G500
Is LAS-ICN The Longest A332 Flight In The World
Mon Dec 05, 2011 1:54 am
A travel website has Korean Air's Vegas-Seoul (going west) at 13 hrs 40 mns. This HAS to be the longest A330 flight in the world, correct?
I didn't know the A330-200 had this kind of range
DLNZ
RE: Is LAS-ICN The Longest A332 Flight In The World
Mon Dec 05, 2011 2:03 am
Quoting g500 (Thread starter):
No, QF operate the type on LAX/AKL which is 420nm longer by distance than ICN/LAS.
http://www.gcmap.com/mapui?P=icn-las%0D%0Alax-akl&MS=wls&DU=nm
G
Transpac787
Mon Dec 05, 2011 3:15 am
DL's DTW-HND will become the longest A332 flight in the world by duration - QF's LAX-AKL will be slightly longer by distance, though much shorter since they don't fight headwinds even remotely as strong as polar crossings.
Faro
Mon Dec 05, 2011 11:35 am
Quoting Transpac787 (Reply 2):
Do either of these flights have payload restrictions? I should imagine these may be significant.
Faro
The chalice not my son
Clydenairways
Mon Dec 05, 2011 4:54 pm
Air Europa MAD-EZE-MAD is also longer.
Air France CDG-Tokyo is very long also.
ferpe
Mon Dec 05, 2011 6:19 pm
Quoting faro (Reply 3):
Payload-range 332 vs 788
The 332 is really characteristic in that it's max MTOW area (the down-slope curve over 5000nm) goes all the way to 0 payload, so yes over 5000nm you can choose between fuel or payload. Just decide how long you want to go and you fuel accordingly, what is left is payload    . Up to about 14 hours you have some usefull payload (subtract 5-8t for a real world cabin + catering first then the rest is payload).
Non French in France
roseflyer
Mon Dec 05, 2011 7:03 pm
Quoting ferpe (Reply 5):
The 332 is really characteristic in that it's max MTOW area (the down-slope curve over 5000nm) goes all the way to 0 payload, so yes over 5000nm you can choose between fuel or payload. Just decide how long you want to go and you fuel accordingly, what is left is payload . Up to about 14 hours you have some usefull payload (subtract 5-8t for a real world cabin catering first then the rest is payload).
I believe that is because Airbus did not remove fuel tanks from the A330 vs the A340, so the A330 can take a ridiculous amount of fuel and is impossible to dispatch with full tanks. No new build airplane has that configuration, but it makes sense for commonality purposes.
Clydenairways
Tue Dec 06, 2011 11:53 am
Quoting RoseFlyer (Reply 6):
The A330-200 does have a centre tank while the -300 does not, but the -200 still doesn't have the same fuel capacity of the A340 109T v 111T.
Not impossible, but you only have about 9000kg of payload available.
The -200 can hold 109T of fuel, but you only need around 70T for a typical 12hr flight. So you are correct in saying the aircraft has too much Fuel capacity .
Viscount724
Wed Dec 07, 2011 1:57 am
Quoting clydenairways (Reply 4):
Don't believe AF uses the A332 on that route now. They did for a while.
In addition to AKL-LAX, QF also used the A332 on SYD-BOM until they dropped that route. Those sectors are roughly 200 to 400 nm further than CDG-NRT.
bjorn14
Fri Dec 09, 2011 10:17 pm
Where did Airbus get the extra 300 nm range on the 333HGW? BTW, can't wait for the 350R to go into service.
"I want to know the voice of God the rest is just details" --A. Einstein
ferpe
Sat Dec 10, 2011 7:33 am
Quoting bjorn14 (Reply 9):
IIRC they raised the MTOW from 233t to 238t, that gives you another 5t of fuel. It was not used for payload (max payload was even reduced slightly from 170t to 168t for VW 58) . Now 5t of fuel gives you about an hour extra flying time at cruise speed ie 480nm longer range but you have to calculate the extra induced drag for dragging those extra 5t to 7000nm where you burn them so the net result ends up at 300nm more range.
Users browsing this forum: Bing [Bot], glen and 7 guests
