sid1975
LGA Airport Badge
Tue Jan 31, 2012 12:54 am
I had a job in 2008 working a certain airline and I had my badge confiscated by the port authority because a fellow worker had his badge rejected and I unknowingly took him with me to retrieve an aircraft to bring back to the gate( we had to go through security). I ended up getting a job at Boeing and worked there up til now and 6 months after I started I had to pay a thousand dollar fine for the infraction that happened at LGA. I paid the fine and that was it never heard from them again. Fast forward three years,..I just interviewed for delta airlines MTC and everything is well, im just waiting on my background check to clear. Now my question is, will the infraction I had in 2008 prevent me from getting my badge? If so what can I do?
EMBQA
RE: LGA Airport Badge
Tue Jan 31, 2012 1:14 am
I would say no. The background check is criminal, the fine was local. My guess you were escorting the person and did not have escort status...?
sid1975
Tue Jan 31, 2012 1:18 am
His badge failed that same day because he messed up his pin number. He had the same privileges as I did.
dlramp4life
Tue Jan 31, 2012 2:28 am
Usually if you screw up your PIN the alarm will sound and you can just reswipe your badge and enter the correct pin, airport staff may need to verify your badge but that happened to me before.
SEA Ramp, wettest place on earth
sid1975
Tue Jan 31, 2012 3:02 am
I want this job really bad, I dont want this to get in the way..
EMBQA
Tue Jan 31, 2012 3:16 am
Quoting sid1975 (Reply 4):
I hope you disclosed this to Delta if at anytime you were asked.
Maverick623
Tue Jan 31, 2012 6:13 am
Quoting EMBQA (Reply 5):
Delta won't care as long as he can hold a SIDA badge. It's purely administrative stuff for them.
Basically, you just have to wait and see. Based on past experience, it shouldn't be an issue unless the airport still holds a "grudge" against your previous infraction.
Quoting dlramp4life (Reply 3):
Easy with the details....
"PHX is Phoenix, PDX is the other city" -777Way
jetblast
Wed Feb 01, 2012 3:36 am
Quoting Maverick623 (Reply 6):
Can you explain what about the above is sensitive security information? I guess I'm not seeing it.
To answer the original question, I wouldn't worry about Delta having a problem with it. Things happen and you paid the fine, so be it.
Speedbird Concorde One
spudsmac
Wed Feb 01, 2012 7:13 am
Am I the only one who thinks this is over the top crazy? Have we really gotten so out of touch with reality that
is something that just happens? It's not like he's letting someone into a top secret intel room or anything.
Moose135
Wed Feb 01, 2012 12:54 pm
Quoting spudsmac (Reply 8):
Assuming that it was just an innocent mistake in typing in his PIN, it doesn't sound like such a big deal. But let's say his friend had his access cancelled because of some job action - say he was fired/suspended for cause, but tells him "I screwed up my PIN, can you let me in" only to have his friend create some mischief once inside to retaliate against his employer. Not saying this was the case, but taken to an extreme, it could have led to another incident like PSA Flight 1771
EMBQA
Thu Feb 02, 2012 3:22 am
Delta will care if during the interview he was asked " Have you ever had a badge revoked for any reason..? " .... " Aaaah NO.." Serious grounds for termination.
FlyASAGuy2005
Fri Feb 03, 2012 7:31 am
Quoting EMBQA (Reply 10):
I have a SIDA badge for ATL and MSP. MSP's app asks if you've ever held an AOA/SIDA badge and had it revoked. ATL's app doesn't specify. So it depends I guess. IDK where he'll be working.. As for Delta, I don't remember anywhere in my entire process where they asked about the status of prior airport badges.
What gets measured gets done.
