VC10er
For A Novice, How Are Composite Materials Made?
Mon Aug 08, 2011 2:42 am
I have only the most basic understanding of composite materials AND how they are used on aircraft? I believe I am correct in my assumption that the 787 will be the the aircraft (commercial) that has used and even pushed the envelope the most composite material.
A few questions from a novice:
How is it basically made?
What are composite materials composed of?
Is it true that the 787 fuselage is baked in a tube shape?
Is lighter weight it's primary purpose?
Is it equally as strong and flexible as aluminum or steel?
Any other things about composites a novice would fascinating?
THANK YOU SO MUCH!
I prefer flying over the vacation itself! I go on business trips just so I can fly!
bristolflyer
RE: For A Novice, How Are Composite Materials Made?
Mon Aug 08, 2011 3:17 am
From one novice to another...
I believe the 787 is the first all composite a/c. Others (eg some Airbusses) have stabilizers that are composite (the composite stabilizer was at the center of the investigation of the AA A300 that crashed just after 9/11 in New York).
I don't know a great deal about the mfr process, but it involves layering strands of fibers on top of each other in alternating directions (so the finished product is strong in all directions). Then you bake it to make the resin hard.
Fortune favours the brave
KELPkid
Mon Aug 08, 2011 3:26 am
Quoting VC10er (Thread starter):
A fibrous, carbon-based material with high tensile strength is placed in a material which bonds the fibers together (like an epoxy), and then cured (usually under heat) to cause the bonding reaction to occur. This creates one layer. Then, another layer is sandwiched on top and bonded to the first layer, and another, and another...until the desired strength/thickness of the material is achieved.
Carbon fibers + a bonding agent
Not always. Many times, it is cheaper to design complex shapes (like fairings) as a composite rather than using traditional metal working techniques.
I'm sure it depends upon the composite and thickness. I would imagine that, in fact, composite is more flexible than a traditional metal like aluminum.
BMI727
Mon Aug 08, 2011 3:35 am
Quoting KELPkid (Reply 2):
In principle, it can be thought of somewhat like paper mache, with the carbon fibers being like the paper and the epoxy being like the glue.
It can also cut down on maintenance significantly. When you get barrels or large carbon fiber panels instead of conventional aluminum panels you can cut down on the number of fasteners and joints, all of which need to be inspected.
Horstroad
Mon Aug 08, 2011 12:04 pm
almost correct, but you add all layers before baking it.
basically you have the fibre, which can be carbon or glass, and a matrix which is usually epoxy resin combined with a hardener. in aircraft manufacturing these two components are already brought together with the right ratio, to achieve an optimal bonding. so you add all layers of so called PrePreg and put it in an autoclave where it is cured with high pressure (something like 150psi) and high temperature.
the 787 fuselage is made of 3 major parts which is, in my opinion, a disadvantage to the A350 which is made of huge CRP panels. I think the panel solution is easier to handle in case of damage, as you can simply change them. repairing carbon fibre structures can be quite difficult.
light weight and high strength are the primary reasons.
I was told "its as strong as steel but lighter than aluminium". I made myself a mouse pad of about 8 or 9 layers of carbon fibre. this thin plate of plastic can carry my whole weight standing on it when I lay it over a gap only resting on two edges.
another type of composite material not mentioned before is glare. it´s a combination of glass fibre and aluminium
Northwest727
Mon Aug 08, 2011 12:54 pm
Carbon fiber is apparently stronger than steel.
I'm curious though, say the composite skin is damaged and repaired with a patch (standard practice)...is the patch now going to create a weak spot that is a nuisance to maintenance (ie, cracks)?
dlednicer
Editor
Mon Aug 08, 2011 6:11 pm
Common composites are fibers of glass, carbon, boron or an aramid such as Kevlar, embedded in epoxy or polyester resin. They can be cured at room temperature or at elevated temperatures (baked).
