jbcontrails
B6 - A320 - ETOPS question
Fri Nov 25, 2011 10:11 pm
Hi all,
Im new to the forums and I am sure that this discussion has be beat to death. Please accept my apologies in advance. However with ETOPS certification for flights to places such as SXM and transcon capability and A320 NEOS on order. Is there any realistic chance that B6 will start flights to HNL, OGG, KOA? I know they divert quite reguarly during winter months on transcons due to the strong jetstream, however, most flights from CA to Hawaii are shorter then the BOS to west coast routes. Is the ETOPS time certifcation issued by the FAA for Carribbean destinations valid for Hawaii operations as well? Thanks for your inputs.
-J
aerorobnz
Fri Nov 25, 2011 10:29 pm
Quoting jbcontrails (Thread starter):
Without knowing for sure I'm gonna say the answer is no. Hawaii is a long way out into the largest ocean on the planet, and there is a lot of empty space before/after Hawaii. Unique the Caribbean which is surrounded on 3 sides by lots of land and lots of potential diversion airports.
I have just checked on GCmap which stated that the minimum requirement to operate LAX-HNL is ETOPS/EDTO180.
Flown to 126 Airports in 47 Countries on 80 Operators. Visited 56 Countries and counting. Wanderlust is like Syphilis, once you have the itch it's too late for treatment.
lightsaber
Crew
Fri Nov 25, 2011 11:29 pm
In my opinion, yes. But it will take the A320NEO with sharklets due to greater diversion margin over water.
The sharklets will help the winter diversions. But that is only 100nm additional range. The engines will provide about another 400nm of range (after the weight penalty of the engine which is ~1.8t including about 1/2t for the airframe).
A prior discussion on the topic:
A320NEO Weight Revealed - Flightglobal (by art Dec 7 2010 in Civil Aviation)
For example, while LAX-BOS is 2269nm vs. LAX-HNL of 2221, the over-water flight will require more surplus fuel (no real diversion available until very close to HNL). Since LAX-HNL is possible with the current 738 (going from memory, 3400nm range), the A320NEO should be able to fly to the islands.
In my opinion, the winglets will allow for more fuel volume. For example, with B6, they found sans winglets the ACJ (due to its weight) cut range. I suspect with the wingles (NEO or no) the ACJ will provide the A320, with a high passenger payload, the range it needs. So it is possible B6 could fly to Hawaii with A320 (w/sharklets & ACJ) prior to the A320NEO, but I consider it unlikely.
Lightsaber
B6JFKH81
RE: B6 - A320 - Etops Question
Mon Nov 28, 2011 7:32 pm
SXM does not require ETOPS. Currently none of the destinations served by B6 require it as there are ample suitable alternatives, and B6 has no ETOPS certified aircraft.
There is always a chance, but the market is quite busy already and based on the many threads in reference to Hawaii - US mainland routes, they are low-yield routes. Right now, a lot of the routes that B6 is opening are high-yield and not flooded with other carriers.
Quoting lightsaber (Reply 2):
And I think that is what you will start seeing. The sharklet-fitted aircraft will start taking out the wingtip fence aircraft on the transcons until the NEOs come in. There are also talks about the A321 starting to do some of the transcon trunk routes once they come online. But, once the NEO's come online, I have a feeling that not only will you see B6 open destinations a bit further away, but the NEO's taking over the transcon routes to get rid of the tech stops during the winter especially. That's just IMHO though.
~H81
747400sp
Mon Nov 28, 2011 7:57 pm
I hope B6 do not enter the Hawaiian market, same for WN. I do not like the ideal, of an A32X/737, flying to Hawaii from California.
I say, leave Hawaii, to airlines that can sever the routes with W/Bs. Hawaiian Air has the right ideal, A330s, are the best a/cs, to fly to Hawaii on form any where in the US.
PS: Please do not take this as a attack on you, I just do not like small planes, flying the Hawaiian service. Also Welcome to A-net.
Mon Nov 28, 2011 8:22 pm
Maximum diversion distance is based upon Vmo/Mmo, not drag reduction or reduced fuel burns.
dxing
Sun Dec 04, 2011 7:24 pm
Quoting 747400sp (Reply 4):
UA does it every day. Two engines is two engines no matter how big or small they are.
Quoting zeke (Reply 5):
Correct. The worst of 4 scenarios is what determines your necessary etops fuel. Usually 10 thousand feet on one engine. At that point sharklets will have little if any effect.
Warm winds blowing, heating blue skies, a road that goes forever, I'm going to Texas!
tdscanuck
Sun Dec 04, 2011 8:58 pm
Westjet and Alaska are both making very good money with that model.
If you're concerned about safety of twins on those routes, you should actually be in favour of smaller planes because the exposure is smaller. The amount of traffic is basically a constant so if you spread them out over more smaller aircraft, the average number of fatalities in the event of an accident is lower.
Tom.
roseflyer
Mon Dec 05, 2011 1:56 am
The A320 is ETOPS 180 capable, but would take payload hits operating to Hawaii on some routes. Although not unbearable, the A319 would probably be the ideal airplane.
