747400sp
Should Gulfstream Try Airbus New Concept Design?
Sun Jun 19, 2011 1:20 am
Should Gulfstream look at Airbuses recent glass roof design for future product? I was talking to my brother, and he like the design, so I think Gulfstream should look at the design for future product.
aklrno
Sun Jun 19, 2011 1:54 am
I think any engineer who looked at that concept just had a good laugh and went back to work as usual. Do you have any idea what is between the aircraft skin and the interior wall? Wires, ducts, insulation, pipes. Are you aware the skin is a structural element? Do you know of any skin material that is as light as aluminum that could take the pressure load and still be transparent while maintaining the stiffness of the structure? That kind of material is usually referred to as "unobtainium". Let us know where to find it.
The closest thing to the Airbus dream is something like a B-29 plexiglass nose. In that case the operational requirement demanded it, but that part of the aircraft doesn't support much load. That type of nose went out of fashion for good reasons. Today that place is usually occupied by a radar antenna sitting behind a plastic dome.
747400sp
Sun Jun 19, 2011 2:34 am
Before it is pointed, out I know that the topic heading is missed spelled, I was in such a rush that I did prof read my topic, but not the haeding.
Please foregive me.
MD-90
Sun Jun 19, 2011 5:19 am
Quoting aklrno (Reply 1):
Transparent aluminum, of course!
TSS
Sun Jun 19, 2011 6:55 am
Quoting 747400sp (Thread starter):
Ignoring the structural and systems routing problems involved in such a design, what is there to look at through the roof of an aircraft that you can't see plenty of through the existing windows?
GST
Sun Jun 19, 2011 9:12 am
Quoting TSS (Reply 4):
What about when the captain says "and for those sitting on the left of the aircraft you can now see a rocket launching from Cape Canaveral" and you are sitting on the right? Or if noctilucent clouds are appearing out of your arc of vision from the window?
travelavnut
Sun Jun 19, 2011 10:34 am
Quoting MD-90 (Reply 3):
You need a Mac 1 and a Star Trek engineer to pull that one off
Live From Amsterdam!
TSS
Sun Jun 19, 2011 7:04 pm
Quoting GST (Reply 5):
Only once in umpteen flights have I had a captain point out anything outside the aircraft- it was White Sands Missile Range in New Mexico, and it was indeed remarkable to see a patch of white sand in an otherwise brown desert, but it was quite visible from where I was sitting on the opposite side of the aircraft. Also, the most interesting part of any rocket launch happens near the ground; once the rocket is past the normal viewing arc of the windows all that can be seen of it is a vapor trail with a tiny speck of light at it's origin.
I'll admit that noctilucent clouds were something I'd never heard of as such before today (I know enough Latin to grasp the general meaning of the term, but I was not aware that it referred to a specific atmospheric phenomenon), but according to this source (http://science1.nasa.gov/science-news/science-at-nasa/2003/19feb_nlc/) true noctilucent clouds are only visible a few degrees above the horizon when the sun is a few degrees below the horizon, thus they would be visible out of existing aircraft windows. I have seen very similar-looking cloud formations directly overhead at just before sunrise and just after sunset, but since my latitude is far South of the one required for viewing actual noctilucent clouds I can only surmise that what I saw were just pretty clouds of an otherwise ordinary, relatively low-altitude variety.
Don't get me wrong, I'm all for larger side windows on aircraft, I just don't see the point of overhead windows on aircraft.
Furthermore, even with shades in place and closed the solar temperature gain from a bunch of overhead windows on an aircraft would be phenomenal.
[Edited 2011-06-19 12:45:55]
2H4
Sun Jun 19, 2011 8:51 pm
Quoting TSS (Reply 7):
Agreed. We need glass-bottom aircraft.
Intentionally Left Blank
David L
Sun Jun 19, 2011 9:33 pm
Quoting 2H4 (Reply 8):
Or stick with the glass roof but authorise barrel rolls in revenue service.
DocLightning
Sun Jun 19, 2011 9:40 pm
I'm no expert in materials science but I do know a thing or two. The lightest, strongest materials will probably be carbon-based. Carbon is a relatively low-density element with multiple covalent binding modes. The problem is that the strongest and most flexible carbon-based materials contain lots of double bonds. When these double bonds can be assembled into large systems of conjugated double bonds (when double bonds are placed in various configurations in which they alternate 1:1 with single bonds, they form "resonance" patterns where the double bonds delocalize throughout the system), they are very strong indeed. Problem is that large, conjugated systems also absorb light. A molecular layer of graphene (a material that I predict will become indespensible to airline manufacturers once it can be inexpensively manufactured in large sheets) absorbs 3% of incident light. A composite sheet with 100 layers of graphene will be plenty strong for an airplane skin (although it will need a frame underlying it for stiffness), but it will be almost opaque.
-Doc Lightning-
-Carl Sagan
GST
Sun Jun 19, 2011 10:12 pm
If you thought I was supporting the idea, I should have been more clear. Its a publicity gimmick that will never work without the invention of force fields that can act as pressure vessels, I was merely suggesting scenarios where it could be a nice thing for the passengers to enjoy.
Also I'm a glider pilot so the greenhouse effect of a big bubble canopy is entirely familiar to me. I doubt I'd want to be in one with 300 other sweating people in the rush hour que at JFK...
