Fatigue Countermeasures In Maintenance
Sat Feb 12, 2011 10:55 am
https://hfskyway.faa.gov/HFSkyway/FatigueCBT.aspx
A Very Important topic for Aviation Maintenance Personnell,especially those that woirk the Night shift.
regds
MEL.
RE: Fatigue Countermeasures In Maintenance
Mon Oct 29, 2012 9:10 am
Anyone aware why this site is not being updated....Or is there an alternative link.
LMP737
Tue Oct 30, 2012 9:22 am
I decided the best way to deal with the fatigue associated with night shift was to get a different job. A job where I do not have to work night anymore.
Sun Nov 04, 2012 8:08 pm
Quoting LMP737 (Reply 2):
Someone somewhere has to do the tough job.....If one has a choice then its optional....Not all are that lucky.
FlyDeltaJets
Tue Nov 06, 2012 10:09 am
If you ever want to be an aircraft mechanic among other jobs that work 24/7 best believe at some point you will be working that night shift.
The only valid opinions are those based in facts
DarkSnowyNight
Wed Nov 07, 2012 2:37 am
Quoting FlyDeltaJets (Reply 4):
And in all honesty, it's really not that bad. Even the busiest airports quiet down at night, and traffic coming in/going out always seems to be lighter as well.
Be A Perfectionst, You're Nothing If You're Just Another; Something Material, This Isn't Personal...
FlyDeltaJets
Wed Nov 07, 2012 8:31 am
Quoting Darksnowynight (Reply 5):
When planes park at night that's when the bulk of maintence work gets performed on it. Pilots fly at night on almost every international flight and many transcons. Dispatchers and loadplanners for international sectors are their most busy during the wee hours of the morning as that is the european departure bank. So the airport is quiet in the departure and arrival sense but there is still alot of airline activity going on.
DarkSnowyNight
Wed Nov 07, 2012 9:12 pm
Quoting FlyDeltaJets (Reply 6):
I'm at an Airport almost every night (and often way into the morning as a result of the most recent "promotion"), so I pretty much knew all that. What I mean is that operationally, things are a good deal smoother than what you would see at say, PM1 during a push.
A lot more MX is carried out at night, but it's also a good deal slower paced as these are usually RON projects. While usually more extensive, there also usually isn't the same pressure to get something "out". Like anything, there are a lot of plusses and minuses, and it often boils down to personal preference. For me, overnights always made more sense, so I tend to like them better, but as I said, it's not for everyone.
Also, when I said traffic, I meant on the way into and out of work. That may not have been clear.
Fabo
Wed Nov 07, 2012 9:30 pm
Yep it might be slower, but you are there. It is not like LMP737 put it, a job where you dont have to work nights.
The light at the end of tunnel turn out to be a lighted sing saying NO EXIT
LMP737
Fri Nov 09, 2012 12:25 am
Yes I know that. In the fourteen years I've been working on commercial aircraft thirteen of them have been on nights.
Quoting HAWK21M (Reply 3):
Yes someone has to do it. But as I have found as you get older it gets harder and harder to do. When it comes right down to it the human body is not built for being up all night. Fatigue is just a fact of life when you work nights. You can try and alleviate it a little with exercise but that still does not change the previous mentioned fact.
For me the change came when faced with being stuck on midnights another ten years or possibly being laid off. That's when I realized that the best thing for me health wise was to take a job that did not involve working the night shift.
strfyr51
Fri Nov 09, 2012 5:29 am
Quoting LMP737 (Reply 9):
You are not unlike many people, But if the money is right? You'll get used to just about anything. I worked 6-3 rotating shifts for better than 12 years rotating every 9 days from 10P-6a 6 on 3 off, to 2p-10p to 6a-2p . Now I work 8p-8a and 8a-8p 4 on 4 off. rotating monthly. I hate the shift.. But! since the Money is right?? You do what you have to do. If the Money was right?? ( whatever that might be in your case) I'd BET you'd do it! !
LMP737
Fri Nov 09, 2012 7:24 am
Quoting strfyr51 (Reply 10):
I took a paycut when I switched jobs. In the end the money is not worth it if it ends up ruining your helath and puts a strain on your family life.
Fri Nov 09, 2012 10:56 am
Thats why EDTL in Maintenance was introduced to cater to Fatigue in Maintenance work especially at night.
check AAC 1 of 2012.
http://dgca.nic.in/circular/aac1_2012.pdf
valley1
Tue Nov 13, 2012 6:47 pm
Quoting HAWK21M (Reply 12):
check AAC 1 of 2012
The keywords to note in this document are advisable, guidelines and should. While they are in there it is pretty much unenforcable.
Thu Nov 15, 2012 10:38 am
Quoting valley1 (Reply 13):
True an Advisory may not be mandatory....but out here Operators are taking it seriously & implementing it......
n737aa
Fri Nov 16, 2012 2:13 pm
Its one of the dirty dozen in human factors training.
In 25+ years of aircraft maintenance I've worked 20+ on shifts other than dayshift. Its part of the job.
N737AA
Wed Nov 21, 2012 8:12 am
Quoting N737AA (Reply 15):
Sure is.....But finally with EDTL [employee Duty time limitations] in place for Engineering/Maintenance, things can be easier on the AME/AMT.
Users browsing this forum: Strato2 and 2 guests