Composites usually have more tensile (pull) strength than metals, but less compressive strength (except rebar reinforced cement, where the opposite is case). Technically, they can be lighter than equivalent metal construction, but usually, when all is said and done, they come out the same weight or heavier. They have very good fatigue and corrosion resistance, but you can get problems with things like aluminum touching carbon composites, where you get corrosion from the dissimilar materials. Kevlar in particular, has moisture absorption problems, but is very abrasion resistant (and hard to cut). Most composites are not very abrasion resistant. Composites are easier than metals to form into shapes with complex curvature.
To me, the biggest drawback of composites is that no one has demonstrated a viable means of recycling them. There have been a lot of claims, but I have never seen a commercially functioning process. For example, when Beech destroyed the Starships, the incinerated them at very high temperature.
Composites won't completely replace metals, but are rather an alternative material.
BTW - wood is a composite, created by nature. Cement with steel rebar is a composite, as are automobile tires, with rayon cords and steel fibers embedded in vulcanized rubber.
VC10er
Mon Aug 08, 2011 7:42 pm
Quoting horstroad (Reply 4):
Super THANKS to everyone, this is all very educational and I can talk about it at dinner and sound smart!
From you account it sounds like the Enterprise (the Starship) will be made of composite's - but probably not wood.
Any more input will help.
Is there like a big metal form to wrap the composites around for the 787?
...and if composites are not really lighter than metal, how is it the 787 will (hopefully) be able to burn less fuel? wings and engines?
BMI727
Mon Aug 08, 2011 7:55 pm
Quoting VC10er (Reply 7):
I'm not sure about the 787, but use of a mandrel is one of the ways large composite pieces are formed. I want to say that is exactly how the Beechcraft Premier fuselages were formed.
Horstroad
Mon Aug 08, 2011 10:59 pm
here is a video about the 787 assembly process... it may be interesting for you
http://www.youtube.com/watch?v=f07HpUAuWgk&feature=related
soon7x7
Tue Aug 09, 2011 1:02 am
51% for the 787 will be carbon fibre. A composite is actually several materials cured to form one. Adobe bricks are actually composites. They are mud reinforced by straw. Boats, surfboards are composite. In aerospace, the first to be used in commercial transport was polyester resin and fibreglass. It is still used today however the polyester was replaced by epoxy resin. The fabrics involved are fibreglass, Kevlar, carbon fibre, carbon fibre w/ boron and carbon/carbon. Initially wing fairings, canoe fairings or "secondary surfaces" were the areas subject to its application. The spoilers of 747's from its inception were fabricated from aluminum honeycomb laminated between layers of aluminum. This method, also considered composite. During the design of the 757, 767, Carbon fibre entered the picture while its use or applications grew on the airframe design. The dive brakes or spoilers, wing fairings, wing lower panels, engine cowlings, rudders, ailerons, etc, saw all composite fabrication with obvious much success. The first Boeing "primary structure" to utilize composite technology was or is the 777 vertical fin. Most of the above mentioned structures are nomex honeycomb core or "resin impregnated paper". The honeycomb core is shaped and then layed up with the resin impregnated fabrics which may be individually , fibreglass, Kevlar, carbon fibre or a matrix of all of them at once...depends on the application. The resins used call for by design certain cure rates and cure temperatures. The parts will be cured in an autoclave the draws out any air and compresses the fabric layers while they cure out. This can take 1/2 hour to several. result is an incredibly light and very strong product.
Airbus led the way with composites in primary structures during the development of the A310. All the tail feathers were composite application. Next they redesigned the A300 tail grouping as compared to its alloy predecessor and yielded a weight savings of about 347 lbs. Not much but it allowed for more PX seats...more flight revenue. Airbus has also pioneered Aluminum lithium into their designs. This is a product Boeing rejected during the 777 development as it had inherent fracture characteristics during manufacture. While composites have amazing qualities they have draw backs including internal damage detection, composites are porous so the exterior topcoat must always maintain its protective integrity. Repainting these surfaces requires a different approach as they are easily damaged. They are also easily repaired. With the 787 as far as I am concerned the jury is open one this one. Not sure how fuselage damage repairs will be approached. Just because it is constructed of carbon fibre does not mean it is indestructible. The leading edges of the space shuttle Columbia were made from Carbon Carbon and we all saw what a block of lightweight foam did to it and the result that unfortunately followed. All in all, composites have made for intersting innovations in aircraft design...some good, some not.
