LAXDESI
B787-10 Versus A359 Economic Analysis
Tue Sep 13, 2011 9:49 pm
Based on the article below, I thought it would be fun to compare the proposed 787-10 to A359. The analysis below has many estimates, both from Airbus along with my estimates.
http://www.flightglobal.com/articles...-entry-timing-for-planned-new.html
The 787-10 variant, seen as a "relatively small statement of work", said Piasecki, would be a stretch of the 250- to 290-seat 787-9, and would offer a performance of approximately 320 passengers, twin 74,000lb (329kN) engines, with a range of 6,800nm (12,600km), slightly lower than its June estimate of 6,900nm.
The numbers below assume that the proposed B787-10 will have similar MTOW and wings as the B789. Even if the MTOW is bumped up slightly given the slightly higher(2,000 lbf) engine thrust, the overall conclusion will remain mostly unchanged.
General Specifications:
....................................B787-10......................A359
Fuselage Length..............222..........................219.5 feet
Fuselage Width.................18.9........................19.6
Wingspan........................197..........................213
Wingarea.......................3501.........................4767 sq. feet
Seats(3 class)..................320..........................314(@210 lbs. per passenger/baggage)
MTOW.......................553,000....................590,800 lbs.
MZFW........................400,000....................423,300
OEW..........................272,000....................292,000 (OEW for B789 and A359 are my estimates)
MSP...........................128,000....................131,300
Design Range..................6,800.....................8,100 nm (passenger only, and zero cargo)
Engines.........................74,000 lbf................84,000 lbf.
List Price..........................$248(?)....................$268 million
Ratois
OEW/MTOW.....................0.49...........................0.48
OEW/MZFW......................0.68...........................0.71
MZFW/MTOW....................0.72...........................0.67
MTOW/Wingarea............158............................124
MTOW/Thrust....................3.73...........................3.52
For a 4,000nm trip(at MTOW), as per my model:
The B787-10 burns about 600 gallons more, while carrying 6 more passengers. The difference in cargo payload is about 5,000 lbs. in favor of A359. It seems to me that both are well matched in operating cash flow for this mission length. B787-10 does not seem to have any advantage over A359 for short and medium haul routes.
The much larger wing of A359 is a major factor in the superior performance of A359, as evidenced by lower overall fuel burn for the above mission.
A359 should turn out to be an excellent replacement for both A333 and B77E with larger capacity and lower fuel costs. A359 can replace both A333 and B77E, whereas B787-10 cannot replace 77E as it falls short on both capacity and range.
I am not too excited about 787-10, but it will have fleet commonality as a major selling point, along with my expectation of a lower selling price.
Arniepie
RE: B787-10 Versus A359 Economic Analysis
Wed Sep 14, 2011 9:25 am
Maybe I don't have the latest figures, but for seating I have some other numbers.
In a typical 3-class configuration the A350 should hold 314 people, a 787-10 however only holds 290 iso 320 in
a 3 class config.
So with the rest of your numbers that would mean that the 359 holds 24 more people and/or 5000lbs more freight
at slightly lower fuelburn and 15% more range.
Also didn't Boeing just not too long ago stated that the 787-10 would probably have to wait for a long time to
materialize, the 777NG will come first.
[edit post]
AustrianZRH
As always, thanks for the analysis! I find it astonishing that the 6800 nm airplane doesn't have the edge over the 8100 nm airplane at a 4000 nm mission  Wow! . But that probably comes from it being a straight stretch vs the base model...
WARNING! The post above should be taken with a grain of salt! Furthermore, it may be slightly biased towards A.
LAXDESI
Wed Sep 14, 2011 7:02 pm
Quoting AustrianZRH (Reply 2):
As always, thanks for the analysis! I find it astonishing that the 6800 nm airplane doesn't have the edge over the 8100 nm airplane at a 4000 nm mission . But that probably comes from it being a straight stretch vs the base model...
As per my model, B787-10 has lower mission fuel burn than A359 below 1,700 nm mission, which is about 4-5 hours of flight time. For the right price, B787-10 may be more attractive to some airlines than A359 on regional routes.
roseflyer
Wed Sep 14, 2011 7:51 pm
Interesting comparison. I'm curious about your model and surprised by the result. The only factor among your general specifications that appears to make the A359 appear to burn less fuel is wing area because every other factor should make it burn less. I'm not an aerodynamic specialist, so I don't know what the impact of wing loading is on overall drag, but to me it seems like the lower overall weight of the 787 should be in its favor and that it would outweigh aerodynamic factors. Could you explain that a little further?
