cotparampguy
Beacon Light Synchronization
Sat Apr 23, 2011 10:51 am
From what i've seen, usually the beacon lights on A320 series and the 737NG series usually blink at the same time with each other. On some aircraft however, they blink seperately. What causes this difference between the same aircaft? Is this a computer operated function or just a worn type of relay?
fr8mech
RE: Beacon Light Synchronization
Sat Apr 23, 2011 9:50 pm
Power up time. Age of the tube or power supply. Whether the strobes share a power supply or timer. Any number of reasons.
spchamp1
Mon Apr 25, 2011 6:56 am
I have noticed that myself as well on our (B6) A320's. One explanation was that there are actually two bulbs in each housing. A primary and a backup. If the primary goes out then the secondary will kick in and perhaps because of some type of bypass they will blink slightly out of sync.
RJLover
Mon Apr 25, 2011 1:39 pm
I've always like the beacons on the CRJ that blink opposite to eachother (top, bottom, top, bottom, etc).
Last Flight(s): YHZ-YYZ-YVR-YYJ // YYJ-YYZ-YHZ Next Flight(s):
413X3
Tue Apr 26, 2011 5:10 am
747 follows a pattern of slowly going in synch then alternating. Pretty neat.
Woof
Wed Apr 27, 2011 4:05 pm
Quoting 413X3 (Reply 4):
I think I have exactly the same system on my Alfa Romeo.
More to the point, I've often wondered the same as the OP.
Deleted
shamrock137
Wed Apr 27, 2011 6:38 pm
This is not necessarily a design feature, but instead most likely because the top and bottom beacon use two seperate strobe power supplies. Because each power sullpy is designed to flash at say for example a one second interval, the strobes may start off flashing in sync but slowly go out of sync due to tiny differences in each flasher module, but eventually they will sync back up, and again go out of phase. On the other hand aircraft such as the 737 and 757 most likely share a power supply for both lights, this meaning that they flash at the same time. Taking it a further step, Airbus has complete synchronization between all the flashing exterior lights. All the white wingtip and tail lights will flash, then just the wing tip, then the red beacon lights. Im not 100% sure, but I once head that this makes it easier to determine of the plane is coming towards you, or heading in the same direction. If you see the double flash of the wingtip, vs the single flash of the tail, you know which way the aircraft is facing without having to see the position lights. The MD-11 has a similar pattern for its lights as well.
Time to spare? Go by air!
T prop
Thu Apr 28, 2011 5:49 am
On some aircraft when there are separate power supplies, the connecter on each power supply usually will have a pin in the connector terminal for sync. If the strobes are to be synched, these pins will be connected between power supplies.
bond007
Thu Apr 28, 2011 8:11 pm
Quoting shamrock137 (Reply 6):
It's probably less dependent upon power supplies, but purely on whether they are synced electronically or not, because as you say ..
Which will happen regardless of shared of separate power supplies.
Quoting T prop (Reply 7):
That would be the only way to ensure synching I assume, unless each module had a GPS receiver for timing... which out of interest is done on some sets of high towers where the strobes are synched (GPS modules are less than $50 for this application)!
Jimbo
rwessel
Fri Apr 29, 2011 1:32 am
Quoting bond007 (Reply 8):
Well, it could be anything to keep the timebases synchronized, so long as the relevant items all use the same reference. You could even slave all the clocks to the phases on the AC busses (which is why your clock radio never drifts off the right time).
bond007
Fri Apr 29, 2011 1:32 pm
Quoting rwessel (Reply 9):
Yes, very true, but the 'problem' is less with the timing between successive flashes, but more with synchronizing them ... i.e. they can all be flashing at 1 second intervals, but not synchronized. They may start at different times due to delays in the switching of the power supply, the individual module etc. Of course,if your reference interval is the same as the flash interval, this isn't an issue.
Anyway, I feeling somewhat of a geek for even joining this discussion
Jimbo
Users browsing this forum: jking629 and 25 guests
