axelesgg
Does The Main Gear On A 747 Turn?
Tue Jun 14, 2011 4:28 pm
Hello!
Was at my local airport today and i saw this...
Is the 747 made to do that? (It's a 744)
Fly Draganair
Fly2HMO
RE: Does The Main Gear On A 747 Turn?
Tue Jun 14, 2011 4:30 pm
Only the inboard main does.
On the 777 the rearmost axle on the mains is steerable (castering?) as well.
BMI727
Tue Jun 14, 2011 5:10 pm
Quoting Fly2HMO (Reply 1):
I always thought it was active steering, but I could be wrong.
Tristarsteve
Tue Jun 14, 2011 5:30 pm
Quoting BMI727 (Reply 2):
It is. The amount is controlled by the amount the nose wheels move.
But on a B777 it is very hard to see. It doesn't move much.
Speedbird741
Tue Jun 14, 2011 6:11 pm
Yep, it is a lovely (maybe not for maintenance) feature about the 747 and it is called 'body-gear steering'.
Speedbird741
Boa noite Faro, Air Portugal 257 climbing flight level 340
axelesgg
Tue Jun 14, 2011 6:25 pm
Oh! I've never noticed it before. Thank's for the answers!
Fly Draganair
lowrider
Tue Jun 14, 2011 7:09 pm
Quoting axelesgg (Thread starter):
The classics have this feature as well. It greatly reduces the the stress on the main gear during sharp turns.
Proud OOTSK member
Transpac787
Tue Jun 14, 2011 8:47 pm
Quoting lowrider (Reply 6):
I could be quite wrong but my understanding is that the body-gear-steering system on the 747 classics must be manually activated on the overhead panel in the cockpit, but on the 747-400 it is an automatic system and activates based on groundspeed and position of the nose-wheel tiller.
Speedbird741
Tue Jun 14, 2011 8:57 pm
Quoting Transpac787 (Reply 7):
I believe it is so. If I recall correctly, it deactivates past 20 knots and arms at 15 knots. I also believe it must meet other criteria (i.e. nose gear angle) to arm. The good 747 pilots will hopefully pop in any time and clean up the issue for us.
Speedbird741
lowrider
Tue Jun 14, 2011 9:12 pm
True.
Quoting Speedbird741 (Reply 8):
I thought the speeds were disarm at 25 and arm at 20, but I wouldn't bet more than a cheap beer on those numbers. I also think the body gear steering actuation was based on tiller angle, not nose gear angle.
Proud OOTSK member
Horstroad
Tue Jun 14, 2011 9:20 pm
i think it's just castering, as well as the rearmost axle of the A380 body landing gear does... the 747 body landing gear is actively steering
AA737-823
Wed Jun 15, 2011 12:07 am
Quoting Speedbird741 (Reply 4):
Not bad from a MX perspective, UNTIL the hydraulic actuator explodes during power-up. In Anchorage. In February. In blowing snow.
THEN it's bad. Been there, done that.
B747FE
Wed Jun 15, 2011 1:45 am
Yes. Body gear steering assist nose steering during taxi and towing reducing stress and tire scrubbing.
When the system is armed, the body gear trucks are out of tilted position and the nose steering goes beyond 20 degrees hydraulic fluid is ported to the body gear steering actuators. (Closed loop system)
Full deflection, 13 degrees for the inboard truck and 11 degrees for the outboard (inboard/outboard of the turn) occurs when nose wheel is steered 70 degrees.
As lowrider mentioned the system is installed on the classics as well.
Arming switch on the classics is in the overhead panel. It's manually disarmed right after lining up for take off and armed during landing roll once the aeroplane reaches taxi speed. It's automatic on the -400.
Steering actuator position sensors will activate the take off configuration warning horn if thrust lever #3 is advanced with body gear steering actuators not locked & centered.
Quoting lowrider (Reply 9):
Correct. Signals to the body gear steering are cable driven from the tiller.
B747FE.
"Flying is more than a sport and more than a job; flying is pure passion and desire, which fill a lifetime"
tdscanuck
Wed Jun 15, 2011 5:28 am
Quoting horstroad (Reply 10):
777 is powered too...you'll get a warning if you don't taxi straight ahead long enough on the runway for the steering actuator to lock before you start the takeoff roll.
Tom.
CCA
Wed Jun 15, 2011 5:53 am
Yes the -400 arms as said reducing through 15kts and disarms accelerating through 20kts.
It's the same as the classic and requires 20 degrees of nose wheel steering before the body gear starts moving.
The trucks on the 777 and A380 use a similar system however it's only the rear axle as said both are hydraulically actuated.
The 747 uses the big fat actuators as seen to steer the gear.
Photo © Maxim Finchenko - Aviator project
The 777 uses a clever design of lever and pivot with a single actuator and fixed rod.
Photo © Thomas Merkl
The A380 Uses a similar system and has a previous discussion here.
Body Gear Steering On A A380 (by Qslinger Oct 18 2007 in Tech Ops)
Photo © Rhys Dudley
P1 in A330, A340, A346, B742, B744, B748.
Wed Jun 15, 2011 9:03 am
Quoting tdscanuck (Reply 13):
So if you taxi straight along a taxiway does it lock as well? Do the pilots have to unlock it or is it unlocked by tiller position?
qslinger
Thu Jun 16, 2011 1:07 am
Is the body gear steering applicable for the push backs as well? is it why the the tug pushes the aircraft for some distance even after the aircraft is lined up with the taxi way lines..to get the body gear lined up as well?
Raj Koona
lowrider
Thu Jun 16, 2011 1:41 am
Quoting qslinger (Reply 16):
Yes, provided you are pushing with the #1 hydraulic system pressurized (at least on the 747)
Possibly, but sometimes there are designated start positions as well, or the push may be long to clear another parking stand. Lots of reasons this could be.
Proud OOTSK member
Speedbird741
Thu Jun 16, 2011 9:33 am
Quoting lowrider (Reply 17):
Ok, I am sorry but now I am a tad confused. If the body gear steering actuators are:
Quoting B747FE (Reply 12):
What is the system logic here since there are no (or so I assume) tiller inputs?
Speedbird741
boeingfixer
Thu Jun 16, 2011 1:31 pm
Quoting Speedbird741 (Reply 18):
The tiller is back driven through the nose wheel steering control valve and cables on the nose gear.
John
Cheers, John YYC
B747FE
Fri Jun 17, 2011 1:10 am
Just to clarify: Body gear actuators are not cable driven from the tiller. A cam actuated switch that arms the system (when demand of nose steering goes beyond 20 degrees) is mechanically driven (by cables) from the tiller.
A series of transducers, servo & solenoid valves within the hydraulic module take care of the rest. All steering actuators are powered by the hydraulic system. (System #1)
Not directly but as boeingfixer pointed out, the tiller is back driven.
There are placards right below the tillers advising not to hold or turn the tillers while pushing/towing the aeroplane. (Sorry no time right now to look for it in the database)
B747FE.
Speedbird741
Fri Jun 17, 2011 8:59 am
Quoting boeingfixer (Reply 19):
Quoting B747FE (Reply 20):
Thank you for your explanations. It is now understood.
Photo © Florian Kondziela
Speedbird741
Users browsing this forum: petertenthije and 1 guest
