VC10er
Are All Aircraft "exactly" The Same Size?
Wed Apr 13, 2011 4:12 am
Is every 747, A320, 777, A380, 737 exactly the same size and wing span, or is there an acceptable variance for every manufactured airplane? I know a plane in different extreme temps can change quite a bit. Someone from my company who worked on the LANDOR livery for Concorde said the Concorde can stretch almost a foot longer when very hot at Mach 2+ at 50,000 feet.
But on the ground can 2 747-400's come off the line with an inch different than the other in it's length or wingspan and be ok? Is there an acceptable tolerance for some variance?
I prefer flying over the vacation itself! I go on business trips just so I can fly!
kanban
RE: Are All Aircraft "exactly" The Same Size?
Wed Apr 13, 2011 4:48 am
there are differences because all the components have + - tolerances.. and the accumulation of tolerances can add inches .. likewise if they were all minus you'd have a shorter fuselage, wing, etc.. fortunately the law of averages kicks in and nothing gets distorted too far.
ADent
Wed Apr 13, 2011 6:02 am
No two items are EXACTLY the same.
There is some variation - I do not know the limits. Modern production processes tend to make a more consistent product.
Remember the proud press releases from some of the first all digital products(777, F35, etc) were assembled - and how they fit so well? It implies that was unusual in the past.
If you want some variation go back to the WW II planes put together by the thousands in a hurry.
nighthawk
Wed Apr 13, 2011 7:50 am
Quoting ADent (Reply 2):
It sure was the case in the past, as the UK discovered when it tried to re-wing the Nimrod. They took a sample Nimrod and took the measurements needed for the wings. The wings were produced using modern techniques, and therefore had variances of just a few mm. When they came to fit those wings to the fuselages, they discovered no two fuselages were the same, and none of the wings would fit! This was due to much greater variances in the fuselage, as it was hand built.
kalvado
Wed Apr 13, 2011 8:17 am
Just to be picky: even exact same aircraft would not be exact same size at different conditions: due to thermal expansion dimensions can change quite a bit. At Al expansion coefficient of 24e-6/degC, difference between same plane soaked overnight in ANC winter compared to sitting in DUB in summer can be a few inches - way more than any manufacturing tolerance
And you may want to think about Concorde - at supersonic speed airframe really heated up. 25 cm - or about 10" of a stretch..
VC10er
Wed Apr 13, 2011 9:52 am
Interesting because I knew it had to be so- nothing is "perfect" probably to the dismay of some! So this leads me to my final question: since a "plate" or "panel" (my words) that are rivited together to make a fuselage will expand or contract due to temperate changes will do so in all 4 directions... How do the airplane manufacturers prevent buckling?
bj87
Wed Apr 13, 2011 11:49 am
A couple of weeks ago I read an article in a magazine about this subject.
Now, I don't know if the following story is 100% true but it is relevant to the subject.
KLM used to fly a bunch of DC8-63 aircraft and they noticed that one of the aircraft actually burned a lot more fuel on a given mission than the other aircraft in the fleet. The situation was so bad that they could not use the aircraft on certain routes. The plane was supposedly also a pain to fly.
In the end they decided to check out the entire plane and also did a measurement of the fuselage. It turned out the plane was everything but straight. It was actually quite a lot shorter on one side than the other which explained the extra fuel burn and odd handling.
A couple of years later when Suriname Airlines began operations KLM donated a DC8, care to guess which one?
Photo © Udo K. Haafke
Anyway, don't know if this is true or just a great story.
(edit: word order)
[Edited 2011-04-13 04:51:50]
[Edited 2011-04-13 05:39:07]
Northwest727
Wed Apr 13, 2011 2:23 pm
With more computerized controls and "robotic" equipment manufacturing airplanes, I'd say that the differences between aircraft have shrunk considerably, but that doesn't eliminate them. I can't say anything about size, but with weight, yes. With the 777, for example, at least when it was first manufactured, the sealant on the wing spars (which form part of the fuel tanks) hand to be applied by hand, using a spray gun. Obviously, lots of room for variance there, which would make the airplanes weight much differently.
UAL747
Wed Apr 13, 2011 5:46 pm
A 747's wingspan varies, as do most large span aircraft, depending on how much fuel it is carrying. I believe the wingspan increases about a foot with heavier fuel loads.
fr8mech
Wed Apr 13, 2011 11:09 pm
Quoting VC10er (Thread starter):
This is why many structural components, primary and secondary, and exterior panels come from the manufacturer undrilled. When we have to relace one of these parts, they are fit into place (where possible) and then drilled or we pick-up the holes from the old part and drill.
kanban
Thu Apr 14, 2011 4:22 am
Quoting UAL747 (Reply 8):
I would question that only because the upper and lower skins plus the front and rear spars can not grow and shrink.. they are one piece .. now if they "grow" because the curvature changes , that's another story
tdscanuck
Thu Apr 14, 2011 5:29 am
Quoting kanban (Reply 10):
Dihedral...as you increase fuel load the wing flexes down and, since it was slightly bent up to start with, the span gets larger.
Tom.
jwenting
Thu Apr 14, 2011 8:47 am
Quoting bj87 (Reply 6):
I'd guess that if it were that bad it wouldn't have passed QA testing and pre-delivery customer testing.
I wish I were flying
oly720man
Thu Apr 14, 2011 12:17 pm
Wasn't the April 1st edition was it?
kanban
Thu Apr 14, 2011 2:54 pm
Quoting tdscanuck (Reply 11):
that's the word I was looking for.. however that span increase is only temporary... I think the original question was more about differences betweeen actual planes.. and that goes back to the accumulation of tolerances (which we used to say always happens at the worst possible spot.)
GBLKD
Thu Apr 14, 2011 4:34 pm
Quoting nighthawk (Reply 3):
A similar problem happened when modifying Concorde post AF4590 apparently. It was the kevlar fuel tank liners that caused a bit of head scratching as no two aeroplanes were quite the same size.
bj87
Thu Apr 14, 2011 5:54 pm
Quoting oly720man (Reply 13):
You actually got met to go: uhhh, o god....... and get up and check. Thank goodness the answer is no, man would have been a stupid mistake.
The article was published in the February issue of the Dutch aviation magazine Piloot en Vliegtuig, page 65. It was written by a journalist called Wim Kroese, gotta give credit where it is due, so if the story is fake it is on him.
[Edited 2011-04-14 10:55:50]
bluejuice
Thu Apr 14, 2011 6:03 pm
On another aviation forums, one person told the story of a DC-9 from his time working as a machinist at McD. Whether the story is true or not is still a mystery to me. Still a nice one though along the same lines as the DC-8 tale. The story goes that a DC-9 for carrier he declined to name was in a jig when a earthquake hit. Ended up torquing the airframe pretty badly but still within spec. The plane was completed and pushed out the assembly line. From that time on, the place needed lots of trim to keep to flying straight. According to the poster, the plane has since been scrapped and no longer graces the skies. Even if untrue, still makes a good story.
kanban
Thu Apr 14, 2011 7:48 pm
I wonder if the AF pilot will use differing wing spans between the A380's as the reason for the NY encroachment?
Users browsing this forum: arcticcruiser, CrimsonNL, TVNWZ, Yahoo [Bot] and 18 guests
