legacyins
SFO 28L/28R
Fri May 27, 2011 5:41 am
Most, if not all long haul flights to Asia/Europe depart from 28L / 28R at SFO. 28L is approximately 10, 600 ft and 28R is 11,500 ft. Sometimes I hear a particular flight request 28R for departure. I assume this is because it is heavy with paxs/fuel ect. While watching the flight depart, I usually noitce the flight rotate shortly after passing the intersecting runways of 1L/1R. Similarly, a heavy departing on 28L, usually departs shortly after passing the intersecting runways.
My question is, why do some aircraft request 28R for departure when they could use 28L, a shorter runway, witrh the same results?
wilco737
RE: SFO 28L/28R
Fri May 27, 2011 6:02 am
Quoting legacyins (Thread starter):
The longer the runway the better. You should image the case that you have a problem and have to abort the take off. Then the longer the better. For the 'go' case the shorter runway is no problem as well, but the 'stop' case could get more restrictive and maybe you can carry less payload or less fuel.
We requested 28R for departure from SFO to FRA as well. Full PAX and a lot of fuel on the flight back, so we haven't had any restrictions on 28R and the 28L would've been possible as well, but a take off which didn't had a lot of margins. These safety margins were given on 28R, so we requested it and got it for take off.
wilco737
fr8mech
RE: SFO 28L/28R
Fri May 27, 2011 6:08 am
Because runway behind you (or in this case, to your left) is like the airspace above you: useless in an emergency. The flight crews of heavily loaded aircraft should prefer a longer runway in order to provide that added cushion in case something goes wrong.
vikkyvik
RE: SFO 28L/28R
Fri May 27, 2011 6:13 am
I don't know the specific answer for SFO, but just because an airplane takes off at near the same spot doesn't mean it could use the other runway.
One answer could be the runway length that the airplane requires to reject the takeoff from V1. All other things being equal, a heavier aircraft will need more runway in which to stop. So using the longer runway could be predicated on that.
Far as I know there is data that airlines use for every aircraft type on every runway at every airport to which they fly. This will basically tell you how much weight you can put on an airplane for a specific runway, taking into account runway length, wind, weather, runway condition (dry, wet, icy, etc.), required climb gradients with an engine out, etc.
So it's not as straightforward as saying, oh they only used half the runway; they should have used the shorter one.
InnocuousFox
RE: SFO 28L/28R
Fri May 27, 2011 1:28 pm
Remember that 28 L/R start at the same spot. Therefore, if they rotate at identical places (i.e. the 1's) the only difference is the runway remaining. Since, as you noted, the right side is longer than the left, the entirety of that distance is what is remaining.
To change gears for a second, ask yourself this... if the a/c are off the ground in 6000', why would they not be able to use a 6000' runway? Obviously, the answer has to do with the question, "what happens if I decide NOT to rotate?" It's all about the braking distance at that point. If you get to the 6000' mark and have to abort, it's going to take you a little while to slow down. The extra 1000' at the end might be the difference.
Dave Mark - Intrinsic Algorithm - Reducing the world to mathematical equations!
26point2
RE: SFO 28L/28R
Fri May 27, 2011 8:21 pm
Also, for efficiency perhaps SFO prefers 28L for landing aircraft as the terminal is on the left side of the runway. This way aircraft aren't landing on the right and having to wait for aircraft to takeoff on the left before crossing. I've been a sitting duck a few times waiting there...not fun.
Just a wild ass guess really.
Fun fact: embedded runway centerline lights are not actually on the centerline but just to one side or the other. Which side is determined by which direction the plane will turn off the runway after landing to avoid the nose wheel thumping along over them. Check it out.
vikkyvik
RE: SFO 28L/28R
Fri May 27, 2011 9:21 pm
Quoting 26point2 (Reply 5):
Don't know about SFO, but other airports with parallel runways seem to typically use the closer runway for takeoffs, and the far runway for landings.
Examples would be BOS and LAX off the top of my head.
Of course there are exceptions - the cross-country flights I've been on from BOS have generally used 4R/22L for takeoff instead of 4L/22R (I assume that's a runway length thing). And the cargo aircraft from LAX seem to use 25L for takeoff instead of 25R (I assume that's because the cargo areas are located on that side of the runways).
Don't know or can't remember about other airports, but I wouldn't be surprised to find a similar setup at, say, DFW, PHX, etc.
InnocuousFox
RE: SFO 28L/28R
Fri May 27, 2011 11:24 pm
He's talking about pilot requests for the longer runways... not operational issues.
timz
RE: SFO 28L/28R
Fri May 27, 2011 11:42 pm
Quoting vikkyvik (Reply 6):
At SFO 90%+ (?) of arrivals from the south land on 28L, 90%+ (?) of arrivals from the east land on 28R. Arrivals from the north might do their downwind NE or SW of the final, presumably based on which arrival stream has room for them at the time.
By the way-- nonstops to Europe off 1R aren't exactly common, but they're not real rare either.
Bellerophon
RE: SFO 28L/28R
Sat May 28, 2011 12:02 am
timz
...By the way-- nonstops to Europe off 1R aren't exactly common, but they're not real rare either...
True, however, I did once take-off from 19L in a B747 for a non-stop to Europe, and that is rare!
Best Regards
Bellerophon
Aaron747
RE: SFO 28L/28R
Mon May 30, 2011 12:17 am
For all the answer you'll ever need, I refer you to the story of Pan Am 845 in 1971:
http://en.wikipedia.org/wiki/Pan_Am_Flight_845
apodino
RE: SFO 28L/28R
Thu Jun 09, 2011 6:15 am
The biggest noteable exception is PHL, where in the West config, which is more common than East, 27L, the runway further from the terminals, is the primary departure runway with 27R being the main arrival runway.
I can elaborate a bit on BOS. 4L can not be used by Jets for departure for noise abatement reasons (even though 4R has a very simlar flight path and its used quite often), but even so runway 9 is the primary departure runway, but its only 7000 feet long, so the planes that are fueled up more (West Coast and Europre), will use 4R more, especially in the summer time.
22R is a very odd runway. I work for a regional airline that flies into BOS often. Runway 22R returns some very low MTOW's due to what Aerodata terms an Obstacle off the runway. Since the end of the field is the harbor, I don't know what obstacle there is. But strangely enough, on a hot day, the Takeoff performance numbers in BOS often tell me that we are too heavy to use runway 22R and we have to request 22L, in a CRJ. And this is just for flights to places like PIT or BUF. This has never made much sense to me here. But that is why you see 22L used often for BOS.
vikkyvik
RE: SFO 28L/28R
Thu Jun 09, 2011 8:15 pm
Quoting apodino (Reply 11):
My guess is the clearance required for ships in the channel between the airport and the Black Falcon shipping terminal. Or the cranes at the terminal.
Airnav says:
Obstructions:44 ft. boat, 670 ft. from runway, 10:1 slope to clear
But I'm not sure if that is talking about the approach end of 22R or the departure end.
http://www.airnav.com/airport/KBOS
Users browsing this forum: hotelbravo and 2 guests
