aerotech777
Static Takeoff Vs Rolling Takeoff
Thu Oct 20, 2011 5:42 pm
Hi,
Takeoff procedure 1: Engines at idle and brakes on. You release the brakes and then you advance the throttles to an intermediate thrust setting (40%N1 or 50%N1, EPR?). Once you reach this thrust on all engines, you apply takeoff thrust.
Takeoff procedure 2: With the brakes on and engines at idle you advance the throttles to an intermediate thrust setting. Once you reach this thrust on all engines, you release the brakes and then you apply takeoff thrust.
Are both takeoff procedures (1&2) considered static takeoff?
Reading from some posts, it seems the rolling takeoff is the recommended procedure. Is this true? Or is it up to the crew to decide between the rolling and the static takeoff?
Is it recommended to apply the 2 steps takeoff procedure (intermediate thrust: 40/50 N, then takeoff thrust) on both types of takeoff procedure?
When and how often the static takeoff is used (besides short runway)?
Feedback appreciated.
mandala499
RE: Static Takeoff Vs Rolling Takeoff
Thu Oct 20, 2011 6:21 pm
#1 takes less time... and smoother (for pax)
#2 takes less distance... and not good on a "low fuel take off" (for ferrying).
Quoting aerotech777 (Thread starter):
As often as when you need every available inch of runway !
Lemmy
Thu Oct 20, 2011 7:34 pm
Quoting mandala499 (Reply 1):
Why is that? Because it uses more fuel, or maybe because the acceleration makes what little fuel you have "slosh" and uncover a fuel pump? Just guessing.
I am a patient boy ...
mandala499
Thu Oct 20, 2011 8:14 pm
Quoting Lemmy (Reply 2):
Just guessing.
Correct guess... on the FCTM I got for the 732, it specifies that as a reason...
akiss20
Thu Oct 20, 2011 10:22 pm
It can be up to the crew, but it is also subject to SOPs of the airline and restrictions by the airframer or the engine manufacturer. Engine companies use rolling T/O procedures to mitigate inlet distortion from crosswinds which can destabilize the engine
Change will not come if we wait for some other person or some other time. We are the ones we've been waiting for. We are
Longhornmaniac
Thu Oct 20, 2011 10:54 pm
So I think this is probably an appropriate question to put in here:
What are the actual performance gains on a static takeoff vs. rolling? How many feet of improvement can you expect to see on a given aircraft (meaning if you have experience with a certain aircraft, what is your first hand experience)? I'm aware this is always dependent on load and any number of other factors like wind, but all other things being equal, what sort of gains would one see?
Cameron
Cameron
tdscanuck
Thu Oct 20, 2011 11:13 pm
Quoting Longhornmaniac (Reply 5):
As a rule of thumb, on a rolling takeoff you will basically give up the distance between where you advanced the engines to takeoff thrust. You need to get to the same speed either way and you use comparatively little distance during the low speed roll...the vast majority of the takeoff distance will be determined by your time at takeoff thrust. If you are 500' farther down the runway when you hit full thrust, you're going to give up about 500' compared to the static equivalent.
Tom.
Mir
Fri Oct 21, 2011 4:18 am
Not really. A true static takeoff is when you hold the brakes, apply takeoff thrust (even if you stop at an intermediate position to verify things are working properly, you'll still hold the brakes until you get the thrust all the way up), then release the brakes (gently, to avoid being slammed back into your seat) and off you go.
We do it whenever runway length is an issue. If I'm calculating I need more than two-thirds of the runway for takeoff, I'll probably be doing a static takeoff, particularly if the runway is wet.
A rolling takeoff (similar to your scenario #1) is my preferred option for takeoff, though.
-Mir
foxxray
Fri Oct 21, 2011 9:06 pm
Rolling takeoff are mostly done on request from the atc (because of an aircraft on short final for example) or just to gain time !
