CXfirst
787 Electronic Window Shade In Other Aircraft?
Sun Nov 06, 2011 4:13 pm
One thing that the 787 has, which I think is great is the electronic window shade.
My question is, would other aircraft be able to implement this. Could say a 737 be refitted with this down the line? Does Boeing have any plans for something like this, as part of an updated sky interior?
Also, does Airbus have any plans to implement this on the A350, and if not, does the design have the ability to have this changed? Or would doing this violate any patent law?
I believe that all airplanes should have electronic window shades, giving people who had the window seat the ability to see out, while not causing any undesired light for people sleeping, watching IFE, etc.
On a side note, what would happen if a technical problem happens, such as the buttons controlling the shade stop working? Are we at risk of having night flights where one faulty shade gives the cabin undesired light?
-CXfirst
bonusonus
RE: 787 Electronic Window Shade In Other Aircraft?
Tue Nov 08, 2011 10:05 pm
I believe it will be an option on the CSeries.
emirates202
Wed Dec 07, 2011 12:34 am
EK has them on all it's A380's, after A6-EDC, in F, and in J on A6-EDP as far as I know. They also have them on most 777L's and 777W's in F that have the suites, and in most J cabins, with the newer aircraft
-Saketh
Fly Emirates, Hello Tomorrow
roseflyer
Wed Dec 07, 2011 3:45 am
Quoting CXfirst (Thread starter):
I don't think it is planned for the 737MAX. The additional wiring would likely pose a bit of a problem to add it into an existing design.
aogdesk
Wed Dec 07, 2011 3:14 pm
AFAIK, that might be a possibility. The fail safe 'position' for this technology is clear/transparent. The technology to darken windows has been around for quite some time, but it would previously fail to a dark/shaded condition.
roseflyer
Wed Dec 07, 2011 6:11 pm
Quoting aogdesk (Reply 4):
I think the backup procedure would be a safety card or two jammed into the window to block light. Same thing that a resourceful FA would do when one of the old plastic shades gets stuck.
hal9213
Thu Dec 08, 2011 2:36 pm
Quoting Emirates202 (Reply 2):
What you mean is a motor driven classic window shade operated with buttons. I believe, the OP means the electrochromatic dimmable glas windows.
emirates202
Mon Dec 12, 2011 1:22 pm
Quoting hal9213 (Reply 6):
Oh ok. Didn't understand what he meant.
Users browsing this forum: Google [Bot], kurtverbose and 2 guests