We have the expertise to make windows bigger (and nowadays the will to take the associated weight hit to do so), but the only way I can see this concept working (and it feasible) is to use external cameras and either projection onto the walls or using the IFE screens to present the "virtual" outside world.
TSS
Mon Jun 20, 2011 4:11 am
Yes! I would have no problem riding in the cargo hold of an aircraft as long as I had access to a decent-sized window that looked straight down.
wingscrubber
Mon Jun 20, 2011 4:28 am
The 'transparent fuselage' idea is ludicrous. I can't believe anybody at airbus thought that it's a good idea, you can't build an airplane out of glass.
Conversely though, more external viewing cameras on and around the aircraft, like A380 would be cool, and potentially delete the need for real windows which would be a structural improvement, this will have to be the approach on a blended wing body airliner design where the majority of the occupants will not have a window seat.
Resident TechOps Troll
Mon Jun 20, 2011 6:16 am
It is a "concept", not an engineering model. Airbus is hardly flogging it as "this is the future". They're saying "here's a neat idea". The press, as usual, needs to sell copies so they say "40 years from now, you will fly like this".
Regarding feasibility, the design is not possible today. But in the future who knows. A hundred years ago an Airbus 380 would have seemed like a completely absurd idea.
History is full of examples where people say "impossible" only to be proven wrong later. For example, Napoleon ridiculed steamships: You would make a ship sail against the winds and currents by lighting a bonfire under her deck? Excuse me, I have no time to listen to such nonsense.
I'm not saying we're all going to be flying inside aquariums in 40 years, just that it is very hard to predict advances that far out. 40 years ago, who among us could predict the rise of the Internet?
Here are three of my favorite quotes on the subject.
"All truth passes through three stages. First, it is ridiculed. Second, it is violently opposes. Third, it is accepted as self-evident." - Arthur Schopenhauer
"The only way of discovering the limits of the possible is to venture a little way past them to the impossible" - Arthur C. Clarke
"If an elderly but distinguished scientist says that something is possible he is almost certainly right, but if he says that it is impossible he is very probably wrong" - Arthur C. Clarke
DocLightning
Mon Jun 20, 2011 7:40 am
The more that I look at the design, the more I like it. First of all, the aircraft is not completely clear. It consists of a transparent bubble supported by a solid, opaque frame. That frame could be made very strong indeed, and add the requisite stiffness. Cabin overhead services like ducts and electrical could be managed through the frame. An inner layer could be coated with some sort of opacifying display, similar to the window shades on the 787. That way, the operator could make the fuselage opaque in various portions at will. For example, the ceiling could be blocked out, or the portion of the fuselage facing the sun dimmed significantly.
The effect would be stunning! It would be like standing on a roofless platform in the sky in perfect pressurized comfort.
-Doc Lightning-
-Carl Sagan
David L
Mon Jun 20, 2011 9:47 am
Quoting Starlionblue (Reply 14):
Exactly. All the manufacturers have people visualising concepts for future development and sometimes they make it to the media. To me, it's better that they should be creative enough to sometimes cross the boundaries of of practicality than be so cautious that they avoid going anywhere near them.
hal9213
Tue Jun 21, 2011 2:11 pm
I highly doubt such superflous and costly features being incorporated in commercial aviation. VIP travel however focuses a lot on "have, because its cool". Especially Gulfstream is marketing with its "biggest passenger windows in a plane". A full-glas-cabin as in the Airbus concept is probably technically not feasible, but how about some glas panels in the roof ? It may cost more money and weight to reinforce the surrounding roof/skin, but can be marketed as the first and only VIP jet ever to have a "Sky-View" with natural Sunlight.
Equip it with electrically dimmable glas and its got even more "Coolness Factor".
Should Gulfstream try Irbus, eh, Airbus New Concept Design? No way possible.
Should Gulfstream (and others) try out some new outstanding ideas for future products, inspired by the concept design? Definately!
TSS
Tue Jun 21, 2011 4:35 pm
Quoting hal9213 (Reply 17):
Fair enough. In a similar vein, nobody needs exotic wood veneers laminated to an aluminum honeycomb substrate when simple aluminum stampings would work just as well for cabinets and cabin dividers, yet Gulfstream offers them... and apparently sells the heck out of them.
A full-glass-cabin as in the Airbus concept is probably technically not feasible, but how about some glass panels in the roof ? It may cost more money and weight to reinforce the surrounding roof/skin, but can be marketed as the first and only VIP jet ever to have a "Sky-View" with natural Sunlight.
I can certainly see the value of a modern, light-weight version of the deck prism to provide natural light inside an aircraft cabin, and I suppose a few overhead windows might be a bragging point for Gulfstream owners.
NoUFO
RE: Should Gulfstream Try Airbus New Concept Design?
Wed Jun 22, 2011 10:17 pm
Yes. Do you have an idea how planes looked like less than a hundred years ago?
Quoting Wingscrubber (Reply 13):
Glass? What glass?
What? You would have the sensation of flying through the air without the tin can around. Imagine how spacious the interior would feel. Think of the light and the stars.
Guys, you need to dream more and allow designers to dream if you (and your company) don't just want to follow already beaten paths.
By the way: There's a concept for a yacht that features the voronoi design as well:
http://www.spiegel.de/fotostrecke/fotostrecke-69118-3.html
I support the right to arm bears
Users browsing this forum: Chris8874, mxaxai, TheDBCooper, zanl188 and 22 guests
