nickh
QUESTION: 737 Landing Gear Doors
Sat Feb 19, 2011 6:43 am
I have a question about something strange that I saw the other day:
I was driving down a major thoroughfare here in Houston, Texas, which just happens to be under the Primary Approach Path to HOU (Houston, William P. Hobby Airport) - mostly frequented by Southwest Airlines.
So - As I was driving along, and I had encountered several stop lights along the way, I noticed two SWA 737s on final to HOU (from where I was, the 737s were still about 25-miles out) and while the first one was flying a standard approach, the second that followed a few miles back, had something interesting to observe:
I noticed that on the second 737, the main landing gear was UP, however, the front landing gear doors were OPEN -- BUT the front landing gear was NOT lowered.
I was at a stop light for about a minute and a half, so I watched the progress of the aircraft (with the sunroof on my car opened) - and I could see that the aircraft was flying for some time with the front gear doors opened, but no landing gear in sight.
So - the question. How can this be possible? As a G/A pilot myself, no aircraft that I know of can allow you to open the gear doors (manually?) but NOT lower the gears. Unless there is something that I do not know.
Any comments/thoughts are appreciated.
-Nick
"We all have wings, but some of us don't know why..."
KELPkid
RE: QUESTION: 737 Landing Gear Doors
Sat Feb 19, 2011 8:37 am
...and as a GA pilot (with lots of complex & high performance time), I can assure you that when the microswitches act up in the wheel wells of Cessnas, that yes, indeed, the doors can sometimes remain opened in flight   I was on board a 210 once with my instructor, and we had to land with the main gear doors open because the gear system was acting up. Destroyed the doors when we drug them along the runway during the flair   Had no choice, our in-flight gear fiddling yielded no results.
Of course, Boeings have forsaken unreliable and failure prone microswitches for better technology years ago. However, I would be willing to wager that what you saw was probably a failure of something-definitely not a normal state of affairs.
n901wa
Sat Feb 19, 2011 12:55 pm
That is strange on a 737. The 737's I have worked on the rods that open and close the nose gear doors are connected to the upper nose gear and thru a crank to the doors. To have both open with the nose gear up, then they must have been wrong. Here's a picture I took tonight to show what I am talking about. Both doors run independent and has no summing rod. HTH
tdscanuck
Sat Feb 19, 2011 1:38 pm
Quoting KELPkid (Reply 1):
Actually, most OEM's forsook unreliable and failure prone microswitches for unreliable and failure prone proximity switches decades ago...although better, it's far from a perfect system.
Tom.
LimaFoxTango
Sat Feb 19, 2011 2:48 pm
Quoting nickh (Thread starter):
The alternate extension system for the DHC8 landing gear technically allows you to open the doors without lowering the gears. The question would then be WHY would you want to do such? Putting that aside, it CAN be done.
You are said to be a good pilot when your take-off's equal your landings.
roseflyer
Sat Feb 19, 2011 3:59 pm
The 737 cannot lower doors without the gear unless something unusual happened. The doors are connected by slave linkages to move with the gear during normal and manual extensions. It's a clever design that eliminates the need for door actuators or door locks.
If the doors were open, I am guessing something was broken on the airplane. The doors are independent of each other and both directly connected to the gear at the shock strut. It surprises me if they were both open, but you never know what can happen.
A complete hypothesis on my part is that the gear doors were re-rigged recently. If someone did not put an adequate preload on the door operating rods and just rigged them to be shut and did not adequately engage the aerodynamic seals, then aerodynamic forces could have forced the doors open in flight. I assume the pilots would notice the noise of that happening, but there is no indication in the flight deck. Regardless the penalty is only drag. The plane is perfectly safe to fly.
737 doors are purely mechanical driven. No switches whatsoever.
AA737-823
Sat Feb 19, 2011 10:27 pm
Greetings from a 737 mechanic, here.
Quoting LimaFoxTango (Reply 4):
Not on a 737, it can't.
Quoting RoseFlyer (Reply 5):
Indeed.
Which is why the OP was either observing an optical illusion, or...... something.
If a rod broke, the aerodynamic forces would hold the door CLOSED, not open.
But the 737 has the simplest landing gear design of any modern airliner... there really aren't any options or failure modes.
tdscanuck
Sun Feb 20, 2011 1:07 am
Plenty of prox switches on the indication side...not on the actuation side though, as you correctly note.
