jetmech
Constant Speed Drive Technical Reference
Sat Jan 14, 2012 7:30 am
G'day All,
I recently found the personal website of an Aircraft Engineer from Greece (A'net member?),
http://www.k-makris.gr/
Of particular interest was an excellent page on the inner workings of the hydraulic Constant Speed Drive (CSD) mechanism used in the Integrated Drive Generator (IDG) as seen on many commercial types.
http://www.k-makris.gr/AircraftComponents/CSD/C.S.D.htm
http://www.k-makris.gr/AircraftComponents/CSD/csd_shcem-2.gif
http://www.k-makris.gr/AircraftComponents/CSD/csd_over.gif
The actual mechanism is far more complex and clever than I first imagined. I was always under the impression that the variable / fixed hydraulic pump combination was the only component responsible for achieving the constant output RPM. However, it appears that the variable / fixed hydraulic pump combination acts on a planetary gear-set and only pumps oil when there is a speed difference between the input and output sides.
If the input and output speeds are similar, there is a direct drive through the planetary gear-set. This approach makes a lot of sense, for if there was only a variable / fixed hydraulic pump combination as I first thought, such a mechanism would still need to pump an appreciable amount of oil for the direct drive (input speed equal to output speed) situation, which would of course entail the IDG consuming much more power.
Regards, JetMech
tb727
RE: Constant Speed Drive Technical Reference
Mon Jan 16, 2012 3:53 am
The CSD is a really cool design. You've gotta check those "In" and "Rise" temps! What is the schematic off of? 737-200? Looks Boeing.
The CSD Disconnect is an interesting feature too, it "screws itself out of a job" and can only be reset on the ground so if you're gonna do it, make sure you really want to do it!
tdscanuck
Mon Jan 16, 2012 4:48 am
Quoting tb727 (Reply 1):
Not sure what aircraft, but that's straight from a Boeing System Schematic Manual...that layout, formatting, and fonts are pretty unmistakable.
This is fairly common for generator disconnects...Boeing IDG's and VFSG's work the same way.
Tom.
B747FE
Tue Jan 17, 2012 2:27 am
Quoting jetmech (Thread starter):
Correct!
Underdrive mode = input speed higher than required = hydraulic unit works a a motor.
Overdrive mode = input speed lower than required = hydraulic unit works as a pump.
When in straight through mode, the generator is then driven directly through the differential. (Wobbler perpendicular to the pumping pistons)
On a JT9, at around 65% N2, sometimes you can actually recognize when the CSD is in straight through because there is a slight load oscillation between generators.
B747FE.
"Flying is more than a sport and more than a job; flying is pure passion and desire, which fill a lifetime"
tb727
Tue Jan 17, 2012 4:18 am
Quoting B747FE (Reply 3):
That's just a cool observation!
737tdi
Tue Jan 17, 2012 4:36 am
Not to be overly picky but the use of IDG in this case is not really correct. In this case the CSD and Generator are separate units where as an IDG is the combination of CSD/Generator in one unit. Good stuff either way. I sure know I prefer IDG's when it comes to replacement.
N243NW
Wed Jan 18, 2012 4:40 am
It's definitely a 737 and definitely not an NG. The overhead panel sketch gives it away.
jetmech
Sat Jan 21, 2012 3:02 am
Was this N2 typical of cruise conditions? Seems like it may be associated more with idle or lower power settings. I would have imagined that you would want the straight through (direct drive) condition to occur at an N2 close to that associated with typical cruise power settings    .
Regards, JetMech
B747FE
Sat Jan 21, 2012 7:46 am
Quoting jetmech (Reply 7):
No, just above idle thrust. (N2 in cruise is around 20 to 25% higher)
On the P&W engines, I used to see this during the taxi out.
On aeroplanes with RR (211-524 with IDG) or GE CF6 it was during descent, but I don't remember the exact speed. (Should be at faster speed than the JT9D)
Sure, but either way even if it was at cruise thrust setting it was a very narrow speed range in which the oscillations happened (+/- 2 or 3% max) and it didn't necessarily happened on all engines at the same time.
Needless to say the CSD's didn't really spend a lot of time in straight through mode.
B747FE.
IFixPlanes
Sat Jan 21, 2012 12:41 pm
...What is the schematic off of? 737-200? Looks Boeing. ...
It is out of the 737-3/4/5 AMM chapter 24-11-00
SSM drawing looks a bit different.
never tell an engineer he is wrong ;-)
aviopic
Sat Jan 21, 2012 9:17 pm
Quoting 737tdi (Reply 5):
To Illustrate the matter I' ve uploaded a few photos that I made at work for PR purpose into an album.
It contains a typical B73 setup, the shiny bit is the Generator and the black bit the CSD together forming a huge lumb
An A320 IDG.
And an internal view of a F70/100 IDG.
The truth lives in one’s mind, it doesn’t really exist
jetmech
Sun Jan 22, 2012 5:11 am
Quoting B747FE (Reply 8):
Certainly. No doubt N2 would also vary somewhat for different flights and during a flight, so any benefits of operating in direct drive would only manifest for a small portion of the total flight time.
Quoting aviopic (Reply 10):
Nice photos. The third one appears to show two CSD's in the same casing. If so, was this for redundancy?
Regards, JetMech
Sun Jan 22, 2012 12:03 pm
Looks exactly like the B732 AMM Schematic & Training manual.
IFixPlanes
Sun Jan 22, 2012 6:53 pm
Quoting HAWK21M (Reply 12):
No, not exactly, but you have to lock closer
As i already wrote in reply # 9:
It is out of B737-300/400/500 AMM 24-11-00.
titanmiller
Sun Jan 22, 2012 7:04 pm
Absolutely fascinating! Thanks for sharing your discovery.
aviopic
Sun Jan 22, 2012 9:15 pm
Quoting jetmech (Reply 11):
Nope.
http://www.honders.net/tmp/FO100_IDG_Dwg_2.jpg
Users browsing this forum: Google [Bot] and 16 guests
