zipsy
Mould Inside The Window
Tue Nov 15, 2011 1:18 am
On my recent flight on the Embraer 195 I have notized there was quite abit of mould inside the window,is that normal?I have never seen that before on any other jets.It would be a difficult job to get rid of it as it is sealed inside the window.
474218
RE: Mould Inside The Window
Tue Nov 15, 2011 1:33 am
If you mean the mold was between the inner and outer panes, the only way to remove the mold is to remove the window assembly remove the panes from the seal and clean the mold.
As for how the mold got there I would guess the vent hole in the inner pane is plugged.
Thu Nov 17, 2011 9:38 pm
What a mold.....Maybe out here it means something else....are you referring to a patch of moisture?...
tdscanuck
Fri Nov 18, 2011 2:00 am
Quoting HAWK21M (Reply 2):
What a mold.....
It's a fungus that tends to grow in moist areas:
http://en.wikipedia.org/wiki/Mold
Tom.
KELPkid
Fri Nov 18, 2011 5:57 am
I would tend to think that dry, thin air and high ultraviolet light exposure would make for a most hostile environment for mold...
B6JFKH81
Wed Nov 23, 2011 6:05 pm
Quoting zipsy (Thread starter):
It may not have been mold. On my airlines E190s, the side of the window shade that faces the window has a fuzzy fabric on it, which leads to more fuzz/dirt between the panes at least based on my observations.
Users browsing this forum: Bing [Bot], DBW111, ikolkyo, stackelberg and 1 guest
