747400sp
Why Do Airbus Test A380 Unpainted Before Delivery
Thu Aug 04, 2011 10:57 pm
I notest, that before delivery, Airbus will test fly an A380 with no paint on the body, but the livery is painted on the tail. So here is my question, why do Airbus do this action?
fritzi
Thu Aug 04, 2011 11:58 pm
The aircrafts is assembled in Toulouse, France and after the initial flight testing flown to the paint shop in Hamburg, Germany for the body paint.
Fri Aug 05, 2011 12:21 am
IIRC the reason the tail is painted before the first flight is that is requires delicate balance, including the paint.
Stitch
Fri Aug 05, 2011 12:32 am
Quoting 747400sp (Thread starter):
Boeing do so, as well.
If the plane is ready for a first flight, there is no reason to wait for it to be painted or the interior installed.
The airline will perform their own test flight prior to delivery once the plane has been painted and the cabin has been installed (though some carriers - like BA - prefer to perform some or all of the interior installation at their own facility after delivery).
tdscanuck
Fri Aug 05, 2011 2:10 am
As noted, it's not just Airbus. A paint hanger, especially one large enough to paint an A380, is an expensive and rare capital asset. Scheduling them is usually very tightly coordinated; if the plane is ready to fly before the paint hanger is ready to receive it, best to get on with the flying.
The tail is painted because the paint is significant enough to alter the rudder balance, so it's painted first, then balanced, then mounted to the aircraft.
Tom.
autothrust
RE: Why Do Airbus Test A380 Unpainted Before Delivery
Fri Aug 05, 2011 1:09 pm
Quoting tdscanuck (Reply 4):
Not that i doubt that but i don't understand how a tail is balanced? Its a rigid structure fastened to fixed points on the aircraft.
“Faliure is not an option.”
boeingfixer
Fri Aug 05, 2011 5:31 pm
Quoting Autothrust (Reply 5):
You're talking about the vertical stabilizer.
Tom.
What Tom is talking about is the rudder itself. Being a dynamic flight control surface it requires careful balancing prior to installation. That is why the rudder is seen painted before the rest of the airframe on the assembly line.
John
Cheers, John YYC
exFWAOONW
Sat Aug 06, 2011 2:19 am
And I thought it was the same reason doctors told their patients to take off their clothes, so they could see any cracks in the skin better.
Is just me, or is flying not as much fun anymore?
Stitch
Sat Aug 06, 2011 3:52 am
Quoting exFWAOONW (Reply 7):
If you have fatigue cracks appear after the first flight...
autothrust
Sat Aug 06, 2011 11:04 am
Quoting boeingfixer (Reply 6):
Thanks for clarification. Now i understand.
bond007
Sat Aug 06, 2011 11:48 am
Most likely all manufacturers. I know it's true for Beech, Cessna, Bombardier, and even the F-18s out of STL.
I'm assuming it's also a lot less hassle if there are problems found that need to be fixed ... i.e. you don't have to re-paint if panels etc. had to be removed.
The completion process for corporate jets is a time consuming process and the aircraft ends up in pristine condition ... something you don't want to do twice.
Jimbo
Quokka
Sat Aug 06, 2011 4:44 pm
This is something that as a lay person I have not considered. While I recognise that rudder balance is significant, is there a great variation in how paint applications affect balance? Would not an effort be made to ensure an equal application of paint to each side of the tail, if even for aesthetic reasons (let alone costs)?
For example (and no indication of airline preference), why would it make that much difference if LH applied the paint to the tail before or after the initial flight? Would not the tail paint weight and distribution be of similar measure?
474218
Sat Aug 06, 2011 5:44 pm
The vertical stabilizer (the fixed part) and the rudder (the movable part) are not built as one unit. After they have each been built the rudder is installed and the entire unit painted together so the pattern (logos) match.
Lufthansa411
Mon Aug 08, 2011 4:40 am
During the factory tour in Hamburg, our tour guide mentioned that the painting schedule had been changed to better accommodate the interior fitting issues that Airbus was having during the production ramp-up. The first few A380's were painted when they first got to Hamburg and then given their interiors. However, with the delays in the interior installation, it was decided that they would wait to paint the aircraft until right before delivery. This way, the paint was fresh when handed over to the customer. At the time, there were 380's sitting outside for several months (6 or more if memory serves) waiting for interiors, and the paint was not up to quality control's delivery standards after sitting for so long.
