Luftfahrer
Brake Temperatures After Landing At London City
Mon Apr 25, 2011 3:28 pm
Hello everyone,
London City (LCY) has a very short runway: only 1508m meters long. Still, fairly sizeable aircraft such as the Embraer E190 or the Airbus A318 are based there and are operated into this particular airport on a daily base. I wondered whether a high amount of braking action was needed in order to achieve a safe deceleration. If so, to what degree does this affect the brake temperature after landing? And are the brakes of aircraft that are operated several times a day into LCY more prone to wear and tear?
http://www.youtube.com/watch?v=lmXiwKWU3N4
PS: Those who have insight into E170/E190 operation into LCY, are autobrakes used for landing there? If that is the case, what setting (LO/MED/HI)?
Many thanks!
Marius
tdscanuck
RE: Brake Temperatures After Landing At London City
Mon Apr 25, 2011 3:36 pm
Quoting Luftfahrer (Thread starter):
All other things being equal, yes, you need to brake harder on a shorter runway.
There's a direct (nearly linear) relationship between energy absorption and brake temperature. The total amount of energy to be dissipated is a function of just your approach speed and weight, but the proportion that goes into the brakes (vs. amount into reverse thrust and drag devices) will be different. Shorter runways tend to put more into the brakes, leading to higher brake temperatures.
If they're steel, probably. Steel brakes wear in proportion to energy absorbed. Carbon brakes shouldn't make much difference, since they wear in proportion to number of applications (one cycle wear is about the same, regardless of how much energy went into the brake on that cycle).
Tom
Luftfahrer
Mon Apr 25, 2011 9:32 pm
Thanks Tom.
Quoting tdscanuck (Reply 1):
Would you say that the temperatures rise so much that it becomes a problem, i.e. a longer cool down phase is needed, possibly extending the turnaround time?
Seeing the E-Jets and the Airbus as modern aircraft, can one assume that they are equipped with carbon brakes?
Marius
yeelep
Mon Apr 25, 2011 10:39 pm
Quoting Luftfahrer (Reply 2):
Can't speak for the E-jets or airbus. However the 737NG has had carbon brakes available, as a option, only in the last year or two.
[Edited 2011-04-25 15:42:31]
Viscount724
Tue Apr 26, 2011 12:04 am
Dozens of even larger aircraft, up to 737-800 size, operate daily to/from Rio de Janeiro's city-center Santos Dumont airport where the longest runway is even shorter (1323m, 4341 ft) than at LCY and ends in water at both ends. Brakes and reverse thrust must also get heavy use there.
Photo © Lucio Henrique Daou Robalinho
Photo © Alvaro Horowicz Martins
Photo © Allan Martins Antunes
Video of Gol 737-700 landing at SDU.
http://www.youtube.com/watch?v=9UMgZ61WayA&NR=1
Longer video of TAM A319 approach/landing. Go to about the 3:15 mark for the landing.
http://www.youtube.com/watch?v=CRWGJhHkEXY
tdscanuck
Tue Apr 26, 2011 4:09 am
It all depends on landing weight...for the types of short/medium-haul jets that go in and out of there, that are built for fast turns and aren't tremendously heavy, I wouldn't expect it to be a big problem.
But yes, you do need to monitor brake energy and that can push up your turn time.
Usually, yes. Some stuff with a long derivative history like the 737NG can still be found with steel.
Tom.
Luftfahrer
Tue Apr 26, 2011 12:17 pm
Thanks everyone!
Quoting Viscount724 (Reply 4):
I totally forgot about SDU! Of course, my question can be considered extended to that airport. The only advantage I see might be that the aircraft don't come in as steep as they do in LCY (5,5° angle) and that they have a wider runway available.
Quoting tdscanuck (Reply 5):
Usually, yes.
I guess it would be a worthwhile investment for carriers based at LCY (read: BA CityFlyer) to have their aircraft equipped with carbon brakes.
Marius
oldtimer
Tue Apr 26, 2011 7:21 pm
Quoting Luftfahrer (Reply 6):
BAe146/Avro RJ had carbon brakes from the early days, those that were doing stol landings were also fitted with brake fans, to assist with brake cooling for faster turnrounds
As a further point of interest, Concorde also had carbon brakes.
I assume the A318 and E190 would also have carbon brakes as they are better than steel for harsh application, being more efficient the hotter they get.
oldtimer
Oldtimer, I should have known better!
71Zulu
Tue May 03, 2011 3:18 pm
http://www.youtube.com/watch?v=9UMgZ...&NR=1
Cool vid and looks like the Autobrakes are set to Max.
TPAJAY
Wed May 04, 2011 6:22 pm
I personally like the approach into KEYW, the field is 4800 Ft in length:
http://www.youtube.com/watch?v=1yTefCX3H08
autothrust
Wed May 04, 2011 10:55 pm
Quoting oldtimer (Reply 7):
The A320 series featured unlike the 737/737NG since 1988 carbon brakes.
“Failure is not an option.”
Users browsing this forum: kurtverbose, vikkyvik and 6 guests
