An225
Engine Fuel Consumption
Sat Nov 19, 2011 2:48 pm
I remember I posted this question long time ago and received answers but can't find the damn thread... So sorry I need to post this again
I am looking for jet engines fuel consumption data during takeoff, cruise and landing. Can anyone please help me on that?
An225
tdscanuck
RE: Engine Fuel Consumption
Sat Nov 19, 2011 6:36 pm
Quoting An225 (Thread starter):
Which aircraft? Which engines? What weight? What thrust rating? Unless you want a *really* big data table (which I'm not sure exists) we need to narrow the problem down.
Tom.
titanmiller
Sat Nov 19, 2011 6:41 pm
A B-1B bomber consumes about 250,000 pounds/hour at sea level full afterburner and roughly 20,000 pounds/hour at cruise. Like tom said, there are so many variables that this question is unanswerable without specifics.
A CFM56 will burn about 8-10,000lb/hr on takeoff and 2-3,000lb/hr at cruise.
tb727
Sat Nov 19, 2011 8:10 pm
A JT8D will burn about 10,000+/hr on takeoff and depending on weight and desired cruise speed, anywhere from 2500-3800/hour in the low to mid 30's.
An225
Sat Nov 19, 2011 8:35 pm
Thanks for the replies.
When I originally posted this thread a long time ago, one of the participants gave me a link to the engine test reports (maybe the certification data?) which stated fuel consumption on takeoff, cruise and landing for numerous engines. I don't remember anything about weight or other variables.
An225
tdscanuck
Sat Nov 19, 2011 9:49 pm
Quoting An225 (Reply 4):
That data usually sneaks around burried in environmental reports...getting good operational data for a large fleet is nearly impossible. For example, see Appendix F of this document:
www.epa.gov/oms/regs/nonroad/aviation/r99013.pdf
CAA keeps a list of engine data sheets:
http://www.caa.co.uk/default.aspx?catid=702&pagetype=68
These give representative fuel flow for takeoff/climbout/approach/idle but not cruise.
Tom.
sunrisevalley
Sun Nov 20, 2011 12:35 am
In the FWIW department a 77L at 329t TOW burns about 15.3t /hr on takeoff and climb to FL390; 6.68t/hr based on 15hrs cruise and 1.38t/ hr in descent and landing.
An225
Sun Nov 20, 2011 5:12 am
Quoting SunriseValley (Reply 6):
http://www.caa.co.uk/default.aspx?ca...pe=68
this is exactly what I needed
tdscanuck you are a life saver!
Thank so much
An225
An225
Sun Nov 20, 2011 8:34 am
Another question or two...
If I am looking at the ICAO ENGINE EXHAUST EMISSIONS DATA BANK pages, there are fuel consumption data for four phases of flight:
Take Off (100%)
Climb out (85%)
Approach (30%)
Idle (7%)
which of these figures relates to cruise phase of the flight?
Another question - the time in minutes given for each flight phase, is it realistic?
An225
tdscanuck
Sun Nov 20, 2011 7:00 pm
Quoting An225 (Reply 8):
None...those data sheets are geared towards emissions modeling around airports so they ignore cruise.
You can interpolate between takeoff/climbout/approach to get a rough estimate for emission for various thrust levels.
In a statistical sense, yes. That data all exists to figure out the emissions input to the local airport environment.
Tom.
An225
Mon Nov 21, 2011 6:38 am
Thanks all for the insights
sf260
Mon Nov 21, 2011 12:31 pm
Quoting titanmiller (Reply 2):
Wow, that's really huge, concorde did 'only' 200,000 lb/hr at take off (with afterburner), while having 25% more thrust. (Concorde seemed a reasonable comparison object in terms of size/technology used to me).
And when comparing to an A380, that's even more mind-boggling, given it consumes about 80k lb/hr at take off thrust. That's 4 times as much, while weighing a third (or so)...
rwessel
Tue Nov 22, 2011 6:18 am
Quoting sf260 (Reply 11):
Afterburners are a rather inefficient way of generating more thrust (except at very high mach numbers). But they're small and lightweight compared to an engine upsized to generate that thrust. Concorde's A/Bs only produced about 6000lbs of additional thrust, or about a 19% increase from the non-afterburning 32,000lbs. The B1-B's A/Bs generate an additional 16,000lbs of thrust, over the normal 14,500lbs (125% increase). As a rough rule of thumb, each pound of thrust from the A/B consumes four times as much fuel as a pound of fuel from the turbojet/fan core. Assuming the engines on Concorde and the B1-B were equally efficient, you'd expect the F101s to consume about 40% more fuel in full burner than the Olympus.
Tue Nov 22, 2011 7:25 am
Combat aircraft are typically not as "optimized" for low fuel burn as airliners, as is obvious from this comparison.
I heard once that a SAAB Viggen runs out of fuel in something like seven minutes on full afterburner.
BA777
Tue Nov 22, 2011 12:20 pm
A rough figure for the 738 is 2,400kg/hr in general. So for example we say 15 mins holding is roughly 600kg.
sf260
Tue Nov 22, 2011 12:57 pm
Quoting rwessel (Reply 12):
Overlooked that... Thanks for pointing it out!
MarkC
Wed Nov 23, 2011 10:51 pm
An225, those percentages from the emissions data can be misleading. Like someone else said, they appear to only apply in the vicinity of the airport. I assure you that climb thrust at altitude is nowhere near 85%. More like 20%. But the TSFC changes as well.
Anyway, you have a Private Message with what you are looking for.
Users browsing this forum: GriN and 1 guest
