dhawald3
Controlling Airbus A320 With Total Hydraulic Loss
Tue Jun 28, 2011 3:59 pm
In an Airbus A320 the Rudder and the THS have mechanical cable connections for their operation, but these cables run only till the hydraulic servos that in turn move these surfaces with the help of hydraulic pressure.
I was wondering how will the aircraft be controlled if there is loss of all the three hydraulic systems.
as far as I know the Boeing 737 can be controlled even without Hydraulics.
longhauler
RE: Controlling Airbus A320 With Total Hydraulic Loss
Tue Jun 28, 2011 4:41 pm
Quoting dhawald3 (Thread starter):
This is no different from any large transport aircraft designed from the B747 onward. The short answer is no, the flight controls can not be controlled without hydraulic power. To date, in the last 50 years, I can think of only two occurances where that has happened. The JAL B747 out of Tokyo and the UAL DC-10 into Sioux City.
Manual reversion is a "feature" of all old Boeing aircraft designs including the B737, B727 and the B707.
bj87
Tue Jun 28, 2011 5:14 pm
Quoting longhauler (Reply 1):
There is also the DHL A300 that got hit by a ground to air missile in Iraq and lost all hydraulics. The crew actually managed to land it only to come to a halt in a mine field!
They used the planes engines to steer and climb/decent, amazing airmanship.
Link to wiki for the complete story: http://en.wikipedia.org/wiki/2003_Ba...d_DHL_attempted_shootdown_incident
There was also an Air Crash Investigation episode about the incident. Very interesting.
The story should be the same for an A320.
A couple of years back there was even a study/project where they installed a computer system on aircraft that has the capability to steer the plane only using the engines while the pilot still use the joystick/side stick for input controls. I believe the conclusion was that it was achievable but very expensive to build and certify for every plane hence it is not a feature on any plane that I know of.
(I am not sure about this but I believe it was NASA that did the study and actually performed several landings in a real plane using the system. I think I saw this subject on TV somewhere but can't remember the program. It might have been the ACI episode.)
Some pics of the DHL A300
Damage to the wing:
http://upload.wikimedia.org/wikipedia/commons/1/15/DHL_Airbus_A300B4-203F%2C_BIAP.jpg
The place they ended up, the mine field!
http://upload.wikimedia.org/wikipedia/commons/3/35/DHL_Airbus_A300B4-203F%2C_BIAP_7.jpg
Edit: added pictures
[Edited 2011-06-28 10:18:31]
sccutler
Tue Jun 28, 2011 5:17 pm
While I may prefer the Boeing standard for flight control logic, the redundancy built into the Airbii is more than sufficient; there are so many more areas of potential failure that would merit concern, long before worrying about what happens if the series of complete failures necessary to give rise to the OP's scenario.
...three miles from BRONS, clear for the ILS one five approach...
Speedbird741
Tue Jun 28, 2011 6:05 pm
I reckon you imply that not even the Blue pump which is either pressurized electrically or by the RAT is functioning. Well, in that event, I believe there is no way of controlling any flight control surfaces. Although not a loss of all HYD servos, this video shows a simulated loss of Green + Yellow systems with only the Blue system remaining.
http://www.youtube.com/watch?v=6XIn1YGT8pw&feature=related
Speedbird741
[Edited 2011-06-28 11:31:22]
Boa noite Faro, Air Portugal 257 climbing flight level 340
mandala499
Tue Jun 28, 2011 8:58 pm
Well, the 737 has manual reversion, but, it's the only Boeing with it in production. Anything after the 737 (ie: 747, 757, 767, 777, 787) has no manual reversion.
The 737 only has 2.5 Hyd Systems (2 primaries, and 1 small backup system, mainly for the rudder which has no manual reversion in the event of a TOTAL Hyd Fail).
The Airbii and the other Boeings in production, has 3 full Hyd sys... 3 HYD sys are there for a reason... redundancy...
