Chamonix
"Center":A Terse Form Of Self-Identification?
Mon May 02, 2011 8:46 pm
What is the ATC protocol regarding the term "Center"?
SPREE34
RE: "Center":A Terse Form Of Self-Identification?
Mon May 02, 2011 8:51 pm
I can only address the US side of it. From the FAA Handbook (FAA Order 7110.65)
" Air route traffic control centers. State the name of the facility followed by the word "Center". "
I don't understand everything I don't know about this.
Chamonix
Mon May 02, 2011 9:31 pm
Is it conventional practice for pilots to drop the digit "one" when repeating the frequency to the air controller?
akiss20
Mon May 02, 2011 10:04 pm
Quoting Chamonix (Reply 2):
Yes it is often done as there are no 2xx MHz frequencies used in aviation. 119.2 might become "nineteen point two" Also as ground control is typically 121.x you will often hear/say "Hold short of taxiway Alpha, ground point 9" and it is understood that ground is 121.9
Change will not come if we wait for some other person or some other time. We are the ones we've been waiting for. We are
P3Orion
Mon May 02, 2011 11:11 pm
Quoting AKiss20 (Reply 3):
What about military UHF freqs? Every ATC facility has them as well.
I will have a Manhattan.
bond007
Tue May 03, 2011 12:54 am
Quoting P3Orion (Reply 4):
Well, they would be using UHF on initial contact, so wouldn't be passed off to another center as "nineteen two". I've never heard (or actually used), an abbreviated frequency for UHF.
Jimbo
sccutler
Tue May 03, 2011 4:22 am
1.
GRK APP: "Bonanza Niner Two romeo, contact Houston Center on one three four point two."
92R: "Contact Houston Center, one three four point two, Niner Two Romeo, G'day."
(changes frequency)
92R: "Houston Center, Bonanza One Two Niner Two Romeo, level one zero, ten thousand feet."
ZHU: "Bonanza niner two romeo, Junction altimeter two niner niner seven."
92R: "Two niner niner seven, Niner two romeo."
2.
Frequency rarely abbreviated, except (as noted above) "Ground point ____" (meaning, 121.___).
...three miles from BRONS, clear for the ILS one five approach...
akiss20
Tue May 03, 2011 4:39 am
Sorry I guess I should have clarified, civil aviation
Quoting sccutler (Reply 6):
While this is following 7110.65, I know I have heard a lot of frequency abbreviations from both pilots and controllers. Maybe it's because I fly in the NYC metro area and NY controllers have a tendency to go off 7110.65 semi-frequently?
bond007
Tue May 03, 2011 7:25 am
Quoting AKiss20 (Reply 7):
The ground control abbreviation is in 7110.65. No others are though:
"... except the following may be omitted:
The numbers preceding the decimal point if the ground control frequency is in the 121 MHz bandwidth. "
Jimbo
Users browsing this forum: WPvsMW and 1 guest
