embrider
777 With De-rated Engines
Wed Nov 23, 2011 3:59 am
I was reading about SIA in Wikipedia and learned that all their 777-200 (and they have quite a few of them) are 777-200ER with de-rated engines. What exactaly are "de-rated" engines? Why would an airline choose it over a "regular" engine? What are the real differences between SIA -200 and the other -200s in terms of performance, etc?
fpetrutiu
RE: 777 With De-rated Engines
Wed Nov 23, 2011 4:02 am
Fuel consumption, those are mostly operated on short hauls and long runways. No need for the higher thrust ratings.
Florin
Orlando, FL
Viscount724
Wed Nov 23, 2011 4:03 am
Quoting embrider (Thread starter):
Probably so the aircraft can be certified at lower maximum takeoff weights which reduces landing fees which are normally based on MTOW. From what I've read, the differences mainly involve paperwork.
embrider
Wed Nov 23, 2011 4:07 am
Quoting fpetrutiu (Reply 1):
Thanks. It makes sense but wouldn't you have the same effect with "regular" engines, just applying less trust? You would still have a more capable aircraft if you ever need to deploy it on another route
jkudall
Wed Nov 23, 2011 4:12 am
Quoting embrider (Reply 3):
To be more clear, typically de-rating is essentially what you describe, at least during the takeoff phase of flight. If runway/airport conditions allow a de-rated takeoff, then the pilots select the appropriate setting in their flight computers and the plane will use a lower thrust rating. The engines themselves are capable of the full thrust, but using the de-rate option puts less wear and tear on the engines, uses less fuel, etc.
qf340500
Wed Nov 23, 2011 4:22 am
thanks for the explanation. I was always asking myself the same question... why has SQ not bought the "normal" 200 then instead, if they dont need the power?
BMI727
Wed Nov 23, 2011 4:30 am
I don't think it is fuel consumption so much, since the only changes to the engine in most cases is the software controlling it. The benefit of derated engines is less wear and tear leading to lower maintenance costs and better on wing time.
fpetrutiu
Wed Nov 23, 2011 4:35 am
Quoting BMI727 (Reply 6):
It is a software change, one that limits the thrust available and you are right increases the life of the engine. But on routes this is used on, also contributes to fuel savings, particularly during take-off and cruise phase. (usually these are shorter routes where a 20kts slower cruise speed would not make a noticeable difference, except for the pocket book)
Florin
Orlando, FL
CX Flyboy
Wed Nov 23, 2011 4:54 am
Also, regulations only allow a maximum derate of 25% from the maximum thrust. So if you regularly fly at lighter weighs, a 25% derate on the day might still be too much thrust. If those engines are derated (and normally given a different engine type name) then you can do 25% derate on the already re-rated engine.
CX has done this on their 777-300s which were fitted with Trent892s, each producing 92,000lbs of thrust. CX fly their 773s regionally only and have lowered the MTOW to 263tonnes. (The 777-300 is around a 300t plane). By lowering the weight to 263t, they pay lower landing fees and overflight fees, and even 263t is plenty when flying around the region. We rarely max out at that weight. Since the MTOW has been lowered, 92,000lbs of thrust was too much so RR did a software and paperwork change in the engines and re-rated them to 84,000lbs of thrust. The engines are now called Trent884Bs. Less thrust means less wear and tear and lower maintenance costs.
Keeping the engines at a higher rating and telling pilots to use less thrust will still result in the highest thrust being used at times, i.e. in turbulent and windshear conditions, and during the latter stages of the climb where maximum thrust might be used to keep the high rate of climb going even though for economic reasons it is not needed.
The Trent884B rating I believe is unique to CX where the engine produces a maximum or 84,000lbs of thrust for takeoff, but those lower thrust ratings are not good enough to keep a decent rate of climb going at higher altitudes and hence as the aircraft climbs, the maximum thrust rating slowly increases so that at higher altitudes, the full 92,000lbs of thrust is available. Without this, the 773 would be limited to lower cruise altitudes which is less than efficient. Its all juggling with costs and tweaking the variables until a lowest cost solution can be found.
tdscanuck
Wed Nov 23, 2011 4:55 am
There's not really a meaningful change in fuel consumption except during takeoff/climb...it makes no difference in cruise since you're not high enough up the thrust curve in cruise to run into the derate.
Quoting Viscount724 (Reply 2):
There's a little more to it than that, but not much. Changes to certified MTOW are purely paperwork; "permanent" derate of the engines changes out a physical programming plug on each engine computer. The plug tells the engine computer what thrust rating it should behave as.
