flipdewaf
Ultimate Load Vs Max Weights
Tue Mar 13, 2012 12:23 pm
I started a thread about wing load questions several months ago and I have a few more questions but thought I'd start a new thread rather than dig up the old one.
I remember from my uni days (only 4/5 years ago) that the wing structure was largely based on MZFW and the 2.5G turn with the 1.5 load factor.
I realise that these tests are largely to test the validity of the modelling methods but is there any chance these can be used to modify the useable weights. I'll use the A350 as an example as this is the next big jet to undergo this test.
MZFW is 192000kg, if the ultimate load testing on the wings went to 156% before breaking would airbus be able to say that the wing is good for 199680kg? Obviously other components do rely on weights and loads so all others would have to pass too or is it just good for the weight to which it has been designed i.e 192t?
Fred
tdscanuck
RE: Ultimate Load Vs Max Weights
Wed Mar 14, 2012 4:13 am
Quoting flipdewaf (Thread starter):
Depending on the design, it may be MTOW or MZFW, and 2.5g x 1.5. Whichever is more limiting will be the test point (it depends on the MZFW/MTOW spread).
Yes, absolutely, this is a normal occurrence.
Yes.
No, you can go beyond. This is partly how you can get increased weights without re-doing the static tests.
Tom.
