timmydasquirrel
What Is The Purpose Of The Solid Red Window...
Mon May 16, 2011 8:55 pm
...on Boeing test aircraft??
I have seen what looks like a red plate? covering over a passenger window near the front of the aircraft on the 777, 787 and now the 748.
I would really like to know the reason behind this??
JohnJ
RE: What Is The Purpose Of The Solid Red Window...
Mon May 16, 2011 10:14 pm
I'd like to know, too. The A380 that visited BDL a few years ago had the same thing.
roseflyer
Mon May 16, 2011 10:16 pm
I'm not sure I know what you are talking about (someone else might be more knowledgeable), however I think it is for flight test instrumentation. They will replace a window with a plate with auxilary sensors attached such as additional pitot tubes or other equipment needed to check out systems.
Viscount724
Tue May 17, 2011 3:32 am
Quoting RoseFlyer (Reply 2):
That's the explanation in Replies 17 and 18 in this older thread on the same subject.
What Is That Red Window? (by PipoA380 Nov 4 2005 in Tech Ops)
bikerthai
Tue May 17, 2011 6:20 pm
The plugs are also good for routing wiring to outside of the fuselage during testing.
bikerthai
GZIP: Off