Quoting jkudall (Reply 4):
The engine is physically capable of full thrust but, if it's a permanent derate then you can't access the higher thrusts (except in some oddball cases like the 737NG) without actually changing the engine programming plug. By far the most significant reason to do it is reduced maintenance and longer time on wing.
Quoting fpetrutiu (Reply 7):
Take-off yes, cruise no. If you're cruising at M0.85 it's going to take the same fuel regardless of whether you have a full or derated engine, since the derate selection doesn't change the aircraft drag polar or physical engine components at all.
Tom.
United1
Wed Nov 23, 2011 4:56 am
Quoting QF340500 (Reply 5):
Probably because if they ever did need the range from the aircraft their would be no way to convert them...vs the derated 200ERs are simply a paperwork exercise and software/chip update. It probably also helps with aircraft resale being able to market the 200ER vs the 200.
IIRC BA did this with some of the 744 calling them "744 Lite" and by limiting the MTOW they saved quite a bit of money in landing fees on the shorter transatlantic legs where full range wasn't needed.
I know the voices in my head aren't real but sometimes their ideas are just awesome!!!
fpetrutiu
Wed Nov 23, 2011 5:13 am
Quoting tdscanuck (Reply 9):
You are right. I had to do some research because I realized that I remembered it wrong. Here is what I have:
http://www.smartcockpit.com/data/pdf...mics/Derated_Climb_Performance.pdf
"For a small increase in block fuel and flight time the use of derated climb will result
in a considerable saving on DMC costs and increase in time between overhauls.
By using a procedure that allows flexible use of climb derate based upon operational
constraints, the savings will be maximised. The actual DMC cost savings are specific
to an individual airline’s route structure, average ambient temperature and other
significant factors. Rolls-Royce willingly engages with individual airlines to discuss
specific details of their operation. Overall a major net saving will be seen.
Many 777 operators have taken the ‘Fast Taper’ option, however Rolls-Royce
recommends that the ‘Slow Tapers’ option should be incorporated to enable
enhanced benefits. To maximise benefits, CLB 2 should be used in preference to
CLB 1 whenever possible."
Florin
Orlando, FL
lightsaber
Crew
Wed Nov 23, 2011 5:43 am
There have already been enough posts explaining it. Basically:
   A derated engine has a longer cycle life. Usually matched to a reduced MTOW, as already noted, for regional flying where a widebody is being used for the volume of payload and not the maximum takeoff weight.
Derating also helps with resale. The 'plug' will be replaced with a higher thrust plug upon resale. When CX and SQ sell their derated 777s, most likely the buyers will need more thrust for higher MTOW missions (longer range or one day there will be a freight 777).
The airframes will also undergo a 'paperwork' increase in MTOW. 772s (A-market) have a much lower resale value than 777-200ERs. The cost to change the plug and increase the MTOW is trivial. SQ bought their 777-200ERs in a very competitive market that allowed them to buy a much more capable jet than they needed for little (if any) increased cost. SQ will make their money back as they resell the airframes.
The same is true of CX's regional 773s. Albeit the 77W has put a crimp on the 773 resale market...
Lightsaber
BMI727
Wed Nov 23, 2011 5:53 am
Quoting lightsaber (Reply 12):
To boil it down to a possibly even more basic level, when an aircraft is first designed, the thrust requirement is matched to MTOW. When an airline is effectively never going to use the full MTOW of a given plane, they don't need the full thrust either to meet various performance requirements, so they might as well derate the engine. And for that matter write down the MTOW as well.
MarkC
Wed Nov 23, 2011 10:58 pm
People confuse "derate" with pilot controlled "reduced thrust". As Lightsaber says, derate engines are fitted with a different plug, and can only get the power corresponding to the plug no matter what the pilots do. Reduced thrust is what the pilots control based on local conditions.
I'll give you another example. Say you were an airline based in SFO, and wanted to put a 4090 on a 777-200 non-er which came with 4077's. You would put a 77k plug in the 4090 to match the engine on the other side.
rjsampson
Thu Nov 24, 2011 12:00 am
While on this topic: Is the only difference between the GE90-115b and the GE90-110b simply a matter of software? If so, is selection for the -110b over the -115b for the same "paperwork" reasons?
