1337Delta764
Slide/rafts On 737 MAX?
Thu Jan 05, 2012 7:16 pm
Currently, the 737NG is the only Boeing or Airbus aircraft that does not offer slide/rafts as an option. However, with many carriers now flying 737s overwater, I was wondering, could Boeing offer them on the 737 MAX?
Markhkg
RE: Slide/rafts On 737 MAX?
Thu Jan 05, 2012 7:26 pm
Quoting 1337Delta764 (Thread starter):
I think the door would need to be re-designed to handle the larger slide/raft pack, but my understanding is that the door design will remain the same. But ultimately air carriers would probably just do what they do with current 737s...stick a separate raft in the overhead ceiling.
JRadier
Thu Jan 05, 2012 9:18 pm
Quoting Markhkg (Reply 1):
I agree. Also because they can only be put on the aircraft when required, and not on every single flight, which would mean increased fuel burn.
For once you have tasted flight you will walk the earth with your eyes turned skywards, for there you have been and ther
