Tod
Gap Between LD3's
Fri Feb 17, 2012 12:13 am
What is the nominal gap between LD3 containers?
thanks
Tod
fxra
RE: Gap Between LD3's
Fri Feb 17, 2012 2:58 am
Not nearly the amount you see on movies. Usually a few inches. Maximization of loadable space is the goal.
Visualize Whirled Peas
Clydenairways
Fri Feb 17, 2012 4:01 pm
Quoting fxra (Reply 1):
Yeah, some of those scenes make the holds look like the size of a stadium.
Daleaholic
Fri Feb 17, 2012 5:49 pm
I believe on older aircraft it could be up to 30cm between containers, however it is determined by location of the 'stops' on the hold floor. As has been mentioned, it tends to be only a couple of inches, if that. The containers are designed the be a pretty tight fit.
Religion is an illusion of childhood... Outgrown under proper education.
B777LRF
Sat Feb 18, 2012 9:28 pm
If you stack load them, which is allowed on certain types, the distance is nil, naught, nada, zip, zilch.
From receips and radials over straight pipes to big fans - been there, done that, got the hearing defects to prove
Users browsing this forum: a7ala and 31 guests
