gopal
Busy Airways And Tcas
Fri Apr 15, 2011 2:36 pm
Yesterday, I got a first hand experience of the busy skies over the US during my Airtran flight 676 from Orlando to Milwaukee. It was bright and sunny during most of the journey which enabled me to see our path being criss-crossed by contrails left by airliners at different levels. I was able to see a contrail every 7-10 minutes. The contrails were well defined, which means that they were left not too long before our arrival at that point. I was also very luck to witness at a Commuter jet ( may be a CRJ or an EMBRAER) whiz past us at a flight level above us (we were at 34000 ft).
The skies got progressively greyer as we approached Milwaukee. Milwaukee was shrouded by a thick cloud cover when we began our final descent into the airport. As soon as descended into the clouds, we suddenly started a steep ascent which continued for a 1-2 minutes. Soon we resumed our final approach course. The captain came on the air and explained that we got too close to a military tanker and had to back up to allow the safe distance between us and them. We landed safely in heavy cross winds.
On my way out I asked the Pilot about the incident who explained that the procedure was initiated by the them (I am assuming the Military tanker flight crew) because we got closer that 5 miles of them. My questions to the informed members are:
a) Could the crew of the Military tanker has remotely acitvated the TCAS the system on our plane which caused the temporary deviation from our approach path ?
b) Does the 5 miles separation only apply to Military planes only ?
tdscanuck
RE: Busy Airways And Tcas
Fri Apr 15, 2011 2:40 pm
Quoting gopal (Thread starter):
The current generation of TCAS is a cooperative system...both boxes talk to each other and figure out what the appropriate resolution is. So it's not really that one activates the other. But 5 miles is too far out for a TCAS resolution advisory, as far as I know.
Tom.
Mir
Fri Apr 15, 2011 3:20 pm
I'm going to disagree with your assumption and say that the pilot was meaning that ATC requested the deviation.
5 miles separation applies any time when under the control of an ARTCC, as their radars are less precise as a result of less dense coverage.
Quoting tdscanuck (Reply 1):
Way too far. Plus, a TCAS RA shouldn't last for 1-2 minutes.
-Mir
josekmlb
Fri Apr 15, 2011 4:12 pm
In the classes B-E airspace the separation for Approach is 3 miles laterally or 1000 ft vertically or visual separation for IFR to IFR aircraft.
IAHFLYR
Fri Apr 15, 2011 5:04 pm
Quoting josekmlb (Reply 3):
Not in all cases is it 3 NM. If you have aircraft which are 60 NM or further from an ASR-9 with MODE-S or 40 NM or more from an ASR-11 you must use 5 NM separation.
Quoting Mir (Reply 2):
Terminal RADAR systems update at 4.7ish sweeps a minute while the enroute Long Range RADAR updates at 12 seconds a minute. There are a few approach control facilities with ADS-B and an automation system which takes input from the ADS-B radio stations as well as RADAR sensors. The system is called FUSION and it provides a 1 second track update. There will be more faclities coming online this year.
gopal
Fri Apr 15, 2011 7:35 pm
Quoting IAHFLYR (Reply 4):
What is B-E Airspace ? Thanks.
DiamondFlyer
Fri Apr 15, 2011 7:59 pm
Quoting gopal (Reply 5):
He meant Class B, C, D and E.
-DiamondFlyer
From my cold, dead hands
dxing
Sat Apr 16, 2011 5:28 pm
Did you climb back out of the clouds? I'm wondering if there was a restricted area that went hot due to tanker activity and that caused the deviation? That happens a lot off the west coast and to a lesser degree off the east coast. I hope the cpt. used his mirrors for safety when he "backed up"!
Warm winds blowing, heating blue skies, a road that goes forever, I'm going to Texas!
BigSaabowski
Sun Apr 17, 2011 12:35 am
Quoting dxing (Reply 7):
If this was on descent to Milwaukee, a Combat Air Patrol was set up over Chicago on Thursday evening with a tanker and several fighters, due to the President's visit.
[Edited 2011-04-16 17:36:05]
gopal
Mon Apr 18, 2011 5:27 pm
Quoting BigSaabowski (Reply 8):
It was indeed Milwaukee airport we were trying to land in. Thanks for the clarification. Now that I recall, we were on some kind of a holding pattern even before we descended into the clouds for our final approach. It could have been due the extra level of security due the president's visit. Also after coming out of the jetway to the terminal we heard an announcement related to Homeland security elevating the threat level to a particular color ( I do not remember which). All related to the President's visit, I think.
Thanks to all for their answers.
So if the 5m/3m horizontal separation is violated by a commerical airplane, does the ATC warn the pilot and does pilot have to take action or does the corrective action happen automatically?
IAHFLYR
Mon Apr 18, 2011 5:44 pm
Quoting gopal (Reply 9):
If you're asking about ATC required separation, hopefully ATC has taken action to provide the correct separation standard.
If you're asking about TCAS, the traffic advisory (TA) and resolution advisory (RA) issued to the crew is automatic.
Mir
Mon Apr 18, 2011 7:56 pm
The threat level has been the color of an orange for a while, and will probably continue to be the color of an orange for the remainder of eternity (or at least until someone decides to ditch the system). So I wouldn't read too much into that.
Quoting IAHFLYR (Reply 10):
This is correct, but it will not happen at 3 or 5 miles - the two aircraft need to be closer than that.
-Mir
IAHFLYR
Mon Apr 18, 2011 8:12 pm
Quoting Mir (Reply 11):
It might if they're closure rate is fast enough, but I don't wish to be involved in that test!
B747FE
Tue Apr 19, 2011 4:40 am
Not so fast.
TCAS protection is based on tau area, not range.
And it's threshold is basically defined by time. If the rate of closure is fast enough, you could very well have a RA at 5 NM.
B747FE.
"Flying is more than a sport and more than a job; flying is pure passion and desire, which fill a lifetime"
gopal
Wed Apr 20, 2011 12:36 am
A top headline from about 2 hours ago states that the First lady's plane had to abort landing because it came too close to a military cargo C-17. Her plane was ordered to perform a series of "S" maneuvers which did not help. Therefore it was asked to abort it landing and circle the airport. It was allowed to land after a while. FAA is investigating if this due an error on the part of an ATC.
http://www.msnbc.msn.com/id/42669951/ns/politics-white_house/
After all ATC incidents that we have been reading in the news, I am beginning to wonder.
Mir
Wed Apr 20, 2011 3:38 am
Quoting B747FE (Reply 13):
True, but I shudder to think at what the closure rate would have to be for that to happen.
Quoting gopal (Reply 14):
The FAA will find that it was a simple case of "well, I thought that separation would work out, but it turns out it didn't, so I have to send the second airplane around to keep things safe". Happens all the time, and if anyone other than Michelle Obama had been on board, this wouldn't have even made the news.
Wonder not. This one is a non-event.
-Mir
IAHFLYR
Wed Apr 20, 2011 12:56 pm
Quoting Mir (Reply 15):
For sure. But begs the question, why push the edge of the separation envelope particularly with the recent activities with naps and movies?
josekmlb
Wed Apr 20, 2011 6:35 pm
ATC will give vectors for traffic if need be or tell the pilot in trail to maintain a visual separation or even follow when on appch to the rwy with a visual separation.
Users browsing this forum: glen and 29 guests
