dla320
Airbus A319 IAE Vs. Engines
Sun Nov 13, 2011 1:47 pm
Why do some airlines choose one over the other? Does one have a climb rate, or range? Can you tell the diffrence when flying?
Northwest727
RE: Airbus A319 IAE Vs. Engines
Sun Nov 13, 2011 3:03 pm
It all depends on what is more important to the airlines that will utilize the engine, factors such as maintenance, power (which in turn affects the aircraft's useful load, and/or performance like shorter t/o runs), fuel burn, and of course, who will give the best deal. Each engine has its pros and cons, and that is why we see IAE V2500 and CFM-56 engines for the A319. On the other hand, the GE CF6-32 for the 757 had no takers, thus GE dropped out of the offerings for the 757.
I'm sure an expert can chime in on more advantages and disadvantages, but one of such points that I am aware of: IAE engines are more anemic with fuel, but have an appetite for oil.
KELPkid
Sun Nov 13, 2011 10:53 pm
The IAE is an outstanding hot and high engine, IIRC (hence operators like HP and UA using it). The CFM has slightly higher TSFC, but slightly better emissions (go figure. Pratt builds the core in the V2500. Remember the J57  ). Also, if you already have a lot of CFM56's in the fleet (737's, maybe A340's) it kind of makes sense to stay "in the family" on your engines (even if there's zero spares parts commonality between different versions of the CFM56, which I don't know if that is the case or not).
Pihero
Mon Nov 14, 2011 12:10 am
The engines are very closely matched in terms of performance but I personally have a preference for the CFM.
It is easier to use ( the main difference and a dead giveaway when you enter a cockpit is that the V2500 uses EPR as its main parameter, and I for one had rather use N1, like on the CFM-56).
It is also surprising to know that the -56 is a lot more automated : the start sequence is wayyyyy more advanced on the -56 although it is the older engine. The 2500 takes about a minute to start up to the 30 seconds or so for the CFM.
That's from an operator's point of view.
I really don't know about the economics of both engines.
Contrail designer
ferpe
Tue Nov 15, 2011 4:51 pm
@Pihero or others who know:
What would be the typical TO and cruise settings for the V2500 and CFM56 engines? I know you derate for the most part for take-off, could you give the typical values for the max take-off and a "day-at-office" take-off. In military engines I have flown we went over 100% N1 for some reason, do you also do that on civil engines? I am most interested in the cruise N1 vs thrust relationship, the cruise thrust is a fraction (typical 1/7 of TO thrust) but the N1 would stay in the region of 70-80% IMO (I have a good idea of the thrust in lbf or N but not the corresponding N1).
Also how do you show the EPR values, as % or pressure? What would be typical values for TO and Cruise?
Non French in France
imiakhtar
Wed Nov 16, 2011 3:41 am
Quoting ferpe (Reply 4):
These cruise videos should get you started. First two videos are IAE at cruise, last one is cfm:
http://www.youtube.com/watch?v=ajVNGhN8k58
http://www.youtube.com/watch?v=LlDUqWKt42M&feature=related
http://vimeo.com/23414415
Whatever happened to Leon Trotsky?
mandala499
Wed Nov 16, 2011 6:38 am
Quoting dla320 (Thread starter):
On a per hour basis...
If you want cheaper fuel burn, go with IAE V2500-A5...
If you want cheaper maintenance, go with CFM56-5B...
If you want to lose out on both in today's competitive environment... use either of the V2500-A1 or CFM56-5A
Comparing 2 A320 operators with similar operating environments, the IAE V2500-A5 were more reliable, but expensive to maintain... so one must balance the trade off carefully.
And yes, the CFMs are sold cheaper than the V2500s. That also a factor...
Quoting Northwest727 (Reply 1):
V2500-A1s are are jokingly "guzzles more oil than fuel"...
I'll add to Pihero...
Apart from the N1 vs EPR gauges... outside the take off and landing phases, you won't notice much.
The V2500s have a much bigger bite on the reversers than the CFM56.
Climb rates are about the same.
Simply pressure ratio... number goes from 1.00 to whatever... Any number bigger than 1 simply means the exhaust pressure is bigger than the inlet pressure... ie: it is pushing itself forward. (and numbers less than 1, we used to get them on 732s, means the engine is dragging itself!    )
The 320 family engines are basically "identical" to the 321 engines, for 33,000lbs take off thrust... The N1 value however, isn't always limited to 100%, it's just an arbitrary number from 0% = 0 RPM to x% = X RPM. However, the x-X conversion is the same for all CFM56-5B family... -5A family has a different set of "conversion", and the V2500-A1 and -A5 each have their own different "conversion" numbers...
This is probably why some prefer EPRs... coz it's simpler (see above), and relationship between EPR and thrust is linear... and the complexities are in altitude and temperature... (although the old JT8D on the 732 have damn easy rule of thumb to remember for consistent performance) and does not reflect "strain on the spools")... regardless on what engine you got...
N1 relationship to thrust, is non-linear... varying altitudes and temperatures can throw havoc into engine limitations during climb, but the "strain on the spools" are directly correlated with the N1).
A319? Over here, things normally we go at sea level and 30C... ish... over here    From the manuals:
Non derate/Flex numbers:
CFM 86-87% on 319s, 92-93% on 320s (96-97% for the older CFM56-5As)... >100% on the 321s... (they're all the same engine, just different FADEC imposed limits to match the required thrust for the aircraft).
Cruise would be about 77.5-85% depending on conditions of course...
On IAE (-A5s)
319s EPR 1.393 - 1.405 (or 86-87% N1), 1.397-1.413s (or 89-91% N1)for 320s...
Max cruise woud be about 1.35 - 1.42 or something like that... and N1s would be about 79-82% ish... on the 319-320 with IAEs...
Don't take the above as gospel... they're just simplistic explanations!
Mandala499
ferpe
Wed Nov 16, 2011 7:25 am
Thanks both for great answers    , now I have a much better idea.
The relationship N1 to thrust is truly non linear, easier to grasp but EPR tells you a more true story. Nice to know that the Civies also go beyond 100% sometimes    it's aviation after all....  Wow!     .
Users browsing this forum: alski, LAE320 and 18 guests
