LY777
LAX-CDG Route Planning
Thu Sep 22, 2011 9:31 am
Why do CDG flights to LAX (or vice-cersa) often fly over Greenland, ie a "Polar" route.
I know this is to save time (shorter route), but when the route is sometimes more to the South, the flight is finally not longer.
Your thoughts?
wilco737
Thu Sep 22, 2011 9:34 am
Quoting LY777 (Thread starter):
It is all about wind. Over the north atlantic you have strong jetstreams. On the westbound part you fly against the wind, so you fly a detour to avoid the headwinds, but the flight is still shorter (flight time wise). The distance maybe longer, but the shorter the flight time, the less fuel you use.
On the eastbound flight you want to use the strong winds as tailwinds, so you fly a route where you have strong tailwinds. Make the flight shorter (flight time wise)... So a detour in aviation can mean reducing flight time - because of the winds.
wilco737
LY777
Thu Sep 22, 2011 10:14 am
Thanks, interesting.
So, CDG-LAX route is "Polar" whereas LAX-CDG is "Regular"
So, the "Polar" route is longer (in term of distance). How much longer compared to the "regular" route?
wilco737
Thu Sep 22, 2011 10:17 am
Quoting LY777 (Reply 2):
I wouldn't call it polar route. It is further to the north. Polar is when you are very close to the North Pole.
You cannot say in general how much longer it will be. It depends on the wind. So it changes everyday again.
wilco737
LY777
Thu Sep 22, 2011 10:21 am
Thanks Wilco for the info!
Thu Sep 22, 2011 10:55 am
To actually fly over the North Pole, you'd have to find a flight like DXB-SFO/LAX and be lucky. My friend flew DXB-LAX and the captain announced that they flew within 3 miles of the North Pole.
[Edited 2011-09-22 03:56:08]
wilco737
Thu Sep 22, 2011 10:58 am
Quoting NZ107 (Reply 5):
Yes. Or like LH Cargo did from Germany or GOT to FAI. They usually flew close or over the North Pole.
wilco737
leftyboarder
Thu Sep 22, 2011 10:59 am
According to FAA, a route is polar if it is north of 78 degrees north. Since that is further north of almost anywhere in N. America or even Greenland, I doubt AF ventures into this territory. In fact, are there any polar routes from Europe to N. America? Did the SVO-SEA flight go that north?
Thu Sep 22, 2011 11:06 am
Quoting wilco737 (Reply 6):
Unfortunately, a lot of us here won't have a chance to fly LH Cargo!
wilco737
Thu Sep 22, 2011 11:08 am
Quoting NZ107 (Reply 8):
True. And these days they don't fly to FAI anymore, so they don't use the polar route anymore anyway. But leftyboarder asked:
Quoting leftyboarder (Reply 7):
So I said that LH cargo used to... But not anymore.
My furthest north was 76°N on a flight from FRA to SEA due to the strong headwinds.
wilco737
blueflyer
RE: LAX-CDG Route Planning
Thu Sep 22, 2011 3:10 pm
If it isn't a polar route, Condor's FRA-ANC has to come very close.
MAGag
bonusonus
Thu Sep 22, 2011 8:14 pm
Expanding on this, what are the main polar passenger routes?
DXB-LAX/SFO was mentioned.
Also, are there any that go this close to the south pole? I know that is ETOPS no-go zone, but could a quad do it?
wilco737
Thu Sep 22, 2011 8:35 pm
Quoting bonusonus (Reply 11):
The flight SYD-EZE is flown by 744 and goes rather far south... But not near the South Pole:
http://www.gcmap.com/mapui?P=syd-eze&MS=wls&DU=mi
wilco737
Viscount724
Thu Sep 22, 2011 10:59 pm
Quoting blueflyer (Reply 10):
If they use the great circle route, the closest point to the Pole is about 400 nm.
Thu Sep 22, 2011 11:10 pm
JFK-HKG. You typically fly straight north from JFK, skirt the actual pole, then straight south to HKG.
EWR-SIN.
There aren't really any "south polar routes" because the geography of the destinations doesn't require it.
sunrisevalley
Tue Sep 27, 2011 2:23 pm
Quoting Starlionblue (Reply 14):
also there are no alternate landing facilities
and
Quoting wilco737 (Reply 12):
I believe the Australian regulator does not allow flights south of 60 degrees although I saw a flight track for a SYD-EZE flight that went to about 62 degrees south.
Users browsing this forum: No registered users and 21 guests
