goblin211
Why Do Some Airports Only Have 1 Runway?
Sat Feb 26, 2011 12:35 am
The incident at GCM got me thinking, even if an airport is controlled or uncontrolled, shouldn't there be a backup runway to avoid incidents like this one? I was thinking there should be some kind of FAA regulation that all airports have at least two runways so it could still be operational. I suppose diversions are much less costly but departures are still affected.
From the airport with love
Viscount724
RE: Why Do Some Airports Only Have 1 Runway?
Sat Feb 26, 2011 12:41 am
Quoting goblin211 (Thread starter):
GVA has only one runway and is served by almost 50 carriers. There is simply no room for a second runway.
macsog6
be a backup runway
Not really practical. Take SAN, you'd just have to close it completely. Additionally, many small airfields could not afford to build a second runway "just in case". And, if you have a diversion airfield reasonably close by, there are better uses for public funds.
Sixty Plus Years of Flying! "I fly because it releases my mind from the tyranny of petty things." - Saint Ex
goblin211
Sat Feb 26, 2011 12:54 am
Quoting macsog6 (Reply 2):
But what about departures? They could use the second runway. But yes, I understand it costs money to build runways.
aklrno
Sat Feb 26, 2011 1:00 am
Even for big airports that have room runways are very expensive and its best to defer the second runway as long as possible. At AKL there is officially just one runway but the main taxiway is strong enough to serve as the runway when needed. It must be an operational hassle, but there is a shortage of 747/380 capable runways in New Zealand. AKL is planning a second runway just for smaller aircraft when they have some more spare cash. Please shop more at duty free. (disclosure: I am a shareholder at AKL).
BasilFawlty
Sat Feb 26, 2011 1:19 am
Not enough space is the most important reason at the busiest singe runway airports. At other airports with less traffic it is just too expensive to built a second runway just for back-up.
'Every year donkeys and mules kill more people than plane crashes'
Viscount724
Sat Feb 26, 2011 1:48 am
I recall an incident (photo below) at GVA in 1999 where the nose gear on an IB MD-87 would not extend. They foamed the runway and the aircraft landed with the nose gear retracted. It was in the middle of a busy Saturday towards the end of the ski season when there are many weekend ski charters, apart from the regular scheduled flights. GVA's only runway was closed for several hours resulting in dozens of delays and diversions of inbound flights.
There were many comments that the aircraft should have been requested to divert to an airport (of which there are many not far away, e.g. ZRH) with more than one runway to avoid having to shut down the airport until the aircraft could be moved.
Photo © Martin Steiner
Joost
Sat Feb 26, 2011 3:40 pm
At least in Europe, most airports have only 1 runway. In the UK, important airports like STN, LTN, BHX, NCL and GLA have only one runway. Other examples are STR, NUE, BLL, RIX, LIN*, BLQ, NAP, CTA, VLC, ALC, AGP**, SVQ, FAO, OPO, etc. And in a way, one could add LHR to the list: they have 2 runways, but no back-up possibilities, as they are both permanently used to handle all flights.
LGW is a special situation, as they have one operational runway but a back-up facility as the taxiway can be used as runway. But not simultaneously.
* LIN has a 2,442m and a 601m runway. The 601m runway isn't of any use for back-up purposes.
** AGP is constructing a second runway currently
The construction of extra runways at all these airports is way more costly than the occasional diversion due to runway occupancy.
rfields5421
Sat Feb 26, 2011 4:21 pm
Very few airports need a second runway. That is why pilots have diversion airports in the flight plan.
Most airports with one runway were originally built decades ago - and there is really no room for expansion. Many airports in the US with multiple runways and not real high traffic levels were originally built by US Army Air Corps or US Air Force. In quite a few cases, the local government organization which now owns them is closing all but runway - simply because they are too expensive to maintain properly.
The US FAA does have a criteria for a second runway for cities seeking grants for construction assistance, and very, very few airports have a high enough traffic volume to justify a second runway.
Some new airports built around the world in the last decade are single runway airports - simply because the costs and traffic levels do not justify a second runway.
As mentioned above - geography plays a big role in the decision to add a second runway. While GCM might look like a second runway is possible - you can also see a lot of homes would have to be moved, and most of what looks like open land is mangrove swamps completely unsuitable for building anything.
Yes, a runway incident can inconvenience some people for awhile. But overall this happens almost never at most airports, and for a couple hours only in most cases each year.
