glidepath73
Airbus Double Flash Sequence: Improving Safety?
Mon Jul 04, 2011 11:08 am
Hi all,
does the Airbus typical double flash sequence as shown in this video here improve air travel safety?
http://www.youtube.com/watch?v=Xpr5T0EC0_k
Does it help air traffic controllers to distinguish between Airbus and Boeing planes?
How about pilots? Does the double flash help them when departing or approaching airports?
Greetz,
Patrick
Aviation! That rocks...
Horstroad
Mon Jul 04, 2011 11:25 am
i guess it´s just an "airbus thing" to double flash.
ERJ also flash twice a second, but leading edge and trailing edge wingtip alternating.
i don´t think it is to distinguish the manufacturers, as this is completely irrelevant for the controllers.
B777LRF
Mon Jul 04, 2011 11:50 am
Nothing at all to do with controllers, but it is grounded in safety. It's about visual recognition at night by other aircraft, and tests have shown that a double-flash strobe is recognised faster and more often than a single flash. Simple as that.
It's not only Airbus using those strobes, it's a quite popular option on very many business jets as well. Can't recall if any of the other airline manufacturers (BCA, BBD, EMB, SUK etc.) are using single or double flash as standard, or if it's available as an option.
From receips and radials over straight pipes to big fans - been there, done that, got the hearing defects to prove
cloudboy
Mon Jul 04, 2011 12:03 pm
You see it on plice cruisers and other emergency vehicles as well.
"Six becoming three doesn't create more Americans that want to fly." -Adam Pilarski
glidepath73
Mon Jul 04, 2011 12:37 pm
The only big airliner I remember, was the MD-11 which had it as well....
MYT332
Mon Jul 04, 2011 1:13 pm
For the record the double flash is actually two seperate bulbs in each wing firing in sequence.
Or so I learnt here once.
One Life, Live it.
SPREE34
Mon Jul 04, 2011 10:08 pm
DC-10 is the first I saw it on, and that was 1972.
I don't understand everything I don't know about this.
AA737-823
Mon Jul 04, 2011 11:38 pm
Some of the Gen-Av planes do three flashes... gets kinda annoying!
I'm not sure that it's two separate bulbs, either.... It could be, but the ones I've seen weren't.
SPREE34
Tue Jul 05, 2011 12:19 am
Quoting AA737-823 (Reply 7):
You are correct. 1 bulb. By design, the first flash is highest intensity, the next 2 are at a lower intensity. The same system is found in some GA anti-collision strobe lights. (red beacon)
wn700driver
Tue Jul 05, 2011 12:32 am
Quoting glidepath73 (Reply 4):
DC-10, MD-10, & Super 80s do this too.
Quoting SPREE34 (Reply 8):
It isn't so much by design, just that the capacitors haven't had time to fully charge up again between the first and second flashes, hence the first one being more intense.
Base not your happiness on the deeds of others, for what is given can be taken away. No Hope = No Fear
SPREE34
Tue Jul 05, 2011 1:08 am
Quoting wn700driver (Reply 9):
It's an optical illusion on the 80. The forward facing strobe only fires once, yet fro some angles one can see the rearward strobe flash as well, giving the double flash impression. It's not intentional, and the forward and rearward are not sequenced. You'll see this on the E170/75 and 190/95 as well.
I understand the capacitor theory. Makes sense. I was told it's by design by a Wheelen rep. Something to do with involuntary eye movement and following movement. Whatever, I didn't sleep at Holiday Inn last night.
shamrock137
Tue Jul 05, 2011 1:17 am
Another aspect of the Airbus design is it makes it easier to tell which direction the aircraft is facing. The double flash is only in the forward facing wingtip strobes while the aft facing strobe is a single flash.
Time to spare? Go by air!
747fan
RE: Airbus Double Flash Sequence: Improving Safety?
Tue Jul 05, 2011 5:28 am
I'm not sure about improved safety, but it definitely makes it easier at night to identify aircraft - I can almost always tell its an Airbus, or at least narrow it down among bigger aircraft to an Airbus or DC-10/MD-11.
But my guess as to why they have two strobes is due to redundancy. For example, the L-1011 had two different anti-collision lights/beacons on both the top & bottom of the fuselage - from what I've read this was for redundancy purposes. One of the strobes/beacons could be "MEL'ed." I suppose this is the same for the Airbus wingtip strobes. Interestingly, just like the L-1011, the A380 has 2 separate anti-collision strobes on the top & bottom of the fuselage (usually its just 1).
Indeed, except for the Super 80. Also I believe the L-1011 had double wingtip strobes. However, the earlier A300's (A300B2/B4) don't have the double flash sequence.
I'll add that most, if not all of Fed Ex's 727's have the double flash sequence - I'm guessing this was a modification FX did to these aircraft. Interestingly, I've noticed FX A306's/A310 that do NOT have the double strobes (its an interesting sequence where the strobes alternate between the left & right wing, much like the ERJ-145).
wn700driver
Tue Jul 05, 2011 7:10 am
Quoting SPREE34 (Reply 10):
Quoting 747fan (Reply 12):
Yeah, I was wrong about that. I took a closer look at those out on the ramp, they don't have it.
I don't see that it would be a mutually exclusive thing... I know capacitors definitely work that way, but it could still very well be that the sequence was also designed with that in mind instead of a longer sequence...
There's an FX that heads eastbound most nights from AFW, and passes over us at DFW, usually around AM2 or 3, and usually not more than about 3000 or 4000 agl... I have certainly noticed this as well...
navion1217
Tue Jul 05, 2011 9:04 am
For GA airplanes, Whelen had a "cometflash" strobe which would flash 3 or 4 times. I think the Pulselight on landing lights is a better thing. I wish all the motorcycles here in Daytona would have it.
Users browsing this forum: Exabot [Bot], Florianopolis, StereoTechque and 18 guests