If you have a mechanical link with HYD boost (reversible) like the 737, you only need 2 Hyd Sys (the rudder, non-reversible, has 3 HYD systems)
Mandala499
474218
Tue Jun 28, 2011 10:30 pm
Quoting mandala499 (Reply 5):
Did Boeing remove one of the hydraulic system from the 747-8's?
Tue Jun 28, 2011 10:54 pm
And the A380, it has self contained electro hydraulic actuators which are independent of the aircraft hydraulic systems giving it controllability even in the event of the failure of all 3 aircraft hydraulic systems.
Quoting 474218 (Reply 6):
Still has 4. Systems 1 and 4 power the trailing edge flaps, landing gear, normal brakes (SYS 4), alternate brakes (SYS 1), steering, and their respective thrust reversers. Systems 1 and 4 also provide redundant power to the primary flight controls. Systems 2 and 3 power the primary flight controls, stabilizer trim, elevator feel, and their respective thrust reversers. System 2 also powers the alternate brakes and lower yaw damper. System 3 powers the upper yaw damper. Systems 1, 2, and 3 power the respective center, right, and left autopilot servos. Systems 2, 3, and 4 power the spoilers.
mandala499
Wed Jun 29, 2011 12:43 am
Bahhhhhh!!!
I keep forgetting that it has 4 on the 747s!!!! Luckily, we have Zeke to remind me!
Mandala499
474218
Wed Jun 29, 2011 1:12 am
Quoting mandala499 (Reply 8):
I knew you knew! But you can't let softball like that go by with taking a big swing!
tdscanuck
Wed Jun 29, 2011 4:59 am
As Zeke noted, A380 has EHA's that give you control without hydrauilc system pressure. 787 has something similar. I think the days of no control after full hydraulic failure are gone for new designs.
Tom.
wingscrubber
Wed Jun 29, 2011 5:20 am
Quoting zeke (Reply 7):
A380 only has 2 main hydraulic systems, but each main system has 4 engine driven pumps and 2 electric motor pumps. The the backup EHAs comprise the elements of the phantom 3rd system - they're just at the end of a cable instead of a hydraulic line, though I don't know if they're 100% duty cycle actuators or not.
A320 cannot be controlled with 'total hydraulic loss', as it is pure FBW controlled - no pushrods and bellcranks to allow the pilot to fly the airplane with his strength alone, this is why it must have 3 systems, two primarily engine-driven pump powered and the 3rd is electrically powered. Manual-reversion aircraft are flyable without hydraulics with manual input alone, but this can be very hard work. For example, the Citation X has this capability and has used it, a X pilot who experienced this described it to me as simply being 'very difficult'.
Manual Reversion Flight Controls... (by JETPILOT Jan 17 2000 in Civil Aviation)
The rationale is that no single failure combined with any probable failure can result in loss of the aircraft, so with three systems you can have a single or dual engine failure and still be flyable, or a leak in any one or two systems.
This is why there has been a number of 3-system airliners, including Boeing 75,6,7, Airbus A319/20/21/30/40, Bombardier CRJ etc
The trend now is to try to get rid of that third system, and substitute in EHAs or Powerpacks.
Resident TechOps Troll
thegeek
Wed Jun 29, 2011 7:38 am
I think it's interesting that these systems were knocked out in the QF32 incident, and the plane was only controllable because one of the hydraulic systems remained functional. I was expecting the EHAs to be more robust than the hydraulics. Bad luck, or are the EHA's more about improving economics than improving safety?
Wed Jun 29, 2011 8:45 am
Quoting Wingscrubber (Reply 11):
You are right, I knew it only has yellow and green, and the they dropped the blue (well as your said decentralised it using EHAs).
The A380 has three different types of actuators, the conventional ones that people would be familiar with on other airliners, Electro-Hydrostatic Actuators (EHAs) which are an electrical backup that are active in case of complete hydraulic failure, and Electrical Backup Hydraulic Actuators (EBHAs) that are a combination of a conventional actuator and an EHA. They work as normal actuators when hydraulics are present, and as an emergency backup when not.
The ailerons and elevator have Electro Hydrostatic Actuators (EHA) and the spoilers and rudder have Electrical Backup Hydraulic Actuators (EBHA).