In general, a smaller plane will burn less fuel for flights within the majority of its operating envelope. Where its operating costs and efficiency go down is when it approaches its MTOW and the limits of its range/capacity. 4000 miles should comfortably be in the 787-10 range since that is a pretty standard transatlantic flight. The A359 should be able to take more cargo and fly further so I would assume at a certain range that it would be more efficient, but 1700 miles seems quite low. I'd expect the larger plane to be able to generate more revenue, but on a basis of fuel burn, I'd expect the smaller plane to almost always burn less fuel.
LAXDESI
Wed Sep 14, 2011 9:23 pm
Quoting RoseFlyer (Reply 4):
I too was surprised by the result, but it is entirely reasonable if you compare the B772ER to B772LR. I have not crunched the numbers, but I remember reading that the heavier B772L, with larger wings, has better operating economics than B772ER beyond 2,000nm(?). Perhaps someone in the know can elaborate.
mffoda
Wed Sep 14, 2011 10:50 pm
Quoting Arniepie (Reply 1):
a 3 class config.
I'm Surprised you did not answer his question? He is comparing the 787-9 to the the A359 not the 787-10??...
harder than woodpecker lips...
tdscanuck
Thu Sep 15, 2011 2:51 am
Wing loading tells you (among other things) what Cl must be in cruise. Higher wing loading means you need higher Cl. Induced drag goes by Cl^2, so higher wing loading means higher induced drag. Depending on the magnitude of the changes, this can overshadow the weight advantage.
Tom.
LAXDESI
Thu Sep 15, 2011 3:18 am
Quoting tdscanuck (Reply 7):
Thanks for an excellent technical explanation, and welcome to my RU list.
Quoting mffoda (Reply 6):
I am not sure what he was getting at. I do have a thread where I compare A359 to B789.
B789 Versus A359 Analysis (by LAXDESI May 20 2011 in Tech Ops)
Arniepie
Thu Sep 15, 2011 9:41 am
Quoting LAXDESI (Reply 8):
I was just wondering where you got your seating numbers from, I cannot realy find anything quoted by
Boeing that says 320 seats in 3 classes, the best I could come up with is between 290 and max. 310
in 3 class config.
Not that I'm doubting your sources but for starters, I cannot open your link and after searching throgh
flightglobal ,I cannot really find any other numbers than those quoted by Udvar H. wich are about the
same numbers or Jim Albaugh at Boeing quoting 300 seats for the 787-10, again between 290 and 310.
Not that it is that important but it leaves me wondering if the 3-class 320 seatcount isn't a tad optimistic
or maybe not a real comparison with the 359, seeing that they only take typical 3 class seatcount as a
standard and not a min-max range for 3 class seating layout (like Boeing usually does).
As far as we can know, 314 seats on the A359 might as well mean ranging from 294 to 334 seats in a
3 class config if we use the same parameters to make up seating arrangement that boeing is using.
[edit post]
LAXDESI
Thu Sep 15, 2011 3:27 pm
Quoting Arniepie (Reply 9):
flightglobal
Looks like the article has been removed. An article by Jon on FG blog suggests 330 seats for B787-10, which should make the 787-10 more competitive against A359 on short and medium haul routes.
The length of B787-10 relative to A359 in my OP accounts for one row difference in 9-abreast layout. If 787-10 ends up with 330 seats, then I will have to tweak my numbers a little bit.
Arniepie
Thu Sep 15, 2011 4:52 pm
Quoting LAXDESI (Reply 10):
Interesting study nonetheless,
After looking the internetoranium for a while, one thing seems conclusive, it's final design
is not yet set, Boeing and Udvar are mentioning 310 seats typical in a 3 class config most of the time.
Specifically after talking with key customers in the middle east from 2007 and 2008 forward, a 787-10 with
310 passengers seems to be the general plan, in the far future, that is.
[Edited 2011-09-15 09:57:17]
[edit post]
Users browsing this forum: Apprentice and 1 guest
