transaeroyyz
Landing Emergency, Is Plane Already Depressurized
Tue Apr 05, 2011 7:07 pm
In a quick Landing Emergency, the plane is on the ground, at what point can u open the exits, how do u when when the plane is depressurized, is there a visual cue besides the flight attendants instruction to open, seconds count...
Fly2HMO
RE: Landing Emergency, Is Plane Already Depressurized
Tue Apr 05, 2011 8:03 pm
Quoting transaeroyyz (Thread starter):
In most planes the cabin outflow valve will go fully open (ie depressurize) once the landing gear hits the ground (a "squat" switch on the gear sends the signal to the pressure controller which then adjusts the outflow valve). The pressurization system should also ensure the cabin will be at field level upon landing, preventing a pressure bump. This is a very broad explanation though, each plane has it's own quirks. In most modern planes pressurization is automatic requiring little to no direct input from the crew.
[Edited 2011-04-05 13:05:00]
transaeroyyz
Tue Apr 05, 2011 10:45 pm
Quoting Fly2HMO (Reply 1):
that's awesome. but how about i throw a belley landing scenario at ya..
fr8mech
Wed Apr 06, 2011 12:27 am
Quoting transaeroyyz (Reply 2):
Then the fuselage ruptures and you don't have an issue.
The cabin pressuriazation system prevents the aircraft from landing while pressurized. If the system is operating in manual, I'm sure that there is a step in the procedure to dump the cabin, by fully opening the outflow valve, prior to landing.
tdscanuck
Wed Apr 06, 2011 4:35 am
By the time you can get to them, they should be ready to open.
If you can't open the door, the plane is pressurized.
No, nor is any needed. The pressurization controller will have the pressure equalized before touchdown and the outflow valves will go full open on touchdown anyway. And, on some designs, starting to actuate the door handle will open relieve valves.
The pressurization controller would have already equalized the cabin prior to landing, so even if the gear function doesn't work there shouldn't be any pressure.
Tom.
Markhkg
Wed Apr 06, 2011 5:07 am
Quoting fr8mech (Reply 3):
Just to point out there have been a few incidents where a cabin remained pressurized once on the ground and flight attendants attempted to open the door (in one case for an evacuation). One aircraft that was studied in particular was the A300. The doors in the studied situations were unable to be opened (as Airbus doors do not have pressure vent gates on their doors, unlike other aircrafts) initially, but later burst open. Flight attendants have been killed in these types of accidents.
(See http://www3.ntsb.gov/recs/letters/2002/A02_20_23.pdf )
Also, Airport Rescue and Fire (ARFF) are actually taught to puncture/make forcible entry into the fusulage/window in case the aircraft remains pressurized and they can't get the doors open in a serious emergency so as to remove the differential. This is, of course, a last ditch step.
Quoting tdscanuck (Reply 4):
Currently manufactered Airbus doors are equipped with a red pressurization warning light on the inside of the cabin. The light illuminates if both engines are off, the door is disarmed but the cabin differential pressure is above 2.5 Hpa. This warning light can be seen from the exterior of the aircraft through the door's window.
Users browsing this forum: bgm and 1 guest
