Vio
Help: Can I Carry This Med. Equipment On-board?
Tue Dec 13, 2011 10:49 am
Hi everyone,
I have been very fortunate to receive a donation for a "Lifepak 10" Defibrillator/Monitor/Pacemaker and I am planning to donate it to a hospital in Romania. I will be travelling there just after Christmas on Air Canada / Alitalia and Tarom. My question is:
Can I carry this equipment on-board the aircraft as a carry on? I don't want to check it in, because it's very sensitive and (fairly) expensive. Good people in Romania can really make use of this and I am trying my best to bring it to them. The machine is in perfect working conditions.
The "Lifepak 10" Defibrillator/Monitor/Pacemaker"
Thank you so much
Vio
Edit:
I should add dimensions / weight:
Height: 10.4cm (4 in)
Width: 40.6 cm (16 in)
Depth: 37cm (14.6 in)
Weight: 9kg (20 lbs)
[Edited 2011-12-13 02:55:25]
Markhkg
RE: Help: Can I Carry This Med. Equipment On-board?
Tue Dec 13, 2011 11:02 am
Ah, good old Lifepak 10. A classic.
Do not carry defib pads through security as they are sealed and should not be opened for inspection. (Security may be concerned about the "gel" in the pads.) Check those in. A non-issue if you're using paddles of course.
For the monitor itself, it's probably find to carry...EXCEPT for the battery. You need to check the type of battery it uses and check with the airline if you are allowed to carry it.
Lifepak brands have several types of battery, the Sealed Lead Acid (SLA), Ni-Cd and lithium. I think the Lifepak 10 only used Ni-Cd batteries which should be fine for carry-on transport. (I would probably double check this if at all possible.) However, SLA is banned on most airlines and there is usually there is a restriction on the quantity of lithium battery you can carry.
If you can, it might be a good idea to get a medical letter indicating that it is being transported for a donation, even if that letter is from the destination hospital.
Fabo
Tue Dec 13, 2011 11:40 am
Also, I would definitely contact the airline. I believe any respectable airline will try to accomodate you.
The light at the end of tunnel turn out to be a lighted sing saying NO EXIT
hal9213
Wed Dec 14, 2011 2:55 pm
Be sure to bring extra time. This kind of stuff will nearly always be checked seperately at security for explosives, which can be time consuming.
474218
Wed Dec 14, 2011 6:19 pm
Have you checked with Romanian government?
While your intentions may be good, normally if you are bringing something into the country and not taking it out with you, it will be subject to import taxes, etc.
Vio
Wed Dec 14, 2011 7:42 pm
Thank you everyone for your good answers, especially Markhkg for his detailed knowledge on the Lifepak 10.
Quoting Markhkg (Reply 1):
This shouldn't be an issue, since it's not considered "dangerous goods"
I will have letters from both the donating / receiving officials.
Quoting Fabo (Reply 2):
You would think so, but I can only hope.
Quoting hal9213 (Reply 3):
Yup. Very true. Yesterday I went and spoke with Air Canada officials and also the Security Manager at the airport. They both said it's no problem.
Quoting 474218 (Reply 4):
I don't think that applies to donations. I'm not making money with it and it's a public donation for a charitable cause. I doubt anybody in their right mind would impose a tax on a free medical (life saving) device... then again, stranger things have happened.
Thanks again for all your help guys!
474218
Thu Dec 15, 2011 12:21 am
Quoting vio (Reply 5):
You will not be dealing with people but with a "government".
But I applaud you for your good intentions.
Maverick623
Thu Dec 15, 2011 1:11 am
Just a question, what makes you say that?
"PHX is Phoenix, PDX is the other city" -777Way
Vio
Thu Dec 15, 2011 2:00 am
Quoting 474218 (Reply 6):
You are right... and thank you... I do want to make a difference in this world, even if it's on such a small scale. Hopefully this machine will be able to help a lot of people in need. If every person did something nice for someone else, even if once a month, this world would be a lot better place.
Quoting Maverick623 (Reply 7):
Quoting Transport Canada Website:
While many types exist, not all batteries are subject to the Transportation of Dangerous Goods (TDG) Act and Regulations. For example, common household-type alkaline, nickel cadmium (NiCad), nickel metal hydride (NiMH), and silver-zinc batteries are not classified as dangerous goods.
http://www.tc.gc.ca/eng/tdg/publicat...ins-transportingbatteries-1099.htm
From what I've been told the Lifepak 10 has a NiCad battery.
JRadier
Thu Dec 15, 2011 9:00 am
Having been at the receiving end of these requests at an airline (and handling them), the only right thing you can do is contact the airline(s) involved. It all very much depends on the Operating Manuals (Ground Handling, Cabin Safety, if checked in Flight Safety, DG regulations). These very much vary from carrier to carrier. From a quick look I don't think I would have had a problem with this one on my carrier, but I'm not looking into specifics right now.
Contact your carriers and let them tell you what to do, that is the best way to avoid surprises at the airport. If they don't have any problem with it they will let you know, and if you need to do specific things to carry it they will inform you. Just showing up with equipment like this might result in it being denied as it can not be determined in time if it is safe, and you will want to avoid that.
For once you have tasted flight you will walk the earth with your eyes turned skywards, for there you have been and ther
Stealthz
Thu Dec 15, 2011 1:12 pm
That is a very valid point, whilst many of us would consider a donation of medical equipment an honourable and noble act, there are some.. governments and their agencies, that might consider such donations as an affront, as a perceived insult aimed at their ability to care for their own citizens.
I am most definitely not saying that Romania is in this category but it it is something to be aware of, limitations on import or carriage of such equipment may be affected by more than the mere technical characteristics of the components.
Not saying don't do it, I admire your charitable intentions, just be aware of the potential issues.
Thu Dec 15, 2011 2:18 pm
Quoting vio (Reply 8):
Commencing Jan 01 2012 the IATA Dangerous Goods Regulations will have been amended to cover all batteries carried onboard. I would strongly suggest you contact the actual carrier that you intend to fly with, with the intended departure date, and supply them with details of the batteries being carried. I suspect the batteries in the device are not the standard household type.
It may also be useful to contact the airport you intend to get security screened before you departure date to ensure they will let you proceed with the device. These people often do not allow things onboard that the airline does.
yeelep
Thu Dec 15, 2011 2:19 pm
The issue I have with your logic is each one of those types of batteries are also found in commercial type batteries. The link you posted has a picture of household batteries that are no larger than a C-cell. You may want to further investigate what is considered "household" by Transport Canada and the TDG Act and Regulations.
It may potentially be less hassle to just ship the batteries separetley.
Vio
Thu Dec 15, 2011 2:35 pm
Thanks everyone for all the good feedback.
Quoting zeke (Reply 11):
Hi Zeke, like I said above, I did check with Air Canada and Security (supervisor on shift) and they both said it's okay. Now I have to find out if Alitalia and Tarom is fine with it. (see my previous post below)
Quoting yeelep (Reply 12):
Hi yeelep,
Yeah, that's a good point.
[Edited 2011-12-15 06:36:12]
Users browsing this forum: Yahoo [Bot] and 1 guest
