UAL747
How Are Head/Tailwinds Calculated?
Fri Feb 10, 2012 3:53 am
How does one calculate a headwind or tailwind in flight? Does it require the use of GPS, or can it be manually calculated somehow?
UAL
tdscanuck
RE: How Are Head/Tailwinds Calculated?
Fri Feb 10, 2012 4:39 am
Quoting UAL747 (Thread starter):
Velocity over the ground minus velocity in the air = wind velocity
i.e. it's the speed difference but, since directions matter, you have to use vectors (velocities).
It does not require GPS but it does require some way to get velocity over the ground. GPS is one way to get that but you can also get it from taking periodic position fixes using any other navigation sources or using an inertial reference system.
Velocity in the air comes straight from the airspeed system and the heading indicator.
Tom.
KAUSpilot
Fri Feb 10, 2012 4:52 am
It's calculated by Inertial Reference Units/Attitude Heading Reference Systems using trigonometry. The systems compare the aircraft's heading to its ground track and its true airspeed to its groundspeed to solve for wind direction and velocity, which is then displayed on the flight deck. The ground track and groundspeed can be determined by IRU's alone, GPS, or navigation radios receiving ground based navaids. The heading and airspeed are determined using traditional aircraft systems.
GPS can be used but something has to tell the GPS unit what the aircraft's heading and true airspeed are, so without that interface it won't be possible to display wind direction and velocity, to my knowledge. There are a few papers out there about using GPS signal reflections from the surface of the earth to calculate independent wind velocities, but I'm not aware if these methods are actually being applied.
Users browsing this forum: Baidu [Spider], iuwnaa, paracetamol and 1 guest
