TheSonntag
Afghan Airspace: Why Is It Used?
Mon Jun 20, 2011 8:24 pm
Yesterday I flew from BKK to Germany on Thai Airways. The pilot said we would fly over Afghanistan. I was a bit surprised given the fact that there are still ongoing military actions.
Is the whole Afghan Airspace open? Has ist been open all the time? Are there no alternatives to fly around it?
Which countries in the world are actually not used for civilian flights (Lybia right now, North Korea come to my mind)?
Are all airlines flying from BKK to Europe overflying Afghanistan?
Michael
GST
RE: Afghan Airspace: Why Is It Used?
Mon Jun 20, 2011 8:42 pm
The altitude airliners fly at is well above anything the troops on the ground are capable of hitting, and if a diversion is required there are still neighboring countries well within reasonable range.
Also, North Korea is overflown by commercial airliners nowadays, even South Korean planes do.
Zkpilot
Mon Jun 20, 2011 8:55 pm
Quoting TheSonntag (Thread starter):
Pretty standard, most airlines do it on that or similar routes. The US and allies control the airspace and the taleban etc doesn't have SAMs capable of hitting anything much higher than a few thousand feet...most civil aircraft are 34,000ft +
57 types. 38 countries. 24 airlines.
LAXintl
Mon Jun 20, 2011 9:08 pm
Flying over Afghanistan is rather routine.
The FIR was closed on briefly during the initial bombing campaign in 2001, but reopened in 2002 - according to my notes Feb 19, 2002 to be exact for traffic above FL280.
Also around 2005 Afghanistan opened a countrywide area control center ACC replacing its patch work of 1960 and 1970 facilities.
Really the adage of “if you build it, they will come,” was certainly applicable to Afghanistan’s reopened airway system. The country sits at a rather opportune location for overflights.
LAXintl
Mon Jun 20, 2011 9:12 pm
p.s. - you mention North Korea - it also is very much used by airlines, even ones from the US.
canoecarrier
Mon Jun 20, 2011 9:16 pm
Quoting GST (Reply 1):
Yes, but if I remember right, the DPRK only allows KE overflight of it's sea territory not over land or the sea area close to land.
I also think LY has a number of restrictions on overflying Arab states.
[Edited 2011-06-20 14:19:58]
The beatings will continue until morale improves
ryu2
Mon Jun 20, 2011 9:57 pm
Quoting canoecarrier (Reply 5):
Correct; the FAA allows transit through the Pyongyang FIR for US carriers, but only east of 132 E longitude, which is well short of the North Korean landmass.
http://www.faa.gov/air_traffic/publi...es/2011-05-05/Part3,%20Sec%201.cfm
canoecarrier
Mon Jun 20, 2011 11:40 pm
Quoting ryu2 (Reply 6):
Here's the exclusion zone:
Gemuser
Tue Jun 21, 2011 1:57 am
Don't know all the details, but KE was flying over China between VVO & ICN and nowhere near North Korea in August 2010. Following is a description of the route flown on KE 986 on 20 Aug 2010, from the IFE route map:
Instead of turning south east or even east to give North Korea a big miss, we turned due west and crossed into China within minutes. We flew west until we were south of Jilin, then turned south west and flew over Shenyang, Dalian, Yantai and almost to Qingdao before turning due east to reach Seoul. As far as I can see we were ALWAYS in Russian, Chinese or South Korean airspace and never in international airspace and presumably under the relevant Air Defense Command surveillance the whole way. This was obviously the usual route as we landed only 7 minutes late at 1537(-2 hour time difference).
Quoting canoecarrier (Reply 7):
Thanks for that, most interesting. I think it helps explain the route KE 986 took, via China is probably shorter.
Gemuser
DC23468910;B72172273373G73873H74374475275376377L77W;A319 320321332333343;BAe146;C402;DHC6;F27;L188;MD80MD85
TheSonntag
Tue Jun 21, 2011 9:10 am
Thank you very much for your insightful comments.
wilco737
Wed Jun 22, 2011 11:06 am
That is no problem anymore. Even the airspace of Iraq is open and can be overflown.
