seachaz
747-8i Door Windows Unchanged From Original?
Mon Mar 21, 2011 7:05 pm
The main deck windows are bigger/more rounded as expected, was curious are the door windows unchanged from the original? From my photos they appear to be but wasn't sure. I assume the doors were pretty much left unchanged from the -400.
Stitch
RE: 747-8i Door Windows Unchanged From Original?
Tue Mar 22, 2011 12:56 am
I have not heard of a new style of Exit Door being used with the 747-8.
SEPilot
Tue Mar 22, 2011 6:59 pm
Quoting Stitch (Reply 1):
Seeing as how doors are very expensive to design and build I would expect that they would have left them unchanged unless there was a compelling reason to do something different, and I do not know of any.
Viscount724
Wed Mar 23, 2011 10:35 pm
Quoting SEPilot (Reply 2):
Even the last 747-400 built in 2009, a 747-400ERF freighter (photo below), still had a main-deck cargo door with plugged passenger windows that dated from the first 747-200 combi built more than 35 years earlier.
http://paineairport.com/images/kpae4976.jpg
No 747s had actually needed the windows for the last decade of 747-400 production (the last -400 combi was built in 1999) but it was presumably cheaper to continue using the door with plugged windows than to redesign it without the window cutouts. I'm not sure whether the cargo door on the 747-8F still has the windows.
UAL747
Thu Mar 24, 2011 2:15 am
Well, in all reality, I believe unlike say the 777 or 767 or even the 787, the 747-1,2,3,4,8i's 5 doors on each side are all very different from each other. In fact, I've heard stories that the over wing exits have a hard time opening when the aircraft is completely full of fuel. (If someone can elaborate, please do). Anyway, I think the 748i's doors are still positioned in parts of the body that allow them to use the same doors that were on the original 747 40 years ago. Now, I wouldn't think it would cost that much to change the window to the 777 style, because I think that's what the new 748 windows are, but when you have to produce 10 doors that are all completely different, I guess it doesn't make much sense. And who really cares anyway? These are rarely used except perhaps 1L/R 2L/R for jet bridges and catering purposes. And then, a window is a just a thing to see through, not something that needs to be more aesthetically pleasing.
UAL
747classic
Thu Mar 24, 2011 9:52 pm
On the photo below the difference between the old style door window and the new (more oval) fuselage windows is clearly visible.
KBFI, RC001, March 20.
Original uploaded by AirlineReporter.com, see for other sizes : http://www.flickr.com/photos/airlinereporter/5545424378/
Quoting UAL747 (Reply 4):
The problem is not the opening of the over-wing doors 3L and 3R with wing tanks full. (otherwise the aircraft would never have been certified).
The problem arises when the wing tanks are full with an over-wing door not closed. Due (a small) deformation of the fuselage and the door-frame, you are unable to close the over-wing door. The aircraft wing tanks have to be (partly) defueled to close the door again.
Operating a twin over the ocean, you're always one engine failure from a total emergency.
747classic
Fri Mar 25, 2011 1:22 pm
Here is a comparison of he cabin windows of all 747 series up to and included the dash 400 and the new elliptical windows of the 747-8 series.
As shown in reply 5, the main deck door windows are NOT changed and are still of the square type.
Elliptical Windows
Remark : the upper deck windows on the 747-8F are also of the "old" square type (crew rest only !).
[Edited 2011-03-25 06:36:58]