Nothing in life is to be feared; it is only to be understood.
Quokka
Mon Aug 08, 2011 3:57 pm
Quoting Lufthansa411 (Reply 13):
Interesting point about the paint quality deteriorating before it can be applied. Is this a common problem, not just at Airbus but industry wide?
As an aside, how long ago was your visit to Finkenwerder? In all my visits to Hamburg I have not managed to fit in a tour because of other commitments.
wn700driver
Tue Aug 09, 2011 9:48 am
What I always wanted to know about rudder balancing is what happens when the plane changes owners or liveries... Is the balance process largely the same after a new application of paint as it was in the factory, or less stringent?...
Base not your happiness on the deeds of others, for what is given can be taken away. No Hope = No Fear
yeelep
Tue Aug 09, 2011 5:46 pm
Quoting Quokka (Reply 11):
The balancing of the rudder is done in the fore/aft direction perpendicular to the hinge line. The paint application to each side of the rudder doesn't effect the necessity to balance it. Even if the rudder wasn't painted it will still have to be balanced.
The manufacture could choose to fly the plane before painting the rudder, but the extra cost and time makes it uneconomical. The rudder would have to be balanced, installed, flown, removed, painted, balanced, installed, flown.
Quoting Quokka (Reply 14):
The point was not to paint the aircraft and then let it sit outside, exposed to UV light and other environmental damage, for up to six months before delivery.
Quoting wn700driver (Reply 15):
The same...at least for the 737.
474218
Tue Aug 09, 2011 5:47 pm
The repaint requirements are specified in the SRM. Usually two complete repaints are allowed (with additional incremental weights added). But once you reach as specific point you can not add additional incremental weights and stripping repainting and complete re-balancing is required.
EMBQA
Tue Aug 09, 2011 6:43 pm
Quoting Stitch (Reply 3):
Flying without the interior would be a weight and balance nightmare. You would need to do one before and after the interior is installed.
Rudders are balanced to reduce flutter. You balance on the hinge line.. and the water line.
SchorschNG
Tue Aug 09, 2011 8:13 pm
Quoting EMBQA (Reply 18):
I guess a balance load could do the job.
Also, the interior is usually quite well arranged about the center of gravity.
From a structural standpoint, passengers are the worst possible payload. [Michael Chun-Yung Niu]
bonusonus
Wed Aug 17, 2011 8:26 pm
The unpainted aircraft usually look green and yellow. Is that a primer applied to the aluminum in the factory? At what point in the fabrication process does this happen?
EMBQA
Wed Aug 17, 2011 9:16 pm
Quoting bonusonus (Reply 20):
Airbus uses a process in manufacturing their aircraft called Bonded Primer. This is a chemical process done to the raw aluminum sheet at the mill. It can not be removed or it will induce corrosion. This is why you see no bare metal skinned Airbus aircraft. It is also what gives their aircraft that yellow-green look you're talking about. It is a process very common in Europe and done with Airbus, ATR and Saab. Many might remember the big skin corrosion issue Saab operators had 8 or so years ago when many were found to have had the bonded primer removed during re-paints not done to the SRM.
Boeing uses AlClad Aluminum in their construction and do not need this process. That is why you'll see bare metal Boeing.
exFWAOONW
Thu Aug 18, 2011 1:43 am
Quoting Stitch (Reply 8):
Ya don't want to waste paint...
exFWAOONW
Tue Aug 23, 2011 5:16 pm
If you ever get past security into the restricted section, be sure to watch when they make the plane turn and cough to see what falls off.
474218
Tue Aug 23, 2011 8:47 pm
Quoting EMBQA (Reply 21):
Boeing uses a spray-on plastic coating on the alclad skins to reduce the damage during transportation and assembly. You can see coating which is blue/green in the attached photo.
Photo © Royal S King
EMBQA
Tue Aug 23, 2011 11:13 pm
Quoting 474218 (Reply 24):
..and that is removed prior to painting. The bonded primer is not
474218
Tue Aug 23, 2011 11:45 pm
Quoting EMBQA (Reply 25):
Which is ... after ... transportation and assembly!
Users browsing this forum: Acey, Starlionblue and 1 guest
