ferpe
Aspire: Will The 330S Become 330neo?
Mon Mar 05, 2012 1:54 pm
Aspire aviation has a majority well written speculation into a possible re-engine decision by A come second half of 2012:
http://www.aspireaviation.com/2012/0...engined-a330-along-with-sharklets/
The only thing I wonder about is their claim that the 787-9 would have a 247t MTOW and the 787-10 at 251t, IMO the 787-9 is already announced as 251t, will that change? If so perhaps as GE can't grow the GEnx as easily for 2014 but I thought they should be OK   .
Non French in France
connies4ever
RE: Aspire: Will The 330S Become 330neo?
Mon Mar 05, 2012 2:07 pm
I see the article indicates a 'typical' pax load of 335 in 2-class config. Wow ! AC's 330-300s are fitted for about 280 in 2-class. That is a big difference.
StickShaker
Mon Mar 05, 2012 3:01 pm
This is a good article by Aspire.
Interesting points regarding a re-engined A333 include:
1. 7000nm range - (250nm more than the 787-10) which may require extra fuel tankage.
2. Possible EIS of 2016/17 will fill the gap if delays occur in 358 EIS.
3. Potential to drop the 358 program not mentioned.
4. Both GE and RR engines discussed - RR more complex.
5. New engines will add weight.
6. 9 to 10% improvement in SFC over current generation 330's
7. Approx 10% SFC delta with 787-10 (advantage 787-10)
8. EIS 2 to 3 years ahead of 787-10 (Aspire figures)
9. Widebody market likely to increase - particularly regional market in Asia.
10. Availability of 787-10 may be production constrained.
11. Low risk program - leverages existing 330 client base and early 350 Mk 1 R and D.
12. 330neo will have pricing advantage over 787-10.
These moves by Airbus are a clear response to the now (finally) emerging threat of the 787-10. The 330 program is to Airbus what the 77W is to Boeing - a cash cow that is worth defending.
I suggest that pricing advantage of the 330neo will be more powerful than Aspire suggest as the current line would be fully amortized - something the 787 program wont be for many years. I'm also curious if the 10% SFC delta between the two aircraft is constant across different stage lengths or is reduced for sub 4000nm hops. With powerful pricing advantage along with all those commonality issues such as spares and training a SFC delta of less then 10% is unlikely to tip the scales for existing 330 operators.
StickShaker
Stitch
Mon Mar 05, 2012 3:03 pm
I just don't see a NEO option being available for the A330 family, unless it comes from Pratt in the form of a GTF.
Rolls-Royce has no real incentive to offer one. The Trent 700 is already the engine of choice on the A330 and they are the engine of requirement on the A350. They are also an engine option on the 787.
General Electric has already completed a bleed-air version of the GEnx for the 747-8 and had plans to develop one for the A350 Mk. I, but they had demanded two years of exclusivity on the airframe. As such, I could see them demanding to be the only new engine option on the A330. And in such a scenario, would they be very successful? How many Trent 700 operators placing top-up orders would go with a GEnx?
LAXDESI
Mon Mar 05, 2012 5:33 pm
IMO, only the A332NEO makes sense as it is right at the operating efficiency dividing line of 240-250 seats(3 class marketing) between 8-abreast and 9-abreast platform. A333NEO(8-abreast) will be at a competitive disadvantage against B789(9-abreast) as it is too far from 240-250 seat dividing line.
In the event that an operator (like CX) plans on configuring B789 with 8-abreast Y, then A333NEO may be competitive on medium haul routes against B789 if A333NEO is offered at a significant discount to B789.
Stitch
Mon Mar 05, 2012 7:12 pm
At 8-abreast, the 4 meter longer fuselage of the 787-10 gives it a seating capacity advantage over the A330-300neo. In fact, since the 787-10 cabin is very close to the same length as the A340-500, we can actually plug in Airbus' numbers for the A340-500 for the 787-10 and therefore eliminate the cabin configuration variables between Airbus and Boeing. Using Airbus' numbers for two class seating, that would be 359 seats for the 787-10 and 335 seats for the A330-300neo. An 8-abreast 787-10 would hold 7% more people and would also offer 38% more cargo volume, so CASM would be lower and cargo revenues would be higher.
Using Boeing's current list prices, a 787-9 is 17.5% more expensive than a 787-8. So if we assume a 787-10 is 18% more than a 787-9, that would put list at $269 million. An A330-300 is $231 million and figure the new engines will be $14 million, bringing the total list to $245 million. So the A330-300neo would be almost $25 million cheaper (at list). However, the 787-10 is a straight stretch of the 787-9 whereas the 787-9 is more than just a stretch of the 787-8) so if Boeing went with, say, a 10% premium, that would bring the 787-10's list to $256 million. The A330-300neo would save you $11 million up-front, but I expect the 787-10's lower CASM and greater revenue opportunities from the extra seats and cargo volume would address that difference relatively quickly.
cosmofly
Mon Mar 05, 2012 8:50 pm
Boeing has new 787 and plans to NG 777. Airbus has new A350 and talks about NG 330. They are both putting new engines on their NBs. Are they trying to keep the universe balanced?
