klm77
What's The Difference Between The A333 And A343
Mon Feb 07, 2011 8:12 pm
I'm an Airbus A330 fan and I was thinking of how the A333 airframe is identical to the A343 frame (Correct me if I'm wrong). What I wanted to ask is, if it is truly the exact same body, what's the point in owning an A333 when you could just get the A343 and get almost 2000km extra range.
masi1157
RE: What's The Difference Between The A333 And A343
Mon Feb 07, 2011 8:37 pm
Hi!
"Airbus fan" sounds suspect to me, but well. I remember when the first A330 was assembled after a couple of A340s, there were lots of failure reports from production because half of the cables and installations were missing. Yes, the original designs were very similar.
Regards, masi1157
479 different segments on 95 airlines to 199 airports in 54 countries
Stitch
Mon Feb 07, 2011 9:53 pm
Quoting klm77 (Thread starter):
The extra engines and such add about five tons to the empty weight of the plane (using Airbus' OEM figures). That extra weight and those extra engines also result in overall higher fuel burn and can result in a lower dispatch reliability (twice as many engines means statistically more chances for things to go wrong). The higher MTOW of the A340-300 increases airport and navigation fees, as well.
So if you don't need the extra range (which is more like 1500nm at MZFW), you can save fuel and and fees without sacrificing passenger or payload capacity.
masi1157
Mon Feb 07, 2011 10:55 pm
Quoting Stitch (Reply 2):
Is that what he asked?
Regards, masi1157
[Edited 2011-02-07 14:55:49]
klm77
Mon Feb 07, 2011 11:20 pm
The weight on the A343 makes sense to be more because of the extra engines and such but I never took into consideration because it is heavier and has a higher MTOW, the taxes would be higher. Thanks for sharing
Mon Feb 07, 2011 11:35 pm
Well, if you don't need the range the 333 is cheaper to operate. I think also cheaper to purchase.
Viscount724
Tue Feb 08, 2011 2:00 am
If you don't need the A340's range you're also paying to maintain the center-line landing gear and the additional wheels and tires, not to mention flying that weight around for nothing.
Users browsing this forum: Okcflyer, SCAT15F and 2 guests