Tom.
SEPilot
Sun Feb 20, 2011 1:10 am
Quoting tdscanuck (Reply 3):
When I was designing grinding machines in the late 70's and early 80's proximity switches were just becoming widely available. Our instructions from management were to only use them when mechanical switches wouldn't work. Within a short time that order was reversed; use proximity switches as the first choice. I do not recall any case where we had a problem due to proximity switches failing.
Sun Feb 20, 2011 10:31 am
On the B737s the NLG doors are mechanically operated through pushrodes/Bellcranks vide the Trunion link rotation & match the gear Extend/Retract sequence.
Your observations if accurate points to a mechanical problem with the NLG doors.
regds
MEL.
nickh
Mon Feb 21, 2011 5:52 am
Thanks for the replies.
Still, what strikes me as odd - that SWA 737 being so close to final approach, unless they were going around and maybe I just happened to catch that second 737 in a holding pattern - perhaps they lowered, but then raised the gears (?) and maybe the hydraulics were slow and I just happened to see it with the gears up, but the doors open at just the right 1.5-minute time-frame, that is the best speculation that I can come up with.
I've flown out of HOU since 1989 and have been around a lot of 737s - the Nose Gear Doors on this particular 737 in question, were open for an abnormally long period of time with no Nose Gear.
Well, there were no local accident reports, so I am guessing that it was just an anomaly. Still, it was a strange thing to see.
Thanks for the comments.
-Nick
bio15
Mon Feb 21, 2011 6:34 pm
If BOTH doors were open, It's possible with BOTH linkage rods broken or disconnected - these should be independent faults since each door has its own linkage rod mechanism.
You can't tell from the flight deck if those doors are open. The green or red "NOSE GEAR" indicator lights only refer to the nose landing gear position, but not the doors. Since it's a mechanical linkage only, you assume that a "NOSE GEAR" green light indicates the nose gear is up and locked AND the doors closed. I'ts important to look at these linkages during the exterior inspecion because if one of them is broken you will be flying with that door open.
I can't find any info on the DDG or CDL that includes the nose landing gear doors, other than the nose gear door rubber seals on the CDL, so I'm not sure if the rods can be disconnected with the doors locked in the open position by any maintenance procedure. I haven't found any info on fuel penalties either.
Alfredo
Fri Feb 25, 2011 9:44 am
Quoting bio15 (Reply 11):
On B737....
Nose Gear Red Light indicate,gear unsafe position or up [depends on situation]
No lights indicates Gear up & locked.
Nose Gear Green light indicates Gear Down & Locked.
regds
MEL.
bio15
Fri Feb 25, 2011 3:11 pm
Quoting HAWK21M (Reply 12):
Yes, my mistake typing! I was supposed to say:
"NOSE GEAR" lights OFF indicate the gear is up and locked. (This when the Landing Gear lever is UP or OFF)
Thanks for clarifying!
Nonetheless, that is considered a light indication of the Landing Gear being up and locked. They're not illuminated lights, but still lights with an ON/OFF meaning. Just as the Flight Control "LOW PRESSURE" lights extinguished indicate that the Standby Hyd Pump SOV has been opened after a loss of pressure in A or B flight controls.
Alfredo
Sat Feb 26, 2011 3:45 pm
Quoting bio15 (Reply 13):
Anytime....
Just to add....The Stby system Flt cntrl Low pr light is connected to the Valve position rather than the Low Pressure switch.
regds
MEL.
bio15
Sat Feb 26, 2011 9:58 pm
Quoting HAWK21M (Reply 14):
The Standby System schematic on the B737NG FCOM shows a direct connection between the Standby Hyd "LOW PRESSURE" and the pressure sensor downstream the Standby Pump, and this connection is broken with the Standby Rudder SOV position (to turn off the Low Press light once the SOV opens). Is there a significant difference between this system and the Classic 737?
Alfredo
Tue Mar 08, 2011 6:26 pm
Quoting bio15 (Reply 15):
From what I remember offhand....The Low pressure light on the P5 panel for Stby is triggered by valve mvmt.
But will recheck.
regds
MEL.
Users browsing this forum: midexjet and 1 guest
