747400sp
A380 Orignially Design With Quad Nose Gear?
Mon Feb 21, 2011 12:10 am
For some reason, around 1997, I remember seeing a drawing for the A3XX (A380) with a quad wheel nose gear. Was the A380 originally design to have a quad nose gear, and if so, why Airbus change the nose gear design to an twin wheel design instead of staying with the quad nose gear design?
Stitch
RE: A380 Orignially Design With Quad Nose Gear?
Mon Feb 21, 2011 1:23 am
The 747-700X concept did have a four-wheel "dualie" nose gear (two wheels and tires per side).
XT6Wagon
Mon Feb 21, 2011 2:23 am
Quoting 747400sp (Thread starter):
Part of what happened in those years was much better tire design. So they could run larger and wider tires than before. This reduces the ground pressure for a given wieght, which in turn can prevent needing more wheels to meet airport compatablity. The primary restriction on wieght per wheel is runway damage, not tire or wheel strength.
