DocLightning
Hard Landing - post-incident procedures?
Sat Apr 30, 2011 7:39 am
On approach into an airport on a stormy day, you experience a hard landing that knocks a few of the O2 mask doors open.
What happens to you now? Is this the sort of thing where you fill out the paperwork and never hear about it again unless you have a huge number of them? Or is this a whole investigation, etc.
-Doc Lightning-
-Carl Sagan
lowrider
Sat Apr 30, 2011 7:57 am
Procedures will probably vary a bit from company to company, but at mine it would generate a log book write up and, depending on the vertical speed at touch down, possibly a hard landing inspection. If the FDR did register a hard landing, there will be additional paperwork to fill out including a narrative. Depending on the circumstances surrounding the event, the history of the individual, and the findings of management, consequences will range from a warning not to make a habit of it up to and including termination.
Proud OOTSK member
contrails15
Sat Apr 30, 2011 10:36 pm
This is gonna seem very vague but there is a procedure in which a pilot fesses up to what they did "wrong" which consists of them reporting what ever it is right away. Its called something but for the life of me I forgot.
Giants football!!!!!!!!!!!!!!!!!!!!!!!!
Viscount724
Sun May 01, 2011 12:38 am
Quoting contrails15 (Reply 2):
I wonder if you're thinking of this program, operated by NASA?
http://asrs.arc.nasa.gov/index.html
contrails15
Sun May 01, 2011 1:36 am
Thats it Viscount. Nice job man. LOL A pilot told me about it one day as we were BSing on the headset.
longhauler
Sun May 01, 2011 1:39 am
Hard landings happen all the time. While the pilot flying may have his/her hand on the stick, it is not always his/her fault.
If there were damage in the landing, it eventually would be found out when it happened. It is always best to log it and report it to maintenance. They will follow the proper procedures from there. More often than not, we are our own worst judges, and the landing was not hard enough to be a concern.
I have never opened up the oxygen mask compartments, but I HAVE knocked the sunglasses off my First Officer's nose! And after maintenance investigation of the FDR, it was not hard enough to warrant any further action.
Fly2HMO
RE: Hard Landing - Post-incident Procedures?
Sun May 01, 2011 1:11 pm
Quoting DocLightning (Thread starter):
Well at my former airline the captain would file an incident report (the way most of them treated it was just to cover their ass). Then they would request MX do a hard landing inspection. 99% of the time the plane was fine. The QAR discs from all planes were pulled daily and sent to the analysts at the FOQA program, the hard landing disc would eventually come into their hands in a day or two and if the recorded values for loads and what not exceed certain parameters the flight would be "flagged" and more in depth analysis would be performed, and the crew of said flight contacted for interrogation, err... explanation
yeelep
Sun May 01, 2011 6:18 pm
Quoting Viscount724 (Reply 3):
There is also the FAA ASAP program which is used by many airlines in the U.S.
http://www.faa.gov/about/initiatives/asap/
lke2fly
Fri May 13, 2011 6:35 am
If a pilot had a missed approached would that fall under the same rule has to right it up to CYA them selfs, and write it up on the log book or is there a different procedure that needs to be followed for a missed approach? I'm sorry but whats a FDR? I know that there are several hard landings everyday and I think the pilots try very hard to make the landing as smooth as possible but sometimes mother nature has a different idea.
bj87
Fri May 13, 2011 11:51 am
Quoting longhauler (Reply 5):
I guess step one of the post landing checklist, The comment "nice landing captain", was omitted that day?
Quoting lke2fly (Reply 8):
If a pilot had a missed approached would that fall under the same rule has to right it up to CYA them selfs, and write it up on the log book or is there a different procedure that needs to be followed for a missed approach?.
A missed approach wouldn't warrant an inspection or anything so I doubt it. But I am not a pilot so I might be wrong. The only thing that happens on a missed approach is that the engines spool up to climb power and the gear goes up and down one more time. Shouldn't be an issue.
An FDR is a Flight Data Recorder. It is one of the orange or "black boxes" that are in the back of the plane and records all the planes movements and instrumentation read outs. It sits next to the CVR Cockpit Voice Recorder. Most planes have two FDR's these days. One in the back in case they crash the thing and a second one in the electronics bay which is used for maintenance purposes and would probably be looked at after a hard landing. The one in the electronics bay looks a bit like a massive USB stick.
At certain airlines, Delta for example, it is a standard operating procedure to announce arrival by putting a crater in the runway. I sometimes really doubt if they even try to "land" it at Delta. (this is just my experience with them though, perhaps just bad luck)
[Edited 2011-05-13 04:53:03]
[Edited 2011-05-13 04:55:48]
kingairta
Fri May 13, 2011 3:35 pm
My C-130 days there was inspection criteria for a "hard landing" however there was no guidence as to what a "hard landing" was. That was left totally to interpretation by the flight crew. I've been a crew on many "firm landings" but never a "hard landing"
I'd imagine quite a few others would be soley judgement calls as to when to perform a hard landing inspection.
