Chamonix
Pros And Cons Of Speed Vs Vector Stabilty
Tue Sep 20, 2011 10:50 pm
Tom tdscanuck mentioned this:
"Airbus does primarily flight path vector stability (reduced speed stability) while Boeing does a blend that favours speed stability over flight path vector stability."
What are the pros and cons of speed vs vector stabilty?
Many thanks!
tdscanuck
RE: Pros And Cons Of Speed Vs Vector Stabilty
Wed Sep 21, 2011 2:57 am
Quoting Chamonix (Thread starter):
Vector stability is closer to the ideal of what the pilot really wants to do...control where the airplane is going. However, you can't do it without heavily augmented flight controls (basically, FBW).
As a result of the above, most planes have natural speed stability. This is what pilots are used to during training so, by the time they get up to sophisticated aircraft that don't necessarily have to exhibit speed stability, they're accustomed to aircraft with speed stability. Artificial speed stability in FBW makes the plane's behavior familiar and intuitive.
Neither is wrong, they're just different.
Tom.
rcair1
Crew
Thu Sep 22, 2011 3:59 pm
Quoting tdscanuck (Reply 1):
Maybe another way to ask the question is:
- is there any credible data (not bias) that would indicate one or the other has led to more/less incidents?
Might be an interesting research project.
rcair1
Chamonix
Thu Sep 22, 2011 6:40 pm
Quoting rcair1 (Reply 2):
Excellent idea!
The topic is under-exposed and under-rated yet over-riding in terms safety and technology.
Google draws a big blank.
I like to compare the two using cars as an analogy.
Vector stability makes me think of ASR and ESP control stabilty systems that that neutralise over-steer and under-steer as well adjusting the active suspension ( AutoTrim in cars).
Speed stabilty gives me the idea of raw performance and power sliding that is more reactive that produces more NVH (Noise,Vibration,Harshness) at the expense of comfort.
I remember comparing two MB 560 SELs in back-to-back testing.
One had all the wizardry,the other was plain vanilla.
The difference was scary in the wet!
[Edited 2011-09-22 11:40:22]
[Edited 2011-09-22 11:40:49]
Thu Sep 22, 2011 11:14 pm
Quoting Chamonix (Reply 3):
Not really. That is, both philosophies will give you ridiculously safe operation, as evidenced by the negligible accident rates.
It's not like we have a statistically significant number of similar crashes to draw conclusions from. The only conclusion is that either way commercial aviation is very safe.
Apples and oranges. In cars all that stability stuff is used at the edge of the envelope, a place where airliners don't venture unless something has gone really wrong.
tdscanuck
Fri Sep 23, 2011 1:42 pm
Not really. "Vector stability" is most often implemented in a pitch control law called "C*", which goes back at least to the early 70's. It's got a long record in military aircraft where, to my knowledge, it's never been indicted in an incident.
You need to know what to search for...try "C* flight control law" as a starting search string.
There's a good overview paper of this particular control law in civil aircraft out of Cranfield University:
https://dspace.lib.cranfield.ac.uk/handle/1826/186
ASR/ESP are much more like envelope protection than they'e like basic axis flight control laws.
Tom.
RaginMav
Fri Sep 23, 2011 7:07 pm
Well I guess I'm the one that has to say it:
The Flight Path Vector stability of modern Airbus aircraft contributed to the crash of AF447. If the wheel/stick/whatever got 'heavy' in the PF's hands, perhaps there wouldn't have been "aft inputs" on the wheel/stick/whatever all the way to impact.
Flame away.
rwessel
Fri Sep 23, 2011 7:33 pm
Quoting RaginMav (Reply 6):
Stick forces are normally* quite light in a stall - minimal aerodynamic load, after all.
*Assuming a non-accelerated stall
RaginMav
Fri Sep 23, 2011 7:39 pm
Quoting rwessel (Reply 7):
Are you referring to an Airbus aircraft? And what are those forces like in the moments leading up to the stall?
[Edited 2011-09-23 12:46:07]
Fri Sep 23, 2011 11:46 pm
Quoting RaginMav (Reply 8):
I think the point rwessel was making was that if you have feedback to the controls, it's not like a stall will give you high stick forces.
On an Airbus, it is just spring loaded anyway right?
First off, the investigation is not complete. Having said that, Airbus pilots should be trained and comfortable in the characteristics of their aircraft. If FPV stability contributed, it is because they made several errors. FPV stability as a concept does not seem flawed to me based on AF447.
tdscanuck
Sat Sep 24, 2011 12:51 am
Not in the way you're describing it.