Quoting thegeek (Reply 12):
I am not sure exactly what was knocked out, however the flight controls have power sources from the green and yellow hydraulic systems, the AC bus 1 & 2, and the AS essential bus. Even if the aircraft was totally without any hydraulic power, or electrical power except for the essential bus, it still has ailerons, elevator and rudder control. The flight controls were actually designed with an engine burst in mind.
Both, economics are improved as weight and system complexity is reduced, safety is improved as additional redundancy is provided and the systems are simpler, hence less to go wrong.
tdscanuck
Wed Jun 29, 2011 1:54 pm
Those two statements don't go together. Being FBW has nothing to do with which actuation technology you're using. The JSF is all, or nearly all, EHA actuated (it has no hydraulic system in the conventional sense) yet is pure FBW. There is no technical reason you can't build a steel-cable-pulley-crank actuation system on top of a FBW controller, although I'm not aware that anyone has done it.
Incredibly bad luck...QF32 had a couple of "magic fragments" that severed both legs of a redundant electrical system. This is how they lost control of the engine spar valves too.
Tom.
thegeek
Wed Jun 29, 2011 9:31 pm
Quoting zeke (Reply 13):
AC 1&2 and a hydraulic system were knocked out AIUI. I think they still had one hydraulic system and I guess "the AS essential bus". Which meant a number of spoilers were inoperative, and I think some of the ailerons. But still enough remained to get back on the ground.
wingscrubber
Thu Jun 30, 2011 5:42 am
Quoting tdscanuck (Reply 14):
FBW generally implies the use of electronically controlled servo-actuators instead of pushrod-controlled actuators, as is the case with the A320 - there is no mechanical link between the sidestick and the control surface, so if all three hydraulic systems are down, no sidestick waggling will help. Those statements do go together with respect to the A320(thread topic) because it has no EHAs.
Another failure mode is the case where the electronic input(which is probably dual redundant) to the actuator fails. To fly the A320 you need hydraulic power and electronic control, if you lose either one, you have lost that control surface, unless a secondary or tertiary actuator on the same control surface is still functional.
If the actuator is controlled mechanically, even if the mechanical input comes from a computer, it is not a true fly-by-wire actuator. If you consider any airplane with electric-mechanical input to the control surface to be fly-by-wire, then a Cessna 172 with autopilot is fly-by-wire.
[Edited 2011-06-29 22:49:06]
tdscanuck
Thu Jun 30, 2011 1:52 pm
Quoting Wingscrubber (Reply 16):
Agreed. But nobody said they had to be hydraulic actuators. You can have pneumatic, electric, electro-hydrostatic, etc. There's also nothing wrong with having a pushrod (or cable) controlled actuator where the other end of the pushrod has some kind of actuator, rather than direct coupling to the pilot inceptors (yoke/stick, column, pedals).
In the specific case of the A320, yes, absolutely. And I do acknowledge that the OP was about the A320 specifically. But this statement:
Implies that it can't be controlled *because* it's pure FBW. That's not the issue. It can't be controlled with full hydraulic loss because it doesn't have any non-hydraulic actuators, which has nothing to do with whether it's FBW or not.
Agreed. But if the actuator is pneumatic, or electric, or an EHA, it's can still be true FBW and be fully functional in the event of a total hydraulic failure.
I wouldn't characterize it in that way. In the case of electro-mechanical input to a purely mechanical flight control system, the electro-mechanical input is replacing the *pilot* actuation, not the control surface actuation. The key to FBW is that there is no mechanical link between the pilot inceptors and the control surfaces...positions are read by sensors that drive some type of computer (analog or digital) that then commands the surfaces. The actual power source to the actuators is not relevant to whether it's a FBW aircraft.
Tom.
Jetlagged
Thu Jun 30, 2011 3:01 pm
Quoting tdscanuck (Reply 17):
I understood Wingscrubber's comment to mean that in the case of FBW there can be no mechanical back up in the event of a flight control system power failure as no mechanical linkages exist.
