justloveplanes
Airline Meals And Food Science
Tue Oct 18, 2011 12:21 pm
Travelling a lot, I am wondering what if any kinds of preservatives and other processing techniques are applied to airline foods?
The don't usally list that on the menus (i.e. caution, contains MSG...). Wasn't aware till recently that one common technique is waxing used for groceries.....
tdscanuck
RE: Airline Meals And Food Science
Tue Oct 18, 2011 5:54 pm
Quoting justloveplanes (Thread starter):
I'm not aware of any special processing done on the made-to-order trays. The pre-bagged stuff (like cookies) probably has the usual suspects...trans fats, stabilizers, preservatives, etc.
That's a general produce technique that you'll find in most grocery stores, nothing to do with airlines in particular.
Tom.
flipdewaf
Tue Oct 18, 2011 8:48 pm
I work as an innovation engineer within the food industry and while I haven't worked directly with the airlines I work within new product development with people who have. I'm sure there are many things in the foods hat you wouldn't know about because they are not classed as ingredients but as 'processing agents' so I don't think that even many of the catering agencies would necessarily be able to tell you.
It's worth remembering that once thawed, the meals will have to survive no longer than the flight itself.
Fred
justloveplanes
Tue Oct 18, 2011 9:07 pm
Quoting flipdewaf (Reply 2):
My curiosity got piqued recently on a flight with CO where they served Kung Pao Shrimp in B class that was quite nice and crunchy. This is hard to do even in a land restaurant, so wondering how they pulled this off with reheated food.
JAGflyer
Wed Oct 19, 2011 1:42 am
I heard that airline food has to be spiced/seasoned more than food that would be served on the ground as one's sense of taste is worse at altitude. I can attest to things tasting different than they do on the ground (ie. a snack brought from home).
Support the beer and soda can industry, your recycle old airplanes!
Wed Oct 19, 2011 5:37 pm
Quoting JAGflyer (Reply 4):
What contributes to variation of Taste at Altitude.......
canoecarrier
Wed Oct 19, 2011 6:29 pm
I'd heard this as well. There's research showing that people lose some of their sense of taste when they hear the white noise inside an aircraft's cabin. For that reason, airline meals tend to be saltier or sweeter than meals served on the ground. LH even took their meals to a low pressure chamber to test the effects of cabin pressure on food taste. Basically, low humidity in the cabin effects the ability of the nose to smell the food, which is around 80% of what makes up what we taste.
Although it does not directly answer the OPs question some time ago in a different thread someone linked to a youtube video showing how airline meals were prepared. I believe it was this one.
http://www.youtube.com/watch?v=alh_2xg5GWo&feature=related
The beatings will continue until morale improves
JAGflyer
Thu Oct 20, 2011 11:33 pm
Quoting canoecarrier (Reply 6):
The show "How it's Made" is a Canadian made TV show that shows the production of different things in Canada (mainly Quebec) and the US. This version is dubbed for the UK but I can still tell it is filmed at Cara Foods in Montreal. You can see the AC salt/pepper shakers towards the end. I'm guessing this was filmed in 2003-2005 (Most of the older episodes are filmed in Quebec).
[Edited 2011-10-20 16:39:29]
justloveplanes
Fri Oct 21, 2011 2:02 am
I feel extra dehydrated or just have a long time digesting what I eat on an airplane sometimes. Maybe it's the extra salt combined with some lingering altitude effect / jet lag. I was thinking it might be preservatives used on the food.
Fri Oct 21, 2011 3:27 am
You get dehydrated on the plane anyway due to the low humidity.
flybaurlax
Fri Oct 21, 2011 4:42 am
Quoting HAWK21M (Reply 5):
The International Space Station has a cabin altitude of roughly 6000 feet, hence Tabasco sauce is one of the most used items for each meal. I do believe that the food is prepped with this altitude factor in mind, however the astronauts still use Tabasco almost with anything they eat up there.
Boilerup! Go Purdue!
Northwest727
Fri Oct 21, 2011 10:49 am
Quoting flybaurlax (Reply 10):
On a side note (and questions), I've been told that the military MRE's have little to no fiber in them, as well as other chemical changes, to limit waste and to "block a soldier up" (you don't want to have to do #2 when you are being shot at). Is this the case with the ISS/astronaut food to reduce waste?
ha763
Fri Oct 21, 2011 4:43 pm
The vast majority of the food for airline meals are made within 24 hours or less of consumption and then chilled or frozen. There is no need for any preservatives, other than what was already in the ingredients.
Sat Oct 22, 2011 9:26 am
Thats why Drinking water is a good option in flight....
On the topic of taste at altitude.....Noticed food does taste a little less tasty,but then I presumed it was the reheated variety thats why.
ajd1992
Sat Oct 22, 2011 12:06 pm
Quoting Northwest727 (Reply 11):
What happens when you need a dump though and you're constipated? Take laxatives?
I can see the reasoning but dropping bricks can't be very nice on a semi-permanent basis.
Northwest727
Sun Oct 23, 2011 4:16 pm
Quoting ajd1992 (Reply 14):
The MRE's come with chewing gum that supposedly alleviates the constipating effects of the food.
Mon Oct 24, 2011 11:33 am
Quoting HAWK21M (Reply 13):
Just to clarify.....I meant Bottled/packaged water & not from the Potable system of the Aircraft.....Those in the field will know what I mean
Users browsing this forum: gloom and 1 guest