Oh as for missed approaches nothing is logged or tracked for aircraft history/maintenance. Those are done quite regularly on training evolutions. Pilot log books would be logged as an approach providided it wasn't a pure visual.
SAAFNAV
Fri May 13, 2011 6:16 pm
Quoting KingairTA (Reply 10):
+1 one that!
If you think it was a hard landing in a C-130, you've put her down at what she was designed to do!
(Might add, crew comfort was not part of that criteria.   )
Erich
Fly2HMO
Fri May 13, 2011 6:27 pm
Quoting bj87 (Reply 9):
If it is what I am thinking then that is not an FDR per se but a Quick Access Recorder (QAR). While yes it records even more stuff than even an FDR would, it is not hardened nor designed to withstand crashes and uses removable media, usually Magneto-Optical discs. Just thought I'd make that distinction, as I worked in a FOQA program retrieving and processing said disks.
yeelep
Fri May 13, 2011 10:22 pm
If a pilot believes he/she has had a hard landing, they will write a logpage and the aircraft will be taken out of service. In the US, a pilot can make a report to the NASA or ASAP programs. With the NASA program, the FAA has agreed not to use any info given in the report, against the person. The ASAP program differs in that the Airline and Pilots group(union) and FAA are in partnership (not all airlines are part of the ASAP program). No action will be taken against the pilot by the FAA or Airline. With either program, all bets are off if it is determined that the reported event was grossly negligent, willfully done, person under the influence, etc.
With the aircraft out of service, maintenance will perform a hard landing conditional inspection, or preferably have the memory card from the DFDAU read and determine that there wasn't a hard landing. If nothing is found, logpage is signed off, aircraft is returned to service.
Quoting Fly2HMO (Reply 12):
Named DFDAU or Digital Flight Data Acquisition Unit. My airline currently uses pcmia cards for memory.
Maverick623
Fri May 13, 2011 11:56 pm
No. Missed approaches happen far more often than hard landings, and don't cause any issues by themselves (although the go-around may be caused by something else breaking).
Nobody ever questions a go-around/missed approach. If the pilot feels it's not safe to continue, well, that's all anyone needs.
Also, missed approaches are often ordered by a controller.
The only "airlines" to make a habit out of hard landings are the Navy and Marines.
Quoting yeelep (Reply 13):
Also, should the FAA via an independent investigation determine that a pilot or controller screwed up, they can use that report as a sort of "get out of jail free card", deferring any administrative actions. This is, of course, provided that the actions weren't deliberate or committed while under the influence.
"PHX is Phoenix, PDX is the other city" -777Way
Alias1024
Sat May 14, 2011 12:18 am
No need to file an ASAP or NASA form for a go-around unless you inadvertently disobeyed an ATC instruction or FAR and that led to the go-around. There's almost never any reason for to cover your a$$ for a go-around.
The only time you'd have to write anything in the aircraft logbook is if the go-around were due to failed equipment on the aircraft like a navigational radio or difficulty with the landing gear or flaps.
The only other things I can think of that would probably necessitate reporting a go-around to the company are if the go-around were caused by a near mid-air collisions or someone shooting a laser into the flight deck.
Fly2HMO
Sat May 14, 2011 12:31 am
I've also heard that one. The naming seems to vary with the manufacturer. Our airline used Teledyne boxes.
http://www.teledynecontrols.com/productsolution/qar/QAR.asp
bj87
Sat May 14, 2011 10:40 am
Yes that is what I meant. I couldn't think of the acronym at the time so I just labeled it a second FDR considering it pretty much does the same. I'll add it to my list of acronyms to remember.
Quoting Maverick623 (Reply 14):
haha, yeah and they even get paid for it.
bueb0g
Tue May 17, 2011 9:11 am
Quoting Fly2HMO (Reply 16):
And Ryanair...
Roger roger, what's our vector, victor?
litz
Thu May 19, 2011 5:20 pm
Several years back, when Ryan Intl (not .eu's ryanair) was flying A320s for AirTran (prior to delivery of the 737s), I was on an ATL-LAS flight ... coming down into the Vegas airport, we smacked the runway ... and I mean smacked ... a few O2 doors popped open, several bin doors popped open, etc. It was a seriously firm thud.
Guy behind me goes "well, I know where HE learned to fly" ... and his buddy chimes right in "yeah, the deck of the Kennedy ..."
- litz
DocLightning
Fri May 20, 2011 6:14 am
Quoting litz (Reply 19):
Right up there with, "Sonny, did we land or were we shot down?"
-Doc Lightning-
-Carl Sagan
Users browsing this forum: kalvado, shamrock137 and 1 guest