"..your eyes will be forever turned skyward, for there.." yeah we know the DaVinci quote. But GA is so dang expensive these days! :(
jetlife2
Thu Nov 24, 2011 12:40 am
Quoting rjsampson (Reply 15):
The engines are physically the same. The FADEC software contains all the tables for all ratings and bumps, so there is only one version of software. The rating plug (containing a permanently burned PROM chip) communicates to the FADEC which rating tables to enable.
The 777F and 200LR are smaller airplanes than the 300ER and are normally configured with 110's, but can be optionally configured with 115Bs. The customer chooses the model desired. The 300ER can only use the 115B. The extra capability of the 115B brings a price difference also. A 110B can be converted to a 115B and vice versa by changing the rating plug as well as record keeping via a SB.
All can be derated on a flight by flight basis, using either assumed temperature methods or fixed derate buttons (configurable to fixed levels of derate at customer option) or both at the same time. So very significant levels of derate can be used (much greater than 25% is possible, depending on mission).
In GE we usually try to use the word "derate" only to mean adjusting thrust flight by flight, and "rerate" when we are "permanently" changing the capability of the engine via the plug, but certainly that usage is different around the industry.
Hope that helps.
GHR
My views are not necessarily the views of the GE Company
Thu Nov 24, 2011 8:41 am
Quoting jetlife2 (Reply 16):
For all intents and purposes then, the PROM is just a program the system runs. Two different software in "physical" form.
tdscanuck
Thu Nov 24, 2011 8:57 am
Quoting MarkC (Reply 14):
There are a few exceptions to this. The specific one I'm aware of is the CFM56-7 on the 737NG...if the throttles are advanced to the forward stop the engine will go to the maximum rated thrust for that model (-600, -700, etc.) regardless of what rating plug is in place.
Yes.
In that particular case, yes.
In airliners with significant differences in length between the longest and shortest frame, but the same physical engine, the maximum thrust on the shorter versions may be capped to a lower value than the longer versions to avoid Vmca/Vmcg problems.
Tom.
aerotech777
Thu Nov 24, 2011 9:37 pm
According to this website: http://www.b737.org.uk/assumedtemp.htm, there are 2 types of derate: semi-parmanent derate and temporary derate known as "T/O De-rate.
The semi-parmanent derate would require changes to the EEC, HMU, fuel pump, engine ID plug and the loadable software.
Here the quote from this website:
A de-rate is a semi-permanent engine fix, used to reduce the maximum thrust available; for instance down to 20k from 22k on -3/700's. It is also used to equalise the thrust where B2 & C1 engines are mixed on the same airframe. When an engine is de-rated, the full (un-de-rated) thrust is no longer available because this would require changes to the EEC, HMU, fuel pump, engine ID plug and the loadable software; non of which can be done by the pilot in-flight.
A temporary form of de-rating known as a "T/O de-rate" is accessible through the FMC on TAKEOFF REF 2/2 or N1 LIMIT (NG's) but this is prohibited by some operators. The T/O de-rates (TO-1 & TO-2) can be 10 to 20%. It follows that an engine may be de-rated and also be using reduced thrust in which case you could be taking off at Full power -20% -25% = 60% of the full power of the engine - scary thought! Note that a T/O de-rate can overridden by firewalling the thrust levers.
hal9213
Fri Nov 25, 2011 12:04 pm
Although everybody already explained well, Ill give another practical example: Lets say, a critical part has to be examined and/or replaced after 1000 cycles, but on the rerated engine, would only need after 1500 cycles, because it experiences less stress. That saves maintenance cost.
If you "just apply less thrust", you cant track or make sure, how the engine was used, so you have to maintain the part after 1000 cycles in any case.
tdscanuck
Fri Nov 25, 2011 7:43 pm
Quoting aerotech777 (Reply 19):
This is only true of older engines (usually the ones that don't have FADEC's). All new large engines I can think of just require changing the ID plug.
They can be more than that...the amount of % derate that matches TO-1 and TO-2 is selectable by the airline.
Tom.
aerotech777
Sat Nov 26, 2011 6:59 pm
Quoting tdscanuck (Reply 21):
I think there are talking about engine fitted with FADEC because they mentioned EEC (Electronic Engine Control).
tdscanuck
Sat Nov 26, 2011 8:13 pm
Quoting aerotech777 (Reply 22):
There was some grey area in there for several years where engines had computers but they were only doing scheduling/monitoring and weren't full authority...not sure if those were properly called EEC's or not. I do know it's definitely true that, on the current generation engines, you don't need to change any hardware beyond the plug...the EEC, HMU, pump, and software are all the same.
Tom.
Users browsing this forum: Google Adsense [Bot] and 1 guest