SonomaFlyer
Sat Feb 26, 2011 4:41 pm
Some history of SAN
http://en.wikipedia.org/wiki/San_Diego_International_Airport
Space considerations and an extremely hostile set of neighbors make a second runway a non-starter. It is now one of the busier single runway airports in the world.
The risk of a shut down by an accident is simply one of those risks that must be taken. Diversion options for an airport like SAN are plentiful and its been quite some time since SAN was shut down due to an accident.
Sun Feb 27, 2011 12:22 am
The ultimate, and I believe busiest in the world back in the day, one runway airport was Kai Tak. Hardly room for the first runway, let alone a second one.
Photo © Alexander K.
Viscount724
Sun Feb 27, 2011 1:04 am
Quoting Starlionblue (Reply 10):
LCY doesn't even have room for a parallel taxiway. All flights have to taxi the length of the runway either before takeoff or after landing, depending which way the wind is blowing. That reduces LCY's capacity significantly due to the extra time the runway is occupied. And for LCY's first few years it also lacked the holding bay visible at the near (east) end of the runway in the photo below which at least now permits one or two departing aircraft to hold there until another aircraft has landed. Previously an arriving flight couldn't land from that direction until the departing flight had turned around on the runway and taken off.
Photo © N94504
Holding bay under construction in this photo.
Photo © Steve Hall
26point2
Sun Feb 27, 2011 1:44 am
An airport with one runway that REALLY needs more than one is TXKF, Bermuda.
Hundreds of miles from alternate airports. If someone wads it up on the active it could be bad for an enroute that can't make it back to the mainland. Nearest alternate...N. Carolina?
KELPkid
Sun Feb 27, 2011 5:19 am
Technically, unless there is a restriction allowing takeoffs and landings only one way, every airport in the world has, in fact, at least two runways    e.g. an east-west runway has Runway 09 and runway 27
Sun Feb 27, 2011 12:16 pm
LCY is pretty cool, but Kai Tak took 747s, dozens a day. And it had a mountain on the approach path, necessitating an offset ILS and a rather spectacular visual turn at 600 ft altitude to get onto final. I still maintain it was the ultimate one runway airport.
oly720man
Tue Mar 01, 2011 11:10 am
What happens, adding up a couple of one-in-a-millions, if there's a crash on the other runway as well?
Also, it may well be that if an incident is bad enough, even an airport with more than one runway will need to close anyway because all emergency vehicles are dealing with the incident and there is no cover for other runways.
Others probably know the rules and regs regarding airport emergency coverage vs numbers of runways and types of aircraft. So JFK or ORD will have a lot more emergency vehicles than, say, Hartford or Bangor.
xero9
Tue Mar 01, 2011 5:10 pm
This actually made me think of a situation that unfolded at CYKZ. I was doing pre-flight stuff when this happened so I missed most of it, but a few months ago a plane landed on the main runway (15/33) and had some issue with it's landing gear I believe. Basically the plane sat there for a while, and ops were shifted to runway 21. Now, makes me wonder what happens if CYKZ only had the one runway, and you have a bunch of student pilots either in the circuit, or making their way back to the field. Would they send them off to land at another field? Keep them in a hold?
I can only imagine if a poor student was on their first solo flight and this happened.
sasd209
Tue Mar 01, 2011 9:56 pm
Quoting oly720man (Reply 15):
It's the ARFF index in the USA. JFK, ORD, and BGR are all index 'E' airfields while BDL is an index 'D' field. A really nice and fairly accurate write-up of the various index meanings is here:
http://en.wikipedia.org/wiki/Aircraf...cue_and_Firefighting#Airport_index
dxing
Wed Mar 02, 2011 6:34 am
I guess if you are talking about an airport of any size with commercial service now would be the time to chime in with, multiple runways or single runway, if there is an incident or an accident, the field is generally closed at least for a short time. The reason is that the fire fighting capability is busy with the incident/accident unless you are talking about a really major airport like DIA. So even if there are two runways the airport is generally closed as least for a short period of time until the situation is under control and emergency services are released for service.
Quoting 26point2 (Reply 12):
ORF is the closest mainland alternate. But BDA flights must include either fuel for an alternate or a 2 hour island reserve which is essentially the same thing.
Warm winds blowing, heating blue skies, a road that goes forever, I'm going to Texas!