VC10er
Tue Aug 09, 2011 1:55 pm
Quoting horstroad (Reply 9):
Quoting soon7x7 (Reply 10):
Thanks to you both, I will watch the video. Also learning about the vertical fin is interesting. I recall a TV special (can't recall if it was a news story or documentary) when AA took delivery of the A300 and the fact that they would have to use a flat grey paint on the vertical tail vs shiny metal to paint it's AA logo onto and how the overall ac would look like as a mixture of really "almost chrome-like aircraft when clean" metal parts with other parts in grey. I hated the way it looked at the time- but now it seems like an actual part of the livery. The picture that always was stuck in my head was the AA 727 which seemed like 100% metal. Like the album cover of the beasty boys (dating myself)
Have there been discussion about their future 787 where the entire fuselage will need to be flat grey!
I wonder if the ac paint suppliers can develop a good silver for the composite parts?
bikerthai
Tue Aug 09, 2011 6:57 pm
Quoting Northwest727 (Reply 5):
No, typically the patch is over built to avoid the weakening the structure. And crack or crack propagation is not a problem with graphite epoxy panels.
You really can't compare strength of composite vs. metal on a one for one basis. It depends on the complete design and how it's optimized for one material to another.
Typical industry design have shown that a good composite design will be 20% lighter than a comparable metal design. (My own experience included).
If you want to understand how it is made first hand, you can try making a composite panel yourself.
All you need is a fiberglass cloth and some two part epoxy from the hardware store.
Lay the fiberglass on a smooth metal surface, brush the epoxy on to it and let it cure.
For better resin and fiber you may try the local boat repair shop.
Of course the material they use for airplanes are more processed and better suit for rate production, but you will get a sense of how it works.
More samples of in-expensive composites can be found in tennis rackets.
bikerthai
[Edited 2011-08-09 11:58:42]
soon7x7
Wed Aug 10, 2011 12:59 am
West marine offers "vacuum bagging" technology through their epoxy systems. Just get the manual and read it...you will then have a great idea how composites are produced, generally speaking...good idea bikerthai!
dynamicsguy
Wed Aug 10, 2011 11:38 am
A good layman's guide to composites, and pre-pregs in particular, can be found on Hexcel's website here. Hexcel is a material supplier to the industry.
tdscanuck
Wed Aug 10, 2011 11:40 pm
A common issue is that people (in aerospace) often automatically equate "composite" with "fiber-reinforced plastic" which is just *one* type of composite, and even then it's a really broad category. *The* major advantage of composites is the ability to tailor their properties. It's easy to make a composite that's more or less strong or more or less flexible than metal. There are also metal composites that have properties better than any individual alloy.
Permanent repairs need a damage tolerance analysis just like the original sturcture, so it needs to be at least as good at not cracking as the original structure. Usually the repair is overstrength just to make up for any discrepancies in the application of the repair, so it's more likely to be less maintenance prone than the original (but heavier).
I still have the Star Trek:The Next Generation Technical Manual...the Enterprise (at least NCC1701-D) is, according to cannon, in fact made from composite (some kind of fiber-reinforced ceramic). So is the warp core.
Yes, it's called a mandrel. There are several for each fuselage section.
About half is supposed to come from engines, about a quarter from systems & aerodynamics, the rest from weight. A lot of the maintenance savings also comes from the composite, as well as a lot of the cabin comfort features.
Tom.
474218
Thu Aug 11, 2011 3:52 pm
Quoting tdscanuck (Reply 15):
Composite on aluminum repairs where developed and approved years ago so I would think a composite to composite repair would be simple.
soon7x7
Mon Aug 15, 2011 3:27 am
Depends on the nature of the repair. Vacuum bagging may be required on an AOG aircraft to a component that is not easily removed. In short it would be easy to the experienced tech w/ the proper evaluation and repair gear. To the less experienced, the evaluation will probably not be correct and the repair will ultimately fail. Composite manufacturing is typically performed in a very controlled environment but not always repaired in same.
