747400sp
Are The KC-390 Wings Large Enough?
Fri May 20, 2011 3:55 pm
Seeing that the KC-390 is supposed to replace old and compete with new C-130s, I wounder, are the KC-390 wing large enough to do the job that a C-130 could? A C-130 wing has a span of around 132 ft, where a KC-390 wing span, is around 118 ft, that a big difference.
RE: Are The KC-390 Wings Large Enough?
Fri May 20, 2011 4:36 pm
The C-130 was designed in the early fifties and first flew 57 years ago. In the intervening time, aerodynamics have come a very long way. So I'm sure the wing will do.
SchorschNG
Fri May 20, 2011 5:21 pm
The KC-390 will sacrifice a bit of field performance when fully loaded.
The C130 is weak in power, a general problem for props.
The KC-390 will solve small wing area with thrust, a strategy Embraer also embraced for the E-Series.
But correct: the KC-390 is a bit off the usual specifications of a military transport. I guess that Embraer realized that only a very small number of operators use their transports into truly short fields with max payload.
From a structural standpoint, passengers are the worst possible payload. [Michael Chun-Yung Niu]
SAAFNAV
Fri May 20, 2011 7:24 pm
Quoting SchorschNG (Reply 2):
Not quite
kingairta
Fri May 20, 2011 11:21 pm
Is the original question in regards to wing area or enough spacing to fuel two aircraft at one time like on the C-130?
474218
Sat May 21, 2011 12:01 am
I take it you have never flown in an L-188 Electra
Sat May 21, 2011 12:17 am
Not true at all. What makes you say that?
wingscrubber
Mon May 23, 2011 4:39 am
Quoting Starlionblue (Reply 6):
Maybe it's more appropriate to say that the C-130 is just not optimized for the higher sub-sonic speeds like the KC-390, power is not in short supply on a C-130, but the MMO is.
As a reference, google tells me a C-130 has wing loading of 88lb/sq ft, but a 737 classic(similar size to KC-390??) has wing loading of 101lb/sq ft.
Faster airplanes can get away with higher wing loading, thus smaller wings. The trade off will be that C-130 will still kick KC-390's ass when it comes to STOL, but it'll be left behind on longer routes.
[Edited 2011-05-22 21:49:36]
Resident TechOps Troll
Spacepope
Tue May 24, 2011 12:35 am
Quoting Wingscrubber (Reply 7):
Maybe, maybe not. One of the thing the C-130 sorely lacks are high lift devices on the wings. It has simple flaps and no slats. If the KC-390 incorporates slats and, say, slotted flaps (with drooping ailerons) a LOT of the STOL advantage of the C-130 will get eaten up.
One could argue the wing of the C-130 IS the high-lift device, but with its (relatively) fixed shape, it's also the reason for its slow cruise speed.
SAAFNAV
Tue May 24, 2011 1:27 pm
Quoting Spacepope (Reply 8):
The C-130 is quite fitted out for short field relative to its size.. And is 300KTAS not sufficient for what it was designed to do?
It's a Tactical Airlifter, not Strategic, so a 450Kts GS is not what is needed. That you use a C-5 or equivalent.
Erich
Viscount724
Wed May 25, 2011 8:14 am
Quoting 474218 (Reply 5):
Or Convair 580, or Saab 2000.
Users browsing this forum: Stitch and 1 guest