IMHO both companies will have problems industrializing 2 new types so it only make sense to NG one to stay in the game in a reasonable manner.
The A330s have proven that the 6000nm market is huge and is only going to grow more rapidly. I think the 787-10 will be a huge threat that A cannot counter with any A350 variant. So the NG330 is not only created because of availability advantages, but also to give existing customers a competitive roadmap to leverage the infrastructures such as pilot pools, maintenance facilities and expertise.....
StickShaker
Mon Mar 05, 2012 10:53 pm
Quoting Stitch (Reply 5):
I think the street prices will tell a different story as Airbus will have far more room to move in terms of discounting the 330neo price than Boeing will with the 787-10 at what will still be a relatively early stage of the 787 life cycle.
The 787-10 will inevitably have a performance edge over the 330 but there are many other factors at play. A 330neo would be the logical choice for existing 330 operators while the 787-10 would be the logical choice for 787 operators.
A real shot in the arm for any 330neo would be the cancellation of the 358 program.
Airbus are sending signals that they will defend the 330's market share just as Boeing will do so with the 777.
StickShaker
rotating14
Tue Mar 06, 2012 1:13 am
Correct me if I'm wrong but isn't the 789, not the 787-10, more in line with 330S??
Stitch
Tue Mar 06, 2012 1:33 am
Quoting StickShaker (Reply 7):
Airline fleet purchasing decisions are not made on pricing alone, otherwise the skies would be full of 767s instead of A330s, A340s instead of 777s and 747s instead of A380s.
A number of A330 operators ordered the 787 instead of the A350 Mk I...
If the market is rejecting the A350-800 in favor of the 787-9, then yes, Airbus would be effectively forced to bring back the A350 Mk. I to protect marketshare. That being said, the 777 did fine with just two sizes, so I imagine the A350 will be fine with only the -900 and -1000.
Quoting rotating14 (Reply 8):
The 787-9 is a closer match to the A330-300 and some carriers have placed 787-9 orders that will likely be used to replace A330-300s. But the 787-10 will be able to perform all the missions an A330-300 can, as well, so I expect both will be pitched in RFPs.
StickShaker
Tue Mar 06, 2012 6:47 am
Quoting Stitch (Reply 9):
I'm not sure if 767/330, 340/777 are accurate analogies as there was clearly one superior airframe in each case. No-one bought the 346 in preference to the 77W because it was cheaper - the SFC delta was simply too much to ignore. The 787-10 and 330neo, however, are more closely matched. I don't disagree that there's more involved than just pricing but it could be significantly more than a subtle difference. There were many 320/737 sales contests that were won by the 320 due to pricing. The 787 itself gained many of its early sales (during the drug like rush) due to very keen pricing from Boeing (along with impressive specs). Boeing even went to the extent of changing their final assembly for the 787 in order to achieve Airbus like costs.
I've had quite a few arguments with accountants and CFO's that pricing isn't everything but I didn't win too many of them unless I had a mighty solid case.
And a large number of operators later ordered 330's once the 787 delays became obvious - plenty of scope for replacement.
The 787-10 will undoubtedly do very well - it has better specs than any 330neo and is more future proof. However, I think there is plenty of room for both A and B in this market.
StickShaker
[Edited 2012-03-05 22:48:39]
[Edited 2012-03-05 22:49:27]
RickNRoll
Tue Mar 06, 2012 7:42 am
If you can do it with the 777, why not the 330?
Stitch
Tue Mar 06, 2012 3:41 pm
Quoting StickShaker (Reply 10):
I believe the 787 to be a clearly superior airframe to the A330 - neo or otherwise.
Yes, because it is the best available option available at the time.
Same reason airlines are buying 777-300ERs by the hundreds today, even though I believe that the A350-1000 is a clearly superior airframe in comparison.
fruitbat
Fri Mar 09, 2012 7:43 pm
I think we have an answer:
http://www.flightglobal.com/news/art...rbus-cool-on-a330neo-plans-369319/
So that's put that idea to bed.
Weaseling out of things is important to learn. It's what separates us from the animals ... except the weasel.
SchorschNG
Mon Mar 12, 2012 1:08 pm
Quoting Stitch (Reply 12):
A theoretical A330NEO would come close to the B787, but always come in behind. In widebody market the winner usually takes all, so being 5% worse at exactly similar payload-range performance means you get probably only a small fraction of the market.
From a structural standpoint, passengers are the worst possible payload. [Michael Chun-Yung Niu]
DocLightning
Mon Mar 12, 2012 11:15 pm
Quoting SchorschNG (Reply 14):
True, but you also get to drive your competition's prices down.
-Doc Lightning-
-Carl Sagan
Stitch
Mon Mar 12, 2012 11:51 pm
Quoting DocLightning (Reply 15):
The list price of the 787 is lower than that of the A330 and I would expect Airbus to not set the list price of the A330neo below that of the A330.
RickNRoll
Wed Mar 14, 2012 11:15 pm
I think you will find that Airbus has a fair bit they can easily strip off the A330 margin to make it more competitive but stil make a healthy profit.