PurdueAv2003
Fri Aug 19, 2011 11:17 am
I'm going to disagree with this statement. As was mentioned above, wood is a natural composite material and has been used since Kitty Hawk. Dope and fabric is also another early composite application.
I've talked with some people who are helping AB develop the A350 SRM, and one of the solutions they are working on is to use metal doublers (Al or Ti) installed with Ti Hi-Loks as a temporary repair solution for skin damage during line operations. Once the aircraft reaches heavy mx, the metal doublers will be removed and a precured patch will be installed.
As is key with any structural repair, the repair has to meet or exceed the original static strength requirements of the original part. Fatigue is less critical with composite structure, so the damage tolerance recheck requirements will, hopefully, be much more liberal.
Ptu = Ftu X Anet (not to be confused with a.net)
autothrust
Fri Aug 19, 2011 3:23 pm
Quoting bristolflyer (Reply 1):
Neither the 787 or the A350 are full composite a/c. Fighters /Bombers/ Helicopters have reached much higher CFRP percetnage.
“Faliure is not an option.”
soon7x7
Sun Aug 21, 2011 12:48 am
Quoting Autothrust (Reply 19):
The 787 is 51% CFRP's. That is enough for an aircraft of its size. Airliners are designed for higher cycles than bombers while fighters and choppers are just smaller.
Quoting PurdueAv2003 (Reply 18):
Of course you are and I would further disagree with you and myself...first composites were mud and straw bricks used in Scotland, Ireland, etc, to build homes...but we are splitting hairs here,...aren't we?...but then again, I'm wrong...I don't have any left!
Think the thread is concerned with contemporary type aircraft as in transports...again...the first used was fibreglass and polyester resin converted to to epoxy based resins. One of the first items that required composite use was the nose raydome. On the 727 wing fairings, access covers and horizontal stabs got the composites along with spoilers. Wing canoes were still alloy construction...the 737 started using composites on rudders, wing canoes, outer wing panels, spoilers, nose gear doors (also later 727's) and vertical fin caps. Carbon fibre started with the 757 and 767 series but still mostly figreglass/ kevlar. CFRP's were used on the engine cowls and spoilers. 747's have fibreglass rudder skins (nomex)with alloy ribs, elevators and h/trim tabs are fibreglass w/ alloy ribs. Belly and wing fairings are fibreglass nomex (3" thick). Wing canoes are nomex w/ outer layer of CFRP's on later models. Kruegar variable camber leading edge devices are fibreglass. The inboard highspeed aileron and low speed aileron are nomex skins over alloy ribs. 40% of the 747 is honeycomb composite, some aluminum honeycomb. All 747 wingtips are fibreglass while the main wing tips on 727,'s, 37's 57's and 67's are alloy. The 777 uses quite a bit more CFRP technology but not sure of its distribution through the airframe. I believe it is the first Boeing product to utilize a carbon tail feather grouping, floor beams, etc. While CFRP's increase use in the 777, the presense of fibreglass is still there and widely used...even on the 787. Guess in less critical areas...it is cheaper and easier to work with. Intersting is how the Kevlar seemed to be phased out as it is difficult to work with. You need some special tools and it creates some AOG repair issues. It doesn't like to be sanded, cut or drilled. In this regard, the other composites act more or less equally the same. Had enough?...I have...sorry for the rant but I like talking after 6 cups of coffee...
bikerthai
Wed Aug 24, 2011 6:46 pm
Quoting soon7x7 (Reply 20):
Kevlar is only used now where ballistics is critical (fan blade containment). Though heavier, some fiberglass and toughened epoxy can fill in the niche without issues of water absorption attributed to Kevlar.
6 cups of coffee...
Oh, i thought they were beers.
bikerthai
Users browsing this forum: 71Zulu, danman132x, ordpark and 34 guests
