lke2fly
Steering An Airliner
Sat Oct 29, 2011 4:20 am
My question is while a airliner heads down the runway at full speed before take off at what point does the rudders take over the tiller for control of the airplane in steering straight? Like wise on landing. Thank you
Mir
RE: Steering An Airliner
Sat Oct 29, 2011 4:35 am
The tiller isn't used at all once the airplane is lined up with the runway for takeoff - the rudder pedals offer enough nose wheel control (and, at higher speeds, rudder control) to keep it on centerline. Same thing during landing, until you're slowed down and ready to turn off the runway - then you start using the tiller.
-Mir
roseflyer
Sat Oct 29, 2011 4:55 am
The nose wheel has about eight degrees of travel with using the rudder pedals. This keeps the airplane in line until rudder authority takes over. The transition is at about 60 knots. However there is no hard transition point so it depends on weight and balance and runway friction.
KAUSpilot
Sat Oct 29, 2011 7:20 am
On the 747 the rudder pedals have no effect on nosewheel steering; therefore we are instructed to use the tiller up until 30 knots groundspeed; beyond that only the rudder should be used.
KAUSpilot
Sat Oct 29, 2011 9:08 am
Correction to the above post, the pedals do provide 7 degrees of steering on the 747.
wn700driver
Sat Oct 29, 2011 10:00 am
Quoting KAUSpilot (Reply 4):
Just for the nosegear or also for the steerable mains as well?
Base not your happiness on the deeds of others, for what is given can be taken away. No Hope = No Fear
LimaFoxTango
Sun Oct 30, 2011 3:14 am
The Dash 8 rudder pedals gives 7 degrees of nose-wheel steering.
You are said to be a good pilot when your take-off's equal your landings.
KAUSpilot
Sun Oct 30, 2011 3:59 am
Quoting LimaFoxTango (Reply 6):
Just for the nosegear.
What I was trying to say in my original post was that the rudder doesn't give you additional steering over what the tiller provides; for example in some planes the rudder pedals give you 7 and the tiller gives you an additional 70 for a total of 77. That's not the case on the on the 747. Anyway, body gear steering only kicks in when when the nosegear is deflected more than 20 degrees, so the rudder pedals alone won't trigger it.
B747FE
Sun Oct 30, 2011 4:16 am
KAUSpilot
Actually both of your posts are correct. Many 747 classic didn't have rudder pedal steering.
Quoting wn700driver (Reply 5):
Only for the nose wheels.
Steering on the body gear is armed when the nose wheels are turned more than 20 degrees.
And it's not active nor intended to use during take off.
Quoting lke2fly (Thread starter):
lke2fly
Light pressure on the control column + rudder pedal steering is used at the beginning of the take off roll. Rudder becomes effective above 40 to 60 knots. Until then, the captain always keep left hand on the tiller.
Quoting RoseFlyer (Reply 2):
B747FE.
"Flying is more than a sport and more than a job; flying is pure passion and desire, which fill a lifetime"
Sun Oct 30, 2011 9:11 am
Just related......
On a B777.....Does mvmt of the Tiller move the MLG in addition to the NLG steering or is it only the NLG that is steered.
SAAFNAV
Sun Oct 30, 2011 9:39 am
On the C-130 there isn't a link between the nose gear and the rudder pedals.
During the Take-Off Run, the Pilot has the rudders, tiller and throttles, while the Co-pilot has the yoke.
Pilot will open the throttles, using the tiller to keep on center-line, until the rudder becomes effective. Not sure, but I think its at about ~50Kts.
Co-Pilot is keeping the wings level, countering for crosswind as needed.
At 80Kts, the Co will call out 80Kts, Pilot moves his hand over to the yoke, and it becomes his aircraft.
This is practiced excessively in the sim.
Landing is the opposite..
But, it becomes hairy when the co-pilot is landing, as he has to transfer control to the pilot. Unfortunately, some stop flying as soon as the they cross the runway, leaving the pilot with a heck of a workload to go straight.
Erich
Sun Oct 30, 2011 10:22 am
Quoting SAAFNAV (Reply 10):
The DC-9 and MD-80 only have a tiller on the Captain's side, so you have the same handover if the first officer is PF. Same on many aircraft.
yeelep
Sun Oct 30, 2011 7:39 pm
Quoting Starlionblue (Reply 11):
737 also has Captain's side tiller. F/O tiller is optional.
tdscanuck
Sun Oct 30, 2011 7:49 pm
Quoting HAWK21M (Reply 9):
MLG steering comes from NLG steering commands, but you have to move the NLG far enough to get it gong. Rudder pedal commands don't move the NLG far enough to get the MLG going, and even smaller tiller inputs won't get the MLG going.
Tom.
LimaFoxTango
Mon Oct 31, 2011 2:14 am
Quoting KAUSpilot (Reply 7):
Wasn't doubting you. I was referring to the DHC8 100-400 not, 747-8.
KAUSpilot
Mon Oct 31, 2011 5:52 am
Quoting LimaFoxTango (Reply 14):
No worries, I actually meant to include wn700driver in the quote for my second post since he had asked about body gear steering, hit the wrong button, doh!
Mon Oct 31, 2011 10:46 am
Quoting tdscanuck (Reply 13):
How exactly does the MLG steer.....Is it sensed by the directional variation of the Aircraft.....
nomadd22
Mon Oct 31, 2011 11:40 am
Is differential braking used at all?
Anon
Mon Oct 31, 2011 12:09 pm
Quoting HAWK21M (Reply 16):
The mains on the 747 (two bogies only) and 777 (rearmost axles only) steer automatically (unless the function is locked out) once the tiller is deflected beyond a certain amount of degrees. Transparent for the pilots.
B747FE
Mon Oct 31, 2011 3:16 pm
Quoting nomadd22 (Reply 17):
Sometimes, on very slippery surfaces.
B747FE.
Tue Nov 01, 2011 4:32 pm
Quoting Starlionblue (Reply 18):
But whats the principle of operation like......How does the rear axle deflect,by what signal...the tiller or the turn mechanically.
KAUSpilot
Wed Nov 02, 2011 1:09 am
Quoting HAWK21M (Reply 20):
On the 744 the nosewheel and body gear steering are all hydraulic, the gear are turned hydraulically by hydraulic system #1. The movement of the body gear is initiated only after the nose gear exceed 20 degrees of deflection from center.
Copied and Pasted from the 744 manual:
Quoting Boeing:
Body gear steering operates when the nose wheel steering angle exceeds 20
degrees. This reduces tire scrubbing and lets the airplane turn in a minimum radius.
Body gear steering is activated when ground speed decreases through 15 knots.
As speed increases through 20 knots, the body gear is hydraulically centered and
body gear steering is deactivated.
Wed Nov 02, 2011 9:21 pm
Quoting KAUSpilot (Reply 21):
Thanks....Exactly what I wanted to know....
lke2fly
Tue Nov 08, 2011 5:15 pm
Thank you to all of for educating me on how the rudder and tiller function together on take off and landing.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 1 guest
