airsmiles
Delta Maintenance Facility Atlanta
Mon Jan 30, 2012 7:30 pm
I'm visiting Atlanta shortly from England and wondered if Delta use a satelite airfield near ATL where they perform additional maintenance work? I'm keen to view as much of the activity as possible (especially the DC-9-50's, MD88's, MD90's) but wonder how close to the action I can get?
If anyone has any knowledge of the various ramps and buildings at ATL I'd be greatful.
KPWMSpotter
RE: Delta Maintenance Facility Atlanta
Mon Jan 30, 2012 9:08 pm
All Delta maintenance work (in Atlanta) is performed at the TechOps facility, right on the airport at Hartsfield. The TechOps complex is located at the Northeast side of the midfield complex, along Aviation Blvd. Unfortunately, there isn't really any way to view the action at TechOps from land-side. You can view some of the ramp from Aviation Blvd, but much of the action is hidden behind the hangars.
If you're interested, the three primary maintenance buildings in Atlanta are (from East to West) TOC 3, 2, and 1. TOC 3 is the most recent hangar to be built, and houses Delta's in-house paint shops as well as three widebody maintenance bays. TOC 2 is the center hangar (the largest cantilevered building East of the Mississippi), and houses most of Delta's overnight, A, B and C checks for 777 and 767 aircraft as well as MRO work for other airlines and the US Government. TOC 1 (the one with the "Fly Delta Jets" sign) is the oldest hangar in the complex and houses most of Delta's narrowbody work. Also in TOC 1 are Delta's back-shops, including the engine rebuild/MRO operation and engine test cells. Let me know if you have any more questions - there's a LOT that goes on within TechOps, far too much to describe in one post.
If you're just interested in watching the aircraft taking off and landing, the only good place I can suggest is the main terminal parking garage at the West side of the field. Atlanta isn't very photographer-friendly, but the parking deck gives decent views and you shouldn't be hassled by security.
Hope this helps!
I reject your reality and substitute my own...
airsmiles
Tue Jan 31, 2012 10:23 am
Thanks, that's a lot of information. It's a shame everything is so inaccessible though, as for a UK visitor there's plenty of interest at Delta's ATL base.
litz
Tue Jan 31, 2012 8:24 pm
You could always book a room at the Renaissance Concourse Atlanta Airport Hotel ... They have an entire side of the airport overlooking the tarmac. A good spotting scope or set of binoculars would offer plenty of plane-spotting opportunities.
Dalmd88
Tue Jan 31, 2012 9:27 pm
TOC 3 has two widebody bays and one narrowbody bay. Bays 11 and 12 on the east facing wall are the only two that are now used for painting. Eleven is for MD88/737/757 and Twelve fits up to a MD11. Bay 10, the most eastern doors facing the runway is for non routine maintenance, but can be used to paint 777 and 747. This time of the year the doors are mostly closed so even from the taxiway there is little to see. From Aviation Blvd you really can't see much and there is no place to park along the fence.
e38
Wed Feb 01, 2012 10:59 pm
Question for KPWMSpotter and Dalmd88:
Both of your explanations were excellent. I have an additional question:
When landing and taking off from Atlanta, I have also seen quite a few Delta aircraft parked on the north side of the airport (north of Runway 8L/26R) and also some parked on the south side of the airport (just south of Runway 9R/27L). Are these areas also used for maintenance or are the aircraft just parked there as "overflow" parking (i.e. what is the status of the aircraft in these parking areas)?
Also, does Delta use the former Northwest hangar (which was the former Republic hangar) on the south side of the airport, and if not who is it used by?
Thanks.
e38
KPWMSpotter
Thu Feb 02, 2012 12:40 am
Quoting e38 (Reply 5):
Mostly just overflow parking. They may do some simple maintenance (things that would be performed at the gate at other airports - tire changes and whatnot), but any major work is done at the TOC.
I think that hangar is vacant at the moment. It's not used by Delta, and I've never seen much activity over there.
e38
Thu Feb 02, 2012 2:27 am
KPWMSpotter:
Thank you.
e38
FlyASAGuy2005
Thu Feb 02, 2012 2:59 am
To piggy back on PWM Dalmd88, Delta North is in fact used for RON a/c and you will also find a handful of MD90s; one in new DL paint but still with a China Southern tail. International garbage, interior and exterior a/c cleaning, and catering is handled on that pad which is officially called Delta North. Cabin cleaning and conditioning, a stores department, and the tow team is based out of that building that sits adjacent to the ASA/Air Tran hanger. Like PWM said, you will find some light MTC work being done as well as a lot of interior MTC.
Also, down by the old NW hanger you will mostly find widebodies which are preparing for an international flight (get the catering and cleaning done) or was towed from an international inbound to clear the cabin (removing all galley carts; getting rid of trash, etc) to prep it for another flight, an overight or waiting to be taken to the hanger.
What gets measured gets done.
airsmiles
Tue Feb 07, 2012 1:36 am
Well thanks to you guys I went down to ATL on Sunday and had a good time. I went into Aviation Boulevard first and saw quite a bit close to, not to mention a steady stream of aircraft waiting to take-off from the eastern end of the runways. I then went around the south side of the outer loop road and picked up a few more Delta a/c parked up there.
Making my way back around to the north side of the airfield I went around the freight area where a number of Fedex, UPS and Omni a/c were parked up. Unfortunately the one aircraft I couldn't get the tail number for was the Omni DC10. Cruel luck as it's a very rare aircraft in the UK. Anyone know that tail number?
Also there were quite a few Delta aircraft parked up on the north side past the freight area. Lastly, as advised, I then spent quite a few hours on top of the North Terminal car park.
Thanks again.
Users browsing this forum: No registered users and 19 guests