CosmicCruiser
Fri Oct 21, 2011 9:36 pm
We used to fly a noise abatement t/o in the 727 in Long Beach, I believe, that required a static t/o but is the only time I've ever done it. I would think if your t/o requires a static t/o for other than what I just posted I'd reevaluate that t/o.  Wow!
KELPkid
Fri Oct 21, 2011 10:09 pm
Quoting Mir (Reply 7):
I know that there are fighters whose brakes can't hold the bird back with full thrust (i.e. you will go down the runway, tires locked but smoking). Wonder if there are airliners (well, other than Concorde  ) that also fall into this boat...
BoeingGuy
Fri Oct 21, 2011 10:33 pm
Quoting CosmicCruiser (Reply 9):
Don't they often do static takeoffs at SNA? I have experienced a few rolling takeoffs there, but I thought it's still mostly static run-ups.
aerotech777
Mon Oct 24, 2011 4:09 pm
Thank you for your feedback.
It seems that Boeing is saying there is negligible difference (less than 50ft) regarding the takeoff roll between the standing takeoff and the rolling takeoff.
If Boeing statement is true and the difference is 50 ft between the static and rolling takeoff, how much this distance will reduce the RTOW or the noise (noise abatement takeoff)?
airbuster
Fri Nov 04, 2011 11:23 pm
For my aircraft static takeoff when:
LVP (rvr 400m or less)
ATS INOP
performance limited weight and actual weight within 300kg
Icing conditions
Slippery/contaminated rwy
Also all TL tables are based on static to.
[Edited 2011-11-04 16:25:33]
FLY FOKKER JET LINE!
Sat Nov 05, 2011 8:55 pm
Wouldn't a Static T/O assist in case EPR/N1 does not register & avoid a higher speed reject......Just wondering.....
Arniepie
Sat Nov 05, 2011 11:57 pm
I remember on another site a pilot quoting from the 737-700FCOM,
"A rolling takeoff is recommended for setting takeoff thrust. It
expedites takeoff and reduces risk of foreign object damage or
engine surge/stall due to a crosswind. The change in takeoff roll
due to the rolling takeoff procedure is negligible when compared to
a standing takeoff."
"Allowing the engines to stabilize for more than approximately 2
seconds prior to advancing thrust levers to takeoff thrust may
adversely affect rolling takeoff distance."
The risk of FoD with static take-off is not negligable it seems;
http://www.aaib.gov.uk/cms_resources...ng%20737-436,%20G-DOCT%2006-07.pdf
[edit post]
AT
Sun Nov 06, 2011 5:12 pm
plus, are there any break heating issues?
I would assume that in static take offs you have more heat generated in the brakes?
XXXX10
Sun Nov 06, 2011 11:55 pm
Are there any situations where you would apply full take-off power before releasing the breaks?
If so I would imagine the Airbus departures from LCY would be a possible.
bonusonus
Tue Nov 08, 2011 12:33 am
Quoting AT (Reply 16):
I don't think this will generate significant, if any heat in the brakes. Heat in the brakes is caused by the conversion of kinetic energy (from aircraft motion) into heat energy. If the aircraft is stopped and the brakes are on, the brake pads arent generating any heat, they are simply holding the wheels in place.
aerotech777
Tue Nov 08, 2011 2:22 am
Hi,
How often (approximate percentage if possible) do you use static takeoff versus rolling takeoff?
Zkpilot
Wed Nov 09, 2011 6:30 am
I'd say 75% of the time rolling takeoffs, 20% position on runway with brakes then release with throttle, 5% static/power on brakes.
Of that 75% figure about 50/50 in terms of throttles advanced to intermediate setting just prior to actually being on centerline, othertimes just advancing. It does help with expediting a departure, saves on fuel and doesn't really carry any significant impact on safety (as others have mentioned it has some safety benefits also).
57 types. 38 countries. 24 airlines.
ual777
Thu Nov 10, 2011 2:38 pm
Ive never done one in the jet. If the numbers look tight, just increase the thrust mode.
It is always darkest before the sun comes up.
Users browsing this forum: sailsman1 and 2 guests