Clearly an electric, pneumatic or EHA flight control servo would not be affected by loss of hydraulic power. Surely the generalised question, beyond the specific A320 case in the OP, is "can the flight control servo be operated without its power source?" In other words is there any back up mode?
dhawald3
Thu Jun 30, 2011 5:27 pm
Here are the flight controls of A320 along with the computer priorities for the redundancies.
travelavnut
Thu Jun 30, 2011 5:35 pm
Quoting dhawald3 (Reply 19):
Nice diagram, thanks for sharing!
Really shows the levels of redundancies in airliners.
Live From Amsterdam!
dhawald3
Thu Jun 30, 2011 6:41 pm
Quoting travelavnut (Reply 20):
Forgot to mention the diagram also shows the control of flight surfaces through multiple hydraulic supply using the three systems in Airbus A320 Green, Blue, Yellow
[Edited 2011-06-30 11:59:17]
tdscanuck
Fri Jul 01, 2011 1:38 pm
Quoting jetlagged (Reply 18):
Ah...OK, that's a different interpretation than I had. Not sure which was the correct one.
However, if we go with that definition, do we not consider the 777 to be full FBW? It has mechanical links to some of the spoilers.
Tom.
Jetlagged
Fri Jul 01, 2011 2:18 pm
Quoting tdscanuck (Reply 22):
Now we're into hair splitting territory. I didn't propose that as a dictionary definition of FBW. The A320 is not "full" FBW by that definition either.
ashyy
Mon Jul 04, 2011 10:54 am
I would say good luck, the fact that the aircraft landed safely and without major damage means the entire hydraulic system design served it's purpose despite extensive damage to the wing following a catastrophic failure that should never of happened.
An uncontained engine failure is a very serious issue, engine manufacturers test for it rigourously and cannot pass an engine into service until it can contain such a violent and high energy failure. There is no predicting what damage that engine could of done to the surrounding wing or worst penetrated the fuel tanks. As the aircraft landed safely and relatively uneventfully considering what happened it's a triumph in the aircraft's design.
It could very easily of been a very different story, UA232 serves as a very real example of the dangers of uncontained engine failures.
[Edited 2011-07-04 03:55:58]
flipdewaf
Mon Jul 04, 2011 11:52 am
Quoting ashyy (Reply 24):
You only have to contain the fan, you arent expected to contain a turbine blade, just minimise the risk if it does go bang.
Fred
David L
Mon Jul 04, 2011 12:37 pm
Quoting flipdewaf (Reply 25):
I thought a shed turbine blade was supposed to be contained. What isn't required to be contained is an entire disc that has shattered into three extremely high energy projectiles, as happened with QF32.
474218
Mon Jul 04, 2011 3:01 pm
Quoting David L (Reply 26):
The turbine blades should be contained, broken/failed bits should exit through back of the engine, if they exit at all. However, uncontrolled failures, where the broken bits and pieces exit through the engine case sidewalls, do happen.
Nothing could contain the fan if it shatters, but there are fan catches that are design to prevent the entire fan from becoming disconnected. When the fan disconnects it moves forward and can actually exit through the inlet. The fan catcher impinges on the fan shaft and prevent its forward movement.
navion1217
Tue Jul 05, 2011 9:13 am
Is the THS hydraulically or electrically actuated?
Speedbird741
Tue Jul 05, 2011 4:30 pm
Quoting navion1217 (Reply 28):
It is hydraulically actuated and controlled either mechanically or electrically. However, mechanical control has priority over electrical.
Speedbird741
flipdewaf
Thu Jul 07, 2011 3:04 pm
Quoting 474218 (Reply 27):
When we were designing an aircraft at uni(I nkow its not the real thing) we were taught that there had to be a less than 20% chance that the burst disc would not hit anything vital, one part of a redundent system such as hydraulics was considered vital, as was the fuselage, the fuel tanks, wing spar, another engine etc. It was done by looking at the aircraft straight on and any "vital" part caused a part of the arc around any given engine to be blocked off, if this was above 20% of the total then it was unacceptable.
Fred
Users browsing this forum: TEALflyer and 3 guests