The PF was pulling full aft stick...that takes a lot of force. He had to know what he was doing (although he may not have known why). Exactly the same thing would have happened in a non-C* airplane if you held full aft stick/yoke.
Tom.
rwessel
Sat Sep 24, 2011 1:09 am
I meant in general, particularly in aircraft that actually have some force feedback from the control surfaces to the stick, since that's what would be the "natural" feel.
In most aircraft, a low-speed stall will have relatively low stick forces leading up to the stall, but will usually require a fair bit of stick deflection. That's not universally true, in some aircraft, if you're trimmed for a fairly high speed, you need some force to pull the stick back far enough to stall, but it's not usually all that much, certainly a lot less than the opposite (the amount of push you need to fly at high speed when trimmed for low speed).
In the AF447 case, and assuming they were flying an aircraft with conventional controls (the A330 provides no feedback from the control surfaces, and handles trim automatically), they would not have been trimmed for a particularly high speed anyway. Their *true* airspeed and Mach number were high, but their *indicated* airspeed, which is what mostly affects your control loads (and trim), was not.
All that's relative of course - if you're flying a B-29 (a 737 sized aircraft with *unpowered* controls), the stick forces are high no matter what you're doing.
And aircraft with a stick pusher will artificially increase the stick load as you approach the stall. An interesting question is if a conventional stick pusher would have helped – basically those depend on the same alpha vanes that the stall warning runs on. That went off for something like 50s before the AF447 before the airspeed dropped below the cutoff limit. And if they were willing to ignore that, would they not have ignored the pusher as well?
tdscanuck
Sat Sep 24, 2011 4:21 am
Quoting rwessel (Reply 11):
I'm not aware of any modern widebody with force feedback from the surfaces to the stick...they all use irreversible hydraulic controls, or electric actuators (which are inherently irreversible). Any feel you get on a widebody is going to be artificial, just like an A330.
Tom.
RaginMav
Sat Sep 24, 2011 3:37 pm
I agree that FPV stability is not inherently wrong, but it is unquestionably different. I stand by my statement that it contributed to the crash. rwessel makes this statement:
and that is exactly my point. I am not a fan of aerodynamic cues and trim movements being masked. The Falcon 7x, for all it's splendor, is guilty of the same thing.
Good point. It's not like the aircraft was trimmed for 300+ KIAS and then that speed got cut in half during their climb. Nonetheless, masked trim movement and FPV stability led to a situation where the airspeed indicator was, obviously, by far the easiest way to see their low speed state. And of course the investigation thus far has indicated unreliable airspeed information.
This brings up a slight variation of my theme: no direct indication of AoA available on the flight deck. Come on, governing authorities of the world, make this a requirement!!! I don't know who led the charge for the US Navy to adopt the AoA indicator the way they have, but I would imagine he would roll over in his grave if he knew modern airliners are not equipped with such a simple system.
Sorry for slightly highjacking the thread, so back on topic for me.
FPV stability is an intriguing concept. I haven't had the fortune of doing this yet, but some day i look forward to putting the HUD's FPVon the touchdown zone of a runway, and-voila!-stabilized approach, at least in a flight path sense. If a pilot is astute enough to look, he or she could see how many degrees away from optimum glide path they are, and use that info to make more timely, and better informed corrections, or go-around decisions. That certainly is an advancement in safety.
tdscanuck
Sat Sep 24, 2011 3:50 pm
Quoting RaginMav (Reply 13):
There may be something to trim masking, but no modern widebody airliner provides aerodynamic feedback from the control surfaces regardless of who made it.
It's in two places...the PLI (pitch limit indicator) and the barberpole on the speedtape. These are actually *more* useful AoA measures since AoA, as an absolute value, doesn't tell you much. It's only when coupled with airspeed and configuration that you get what you really want (how close to stalling am I?)...which is exactly what the PLI (how much more pitch do I have available) and speed tape (how much slower can I get) tell you.
They are...most airlines just don't take the option.
It's awesome.
Tom.
Sun Sep 25, 2011 12:53 am
Different, sure. But it is hardly new and groundbreaking anymore. It's been around for over a quarter century in service. Any pilot who flies a FBW Airbus should be well aware of the idiosyncrasies of his aircraft.
Users browsing this forum: skyhawkmatthew, StereoTechque and 1 guest
