Thrust
Why Is The 737 Only One Without Main Gear Doors?
Thu Aug 25, 2011 7:12 am
Basically what it says...I thought some smaller express jets like those made by Embraer might have this future, i'm not sure. But basically it seems like the 737's practice of no main gear doors and leaving the wheels exposed in the undercarriage bay appears to be unique only to that aircraft. I read somewhere that the practice saves weight and the drag effect was proven to be negligent. So my question is, why wasn't this practice kept up and universalized if they found a way to make it work?
Fly one thing; Fly it well
JRadier
RE: Why Is The 737 Only One Without Main Gear Doors?
Thu Aug 25, 2011 8:33 am
The Bombardier CRJ series as well as the Embraer ERJ-145 and EMB-170/190 series do not have main gear doors either.
For once you have tasted flight you will walk the earth with your eyes turned skywards, for there you have been and ther
wn700driver
Thu Aug 25, 2011 11:18 am
Thrust,
It's hard to see until you're right down on the ramp, but the 737's MLG are significantly smaller than what you would find on an A32x a.c (The super80s being the only other a/c in that size category carry over a design that predates the 737; they pretty much had to stick with what they had to keep their common type certificate). That may have a lot to do with it. And the fact that the 737's Main Gear bay is also a smaller, "busier" place than what you see on the 32x, and thus, not a lot of room for door actuators. I also think that being lower to the ground would complicate all that as well, but that's just my theory...
Base not your happiness on the deeds of others, for what is given can be taken away. No Hope = No Fear
PapaChuck
Thu Aug 25, 2011 12:34 pm
Just a few that come to mind:
Photo © Chris Gimmillaro
Photo © Ruud Brinks - Aerospray
Photo © Siegi N
Photo © Johannes Kreutzer
PC
[Edited 2011-08-25 05:40:55]
In-trail spacing is a team effort.
Mir
Thu Aug 25, 2011 1:20 pm
Quoting Thrust (Thread starter):
It doesn't scale up very well, particularly if you're talking about tandem gear (which rules out everything from the 757 on up).
-Mir
dlednicer
Crew
Thu Aug 25, 2011 5:19 pm
Two more:
Photo © Patric Borg
Photo © Rodrigo Carvalho
citationjet
Thu Aug 25, 2011 5:33 pm
Boeing Flown: 701,702,703;717;720;721,722;731,732,733,734,735,737,738,739;741,742,743,744,747SP;752,753;762,763;772,773.
PapaChuck
Thu Aug 25, 2011 6:05 pm
And just for fun:
Photo © Tim Samples
PC
rwessel
Thu Aug 25, 2011 6:11 pm
The 737 was conceived as a short range aircraft (the -100 had a max loaded range of only 1500nm, although that increased on the -200 to 1900nm). Proper landing gear doors would be better aerodynamically (which increases in importance as the length of your flights increases), but weigh more (which costs on every flight) and are much more complex. So on short flights, a bit of inefficiency is a reasonable tradeoff, especially given the fuel prices in the era in which the 737 was designed. So Boeing went that route, but fiddled the fairings (there's actually a rubber skirt around the bay which helps close the gap between the well and the tire) and added a hubcap, to make up for that a bit.
A nice shot from inside they bay showing the skirt:
Photo © Andy Egloff
Note that the hubcap is only on the other side of the gear, the one that faces out when retracted. It also shows how busy a place the bay is, and hints at why it would be tough to redesign the gear to use proper doors.
474218
Thu Aug 25, 2011 6:46 pm
How could everyone forget:
Photo © RAScholefield Collection
HaveBlue
Thu Aug 25, 2011 8:40 pm
I didn't realize and I am quite surprised that the Citation X doesn't have main landing gear doors. I would have thought that an aircraft designed with top speed of utmost importance would have had doors... interesting.
Here Here for Severe Clear!
contrails15
Thu Aug 25, 2011 11:09 pm
Quoting JRadier (Reply 1):
I thought the E190 does.
Giants football!!!!!!!!!!!!!!!!!!!!!!!!
pilotpip
Thu Aug 25, 2011 11:16 pm
Quoting contrails15 (Reply 11):
Nope.
I have read a number of articles that indicate that with modern designs it's more efficient to have the wheels enclosed in a fairing than pay the weight penalty for doors. Witness the Citation X if you disagree.
DMI
contrails15
Thu Aug 25, 2011 11:39 pm
Quoting pilotpip (Reply 12):
Nope.
I load them all the time and always thought they went into a bay. Learn something new everyday.
Thrust
Fri Aug 26, 2011 7:11 am
Future = feature. Sorry about that spelling mistake.
Thrust
Fri Aug 26, 2011 7:15 am
I also forgot to ask...why didn't any other commercial airliner the size of the 737 use this feature. And why don't giant jetliners use this feature?
rwessel
Fri Aug 26, 2011 7:42 am
Quoting Thrust (Reply 15):
A multi-axle bogey would make it very difficult to achieve even a partial seal around the wheel(s) as can be done with a single axle. That and larger aircraft are almost always longer range, where the aerodynamic penalty matters more. Also many of the large gears don't have a simple sideways swing for their retraction, which would make the exposed area even worse from a drag perspective.
wingscrubber
Fri Aug 26, 2011 3:23 pm
Quoting HaveBlue (Reply 10):
There are doors/fairing on the gear legs of the X, but the wheels are flush with the belly fairing when retracted. Because of the location of the hinge line and the structure in the wheel well, they can't recess deep enough to justify adding gear doors. This is probably also a carry-over from the Citation 650 which was the design starting point for the X when it was developed.
Photo © Michael Durning
Resident TechOps Troll
bonusonus
Fri Aug 26, 2011 3:32 pm
Is this something that could possibly get changed on the 737RE? I know they are trying to keep redesign limited on that a/c to save resources for the 797 project, but some type of modification to the fairing could yield some benefits for fuel burn.
yeelep
Fri Aug 26, 2011 4:34 pm
The COMAC ajr-21 would support that view as its a update of the DC/MD series.
Photo © AnHz
Photo © Weimeng
dlednicer
Crew
Fri Aug 26, 2011 5:08 pm
Two more:
Canadair CL-600 Challenger:
Photo © Shahram Sharifi - Iranian Spotters
Bombardier Challenger 300:
Photo © Maksimov Maxim - RuSpotters Team
HaveBlue
Sat Aug 27, 2011 3:10 am
Quoting Wingscrubber (Reply 17):
Thanks for the explanation, makes sense.
Viscount724
Sat Aug 27, 2011 3:41 am
Another, the Yak-40.
Photo © Anton Harisov CHELTEAM Photography
Photo © Alexander Nikolaev - RuSpotters Team
Sat Aug 27, 2011 9:17 pm
Reduce weight by less mechanical components & sequencing hurdles.
Users browsing this forum: diverted and 13 guests
