c5load
Customs Procedures For Aircraft
Sun Oct 23, 2011 2:06 pm
Not sure if this has been discussed before, I couldnt' find anything so Mods if it has please delete.
When we come in on the C-5 from an international base like ETAR, we are not allowed to deplane nor open any doors except to deplane the scanner until CBP has cleared both the crew and the airplane. Yet when I was on a flight from FRA-ATL a while back, we deplaned as normal and made our way to Customs. Does the airplane and/or cargo itself have to be cleared/checked before anything happens? Do pax not see it or do they deplane before Customs boards?
"But this airplane has 4 engines, it's an entirely different kind of flying! Altogether"
rfields5421
RE: Customs Procedures For Aircraft
Sun Oct 23, 2011 2:50 pm
The procedure depends upon the staffing and facilities at the arrival airport.
Commercial airports with full CBP staffs and separatation capability - pax deplane quickly and go into a sterile area to clear Customs and Immigration.
Airports without full CBP staffs and separation capability, like military airports, pax and crew have to wait until CBP arrives at the aircraft.
Travis AFB and McGuire AFB used to have full CBP separation facilities like a commercial airport for arriving passengers, back when almost all military would depart/ arrive at those airports. As much as 8 to 12 full DC-8/B707 flights per day (1,500 to 2,500 pax daily).
I don't think the military maintains that level of expense any longer.
SAAFNAV
Sun Oct 23, 2011 7:28 pm
Quoting c5load (Thread starter):
scanner
Sorry, I know this is off-topic, but I read this in a C-5 document..
What is the scanner position? What does he do?
Erich
On-board Direction Consultant
c5load
Sun Oct 23, 2011 9:01 pm
Quoting SAAFNAV (Reply 2):
What the scanner does is conduct outside preflight inspections, clears the aircraft for ground clearance prior to taxi and boards the airplane. He watches the engines during start for any abnormalities, then once boarded conducts an interior inspection for any abnormalities. After block in, he deplanes first and conducts any clearance checks prior to engine shutdown. In flight, if there is a mx issue or something out of the norm, he goes and checks what may be wrong and reports back to the pilot. That's it in a nutshell.
wn700driver
Mon Oct 24, 2011 12:10 am
Quoting c5load (Reply 3):
Wow, that actually sounds like the best job in the USAF.
Base not your happiness on the deeds of others, for what is given can be taken away. No Hope = No Fear
c5load
Mon Oct 24, 2011 2:15 am
Quoting wn700driver (Reply 4):
Well that's just a few things, scanners are still flight engineers they just rotate between being at the panel and pulling scanner duty.
rolypolyman
Mon Oct 24, 2011 2:34 am
I don't know about that... back in 1994 I flew from FRA to MBA and back again two months later, on C-5s each way, and we were never met by customs either way or had any kind of arrival screening. That includes during the refueling stop at CAI, where we were milling about next to the taxis while they loaded fuel. I don't know where the ball was dropped or if that's business as usual, but that's what I saw.
SAAFNAV
Mon Oct 24, 2011 4:29 am
Oh ok thanks!
We just use a loadmaster for that duties.
Erich
KELPkid
Mon Oct 24, 2011 5:34 am
I can't speak about commercial flights, because I don't know, but in GA realms, you are required to taxi the aircraft to the "Customs circle", and you are not allowed to exit the aircraft until US Customs says it's okay to do so. And I have flown into ELP when we've gotten "lost" on the ramp (our little Cessna towered over by cargo Convairs, DC-3's and 727s). I remember calling the tower once and requesting a landline to Customs because we had been baking in the sun for an hour, hidden by bigger birds (pre cell-phone days).
wn700driver
Tue Oct 25, 2011 2:06 am
Quoting c5load (Reply 5):
Still sounds awesome. Especially considering it's the only place (USAF) where you can fly on a FRED.
