Aircraft Wing Escape Path Colour
Sun Feb 19, 2012 6:42 am
Anyone aware of the worldwide norms for escape patch on commercial aircraft....its black on B737s & red on A320s.
Any reference to the rule.
nonfirm
RE: Aircraft Wing Escape Path Colour
Fri Feb 24, 2012 3:38 am
The Boeing Drawing for the 737 shows a black non skid edge and arrows with the field area a white non skid paint the drawing also has standard layout with measurements as well.
Big version: Width: 1200 Height: 812 File size: 349kb
[Edited 2012-02-23 19:51:19]
Fri Feb 24, 2012 9:52 am
Exactly.....Was looking for the Regulatory rule reference.....
Viscount724
Fri Feb 24, 2012 9:23 pm
Quoting HAWK21M (Reply 2):
As far as I can tell, there is nothing in the ICAO Annexes covering this, so it would be up to each country's regulatory authority.
Sat Feb 25, 2012 8:01 am
Quoting Viscount724 (Reply 3):
Anyone having access to the FAA reference to it.
bassbonebobo
Sat Feb 25, 2012 8:49 am
FAR part 25.810
(c) An escape route must be established from each overwing emergency exit, and (except for flap surfaces suitable as slides) covered with a slip resistant surface. Except where a means for channeling the flow of evacuees is provided—
(1) The escape route from each Type A or Type B passenger emergency exit, or any common escape route from two Type III passenger emergency exits, must be at least 42 inches wide; that from any other passenger emergency exit must be at least 24 inches wide; and
(2) The escape route surface must have a reflectance of at least 80 percent, and must be defined by markings with a surface-to-marking contrast ratio of at least 5:1.
No reference to color. The markings just have to contrast with the background significantly.
linky thing
Rule #176. Any device that can crawl across the table on medium, does not need to be brought into the office.
Mon Feb 27, 2012 9:14 am
Quoting bassbonebobo (Reply 5):
Interesting....Thanks...Guess the Manufacturer then determined the colour & decals.
Users browsing this forum: CONTACREW and 2 guests
