mpvincent
Impact Of Gradient On Takeoff And Landing B777
Sat Sep 24, 2011 5:05 am
Hi there
Does anyone have a rough equation I could use to estimate the improvement in takeoff payload of a b777 200er off a runway that is descending and ascending by a certain gradient? I was thinking if I used the Boeing curves from airport manual to work out max tow and then used some relationship between gradient acceleration and velocity to work out how much more speed I would have with a gradient and then back calc to give implied payload?
Unless someone has some take off curves for the 200er varying by gradient?
Thanks.
mandala499
RE: Impact Of Gradient On Takeoff And Landing B777
Sun Sep 25, 2011 5:45 pm
Quoting mpvincent (Thread starter):
Hmmm... that would be a bit more difficult than just looking at some dispatch tables from the FCOM.
Get the runway length, then put in gradient correction and wind correction to get the "corrected runway length", pull that runway length onto a take off vs TOW table and get the max number for that corrected length.
When we're talking about runway length, the TOW is primary weight limit... then, you can calculate the payload from that (if you know how much fuel is on board).
You're in luck in that it's a sunday today and I just did this for fun (    ), so take it as is and no implications that it is correct (but I did take the numbers from a 777-200ER FCOM performance dispatch section).
http://www.globalsim.web.id/publicservice/777GradientCorrectionNoWindTakeOff.jpg
Gradients are in percent... + means upslope, - means downslope.
Enjoy,
Mandala499
mpvincent
Wed Sep 28, 2011 2:43 am
Thanks very much.
Users browsing this forum: Dt91c, gloom, LAX772LR, TOGA10 and 20 guests