It was funny when I first approached the Afganistan airspace and called in and then I heard a very strong American accent. I didn't expect that
Sometimes when over Afghanistan you hear them saying: "There will be some military traffic close to your airplane, you won't see them on TCAS, don't worry, they are not getting too close."
wilco737
Wed Jun 22, 2011 11:13 am
Incorrect, terrain goes up to around 25,000 ft, shoulder launched weapons are in range of commercial traffic.
rfields5421
Wed Jun 22, 2011 12:42 pm
Most of the airspace restrictions of overflight in the world today are political and religious based.
Most involve airlines of certain countries not allowed to over fly certain other countries with conflicting political beliefs, or more commonly - different religious beliefs.
TheSonntag
Wed Jun 22, 2011 2:01 pm
Are other countries also imposing rules on which airspace their planes have to avoid like the US does? Is fx. germany also prohibiting the overflight of certain areas for German registered civil aircraft?
canoecarrier
Wed Jun 22, 2011 5:33 pm
Quoting rfields5421 (Reply 12):
Outside of El Al what other airlines are unable to fly of countries with different religious beliefs? Presumably, the airspace restriction is reciprocal to the arab states LY is unable to fly over. Although Royal Jordanian overflies and flies into Israel several times everyday.
Viscount724
Thu Jun 23, 2011 12:05 am
Quoting canoecarrier (Reply 14):
Israel has had diplomatic relations with Jordan since 1994 (and with Egypt since 1979).
bikerthai
Thu Jun 23, 2011 6:14 am
As for overflights, do airline have to pay overflight fees to the respective countries?
If yes, then Afghanistan can use the cash.
bikerthai
gunsontheroof
Fri Jun 24, 2011 2:26 am
Quoting zeke (Reply 11):
You ever tried to lug an already busted-up stinger up a mountain to 25,000 feet on the off-chance a passing airliner MIGHT cross over your position? Me neither, but I bet it's tough. Furthermore, anything over Afghanistan is roughly halfway to wherever it's going so you're probably talking about airplanes that are closer to 40,000 feet than 34,000, particularly if there are 25,000 foot peaks anywhere nearby.
Picked a hell of a week to quit sniffing glue.
baw217
Fri Jun 24, 2011 4:14 am
Quoting bikerthai (Reply 16):
Most counties outside the US and Canada charge Navigational fees additionally. MOTCA have set the current overflight charge at USD 400.
This fee is collected by IATA on behalf of MOTCA.
B747FE
Fri Jun 24, 2011 5:09 am
Why not?
Pretty much.
At least from 2004 when I first went there yes.
Is not really that bad a people thinks.
Flying there since 2004 and while is far to be my favourite place, whatever is on the ground is the least of my worries.
As Wilco said, flying things that you won't see in the TCAS or high terrain around you makes us more nervous than the guys below.
B747FE.
"Flying is more than a sport and more than a job; flying is pure passion and desire, which fill a lifetime"
TheSonntag
Wed Jun 29, 2011 11:50 am
Thanks for your replies. So have you seen military planes flying in Afghanistan?
wilco737
Wed Jun 29, 2011 11:56 am
Quoting TheSonntag (Reply 20):
I did. It was once an AWACS and the other time I couldn't identify it. Some smaller airplane, but too far away to figure out.
wilco737
Rara
Wed Jun 29, 2011 12:24 pm
The gf and I are flying MUC-DEL on LH soon, is that flight likely to be routed over Afghanistan?
Samson was a biblical tough guy, but his dad Samsonite was even more of a hard case.
wilco737
Wed Jun 29, 2011 12:45 pm
Quoting Rara (Reply 22):
Yes, I guess so. Great Circle brings you over Afghanistan so most likely you will fly over it.
wilco737
Rara
Wed Jun 29, 2011 12:55 pm
Quoting wilco737 (Reply 23):
Interesting, thanks... I'll keep an eye out (even though it should be very early morning).
Users browsing this forum: fr8mech, phugoid1982 and 10 guests
