aquablue
JFK Parallel ILS Approach Question.
Fri Mar 02, 2012 9:23 pm
Hi,
I'm wondering if JFK can do parallel ILS approaches on its closely spaced runways (22/4) like airports such as San Francisco can? Are they using PRM or SOIA procedures, and if not, why
mmedford
RE: JFK Parallel ILS Approach Question.
Fri Mar 02, 2012 9:55 pm
Yes it can happen... it doesn't; because there is only one approach flow into the area...
ILS = It'll Land Somewhere
aquablue
Fri Mar 02, 2012 9:58 pm
The reason for only 1 approach flow is?
Do they use PRM/SOIA?
mmedford
Fri Mar 02, 2012 10:00 pm
Because we don't have airspace to have multiple routes of flight into the airport?
Check the STARs.
aquablue
Fri Mar 02, 2012 10:02 pm
Well, they certainly do use parallel approaches to the 31s. I often watch that on radar. So, it is possible then with 1 approach flow, no?
I don't see why they can't use it on the 22s.
[Edited 2012-03-02 14:04:05]
mmedford
Fri Mar 02, 2012 10:08 pm
Oh they have aircraft landing on 22R...if it's requested; I just figured out what you were asking.
But usually on 22L it's the VOR Approach with 22L ILS up.
aquablue
Fri Mar 02, 2012 10:11 pm
So, there is no hope of closely spaced parallel approaches using Precision Runway Monitoring or SOIA like in San Francisco?
mmedford
Fri Mar 02, 2012 10:24 pm
Quoting aquablue (Reply 6):
Been there, tried that... and no.
aquablue
Fri Mar 02, 2012 10:26 pm
I'd like if someone explained it to me with more than 1 line. Thanks.
Why bother answering if you're just going to give one liners? You're not talking to an aviation worker here.
[Edited 2012-03-02 14:27:25]
[Edited 2012-03-02 14:30:20]
Mir
Fri Mar 02, 2012 11:49 pm
Quoting aquablue (Reply 4):
The costs of PRM or SOIA equipment are high. The benefit, in this case, is not that great - the fact that you'd be using both 22s or both 4s for landings would mean that your takeoff capacity is reduced or eliminated on those runways.
Because they don't have PRM or SOIA equipment (and you would need SOIA, since the runways are too close for PRM by a couple hundred feet). And though I'm not exactly sure why they don't put in such equipment, I would suspect that it has to do with the airspace being very congested and there's no room for the extra arrival and departure corridors that would make it work.
Also, there is a cost/benefit side to everything, and it's possible that there aren't enough days where such an approach would get used to justify the expense.
-Mir
aquablue
Sat Mar 03, 2012 12:00 am
I understand, thanks.
I wonder would NextGen free up airspace to allow for another approach flow by allowing planes to fly closer together and also by using ground based systems to allow for closely spaced parallel approaches?
aquablue
Sun Mar 04, 2012 2:01 am
The 22s are used together for ILS landings right? I was watching the flow inbound one afternoon and the ATC directed certain planes to 22R ILS and some to 22L ILS and I didn't notice any pilot requests for it. Takeoffs were primarily on 22R and 31L.
[Edited 2012-03-03 18:02:26] The radar showed planes generally coming in over the coast of LI in 1 flow, but they were split off into two approaches at times.
[Edited 2012-03-03 18:03:38]
Mir
Sun Mar 04, 2012 5:57 am
Quoting aquablue (Reply 11):
If they are, it'll be in visual conditions only, or the aircraft will have to be staggered on the approaches (which limits capacity and thus is pretty pointless, considering the hit your departure rate is going to take).
It's rare, though - most of the time it's just 22L for landings.
-Mir
mmedford
Sun Mar 04, 2012 3:38 pm
Quoting Mir (Reply 12):
Aircraft are staggered on the approach into the 22s regardless...
But 22L can be a VOR/DME with ILS avaliable and the 22R ILS will be up.
aquablue
Sun Mar 04, 2012 4:57 pm
How is it rare, are you sure? I say this because very often when I look on the radar & monitor the ATC when the wind is in that direction it shows planes landing on both runways (22s) in the afternoon (which is when I monitor). Often they land very close to parallel. Also, the ILS approach is given for both by the controllers. They are also using the 31L for takeoffs at the same time!
Yesterday, for instance, the controllers switched the approach clearance from 22L to 22R for multiple planes on arrival. ILS also. The wordings was 'cleared ILS approach', there were no mention of VOR/DME approach.
The conditions were perhaps visual, but no visual approaches were assigned and the arrivals were filtering in nicely in the late afternoon. It seemed to work very well with 3 runways in use, 2 for landing, 2 for departure.
Also, because this was an arrival heavy time, I think arrivals took precedent here anyway so departure rate isn't of paramount concern? I think having NextGen closely spaced approaches might even speed up arrivals in this configuration in bad weather, no?
[Edited 2012-03-04 09:17:03]
Users browsing this forum: A320FlyGuy, Google Adsense [Bot] and 19 guests
